Hydraulics in a sports car (seriously) | FerrariChat
Discussion in 'Other Off Topic Forum' started by cohiba_man, Mar 8, 2004.
  1. cohiba_man
    cohiba_man Formula Junior
    Jan 23, 2003
    937
    Canada
    I've been thinking about this for quite a while, I'd like to DD my C5, but I find it too low to be comfortable an a lot of driveways...would it be possible to put airbags in to raise and lower the front/ whole thing up to 2 inches or maybe a little more and right down WITHOUT affecting the suspension, handling at all and with a minimal (100-200 pounds at most) weight increase. Is this possible or will it mess up the ride and handling dynamics? Remember this is a funtional system, not for the 'bling-bling' factor.
  3. Auraraptor
    Auraraptor F1 World Champ
    Sep 25, 2002
    12,336
    MO
    Just about everything I have heard is that these systems kill handling.
  4. robiferretti
    robiferretti F1 Rookie
    Oct 31, 2003
    3,299
    NYC area
    rob ferretti
    think aobut it too, an extra 200 lbs on either end of the car throws off the balance that the car was designed around
  5. F360@20
    F360@20 Karting
    Nov 24, 2003
    244
    San Diego
    Yea, I looked into it for the same reason you were. Except I wanted to set my coil-overs down to where the car sat 1 inch off the ground. So when I was driving I could have the bags up and ride with no problem and when I wanted to have fun I just hit the switch and it drops right down on to the coils. But no luck it kills your handling sorry.
  6. karmavore
    karmavore Formula 3
    Dec 29, 2002
    1,641
    Hell
    Karmavore
  8. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    8,825
    What is a DD? Dutch Delima? Deliberate Dementia?
    However, I will note that raising or lowering the car by 3 millimeters (yes mm) is enough to alter the camber and toe settings on these cars.
    With the long/short a-arm suspensions Ferrari uses (Corvette uses this too); the roll center generally moves about 60% faster than the ride height of the car. This leads to geometry effects like when the car is high off the road surface, you need very little spring to control roll, but while the car is low to the road you need much more spring to control roll. Exactly the opposite effect as desired!
  9. cohiba_man
    Jan 23, 2003
    937
    Canada
    Thanks everyone, thats too bad. BTW, DD means daily drive
