360 - Impossible to shift when warm (Manual Transmission) | FerrariChat
360 Impossible to shift when warm (Manual Transmission)
Discussion in '360/430' started by KILOCHARLIE, Apr 20, 2019.
  1. KILOCHARLIE
    KILOCHARLIE Formula Junior
    Oct 14, 2012
    321
    Cardiff, UK
    KC
    A while back I noticed that on a long motorway run and the car in 6th gear for an extended period of time, the gear shifter required quite a bit of force to knock it out of 6th and engage other gears.
    Slowly this has become a problem when once the car is warm at all, gear shifts are really tight and sometimes impossible to change gear at all.
    I've just had my gearbox oil changed in the hope that may solve it, but no difference at all, if anything slightly worse.
    Could it be my oil is overfilled and causing too much pressure when warm? Both the last two gearbox oil changes (both different types of oils, the most recent being redline ns), I'be followed the workshop procedure which says to measure and replace the same amount that comes out. My dipstick shoes slightly over maximum when cold.
    Or could it be something else? Cables were replaced prior to my ownership 7 years ago but it was fine until a year ago or so. Gear linkages were also greased at my request on last service.
    Thanks for any advice.
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    I think there are threads on this, something to do with the gear lever bushing i think. Better parts are available from hill engineering or superperformance. Others on here know more than i do
    gt1995 likes this.
  3. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    Obviously the bushing is a possible cause. There may be air in the line, a failing throwout bearing, an adjustment is needed, etc. You will have to dig into it to find the root cause.
    gt1995 likes this.
  4. KILOCHARLIE
    Oct 14, 2012
    321
    Cardiff, UK
    KC
    Thanks both, I had seen the hill engineering part previously but it didn't sound like the same issues I'm having with the shifting only when warm. Feels more like transmission problem as once the engine cools back down its fine again.
    Maybe worth doing to rule out, then I was going to take some oil out to remove the possibility it might be overfilled (if anyone thinks that might be a cause?), then I'm guessing it'll have to be looked at by someone with more experience than me!
  5. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    Good call to check the fluids. I am not an expert but I think I read that overfilling can/will impact shifting. Good luck.
  6. one4torque
    one4torque F1 Veteran
    5,123
    Houston
    One4torque
    Check your bushing.
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Any dealers local to you ?
  8. timwu12
    timwu12 Formula Junior
    919
    TX
    if it's not your bushing, bleed the line to the throw out bearing at the clutch block, you might have air in the line that's causing the TOB to not push on the pressure plate fully, thus having a hard time releasing the clutch and changing gears.
    i had a similar problem at high rpm where the pedal was soft and the gear wouldn't disengage. I bled the line at the clutch block and problem fixed
  9. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    Didn't the 360 have an issue with leakage at the divider block? I think I remember that from other threads. I think HE makes a different block. IF it is leaking you could have air in the system that way as well.
  10. KILOCHARLIE
    Oct 14, 2012
    321
    Cardiff, UK
    KC
    Thanks all. I already have the Hill engineering block after the original leaked a few years ago and left me stranded on the side of a motorway for four hours.
    My nearest dealer is about 3 hours drive away but I have a local guy who is quite competent although is not familiar with common Ferrari problems etc.
    Does anyone know if the bushing can be visually inspected? From memory the original is plastic and the HE is steel? For some reason I have a memory of seeing the bushing was updated in my service history somewhere which I guess would rule that out.
  11. RossoC360
    RossoC360 Formula Junior
    Jun 20, 2008
    475
    Buffalo NY
    Jason
    The original piece is plastic and in reality under engineered, the HE part is aluminum and far superior. If you attempt to inspect or replace yourself, maybe this video will help.
    robertjskelton likes this.
  12. one4torque
    5,123
    Houston
    One4torque
    My plastic bushing was visibly worn thin.
    Some people find them cracked.
    My difficult shifting went away w the bushing. And I need to let car fully warm up for the sweet shifting.
    It’s a little fiddle to do yourself, but I managed w simple tools.
  13. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner Rossa Subscribed
    Jan 19, 2004
    7,542
    San Jose, California
    We need to make sure we differentiate between "hard to shift" and "hard to get into gear". I went through the whole bushing thing, but I too have a harder time pushing the shift lever around when my car is up to temp than I do when the car is cold. Will check for air in the lines. Thanks
  14. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    That and the OP says he has the HE bushing already.
  15. dang2407
    dang2407 Karting
    Apr 29, 2017
    169
    SW France
    Checkout my thread on adjusting cables - no cost apart from time. In summary try each cable adjuster (behind the gear lever) one way and then the other. Continue with the way it makes progress until there is no more improvement.
  16. KILOCHARLIE
    Oct 14, 2012
    321
    Cardiff, UK
    KC
    Anyone know if the HE bushing would be called "roll pin" or "cable bush" at the "bottom of gear lever"?
    On checking my service records, this work was done a few years ago. Unsure whether this is the same as the HE part. The part on the materials is listed as "pin" and "small block"
