Impressive 348 Gearbox Picture | FerrariChat
Discussion in 'Technical Q&A' started by ricrain, Jan 2, 2004.
  1. ricrain
    ricrain Karting
    Nov 1, 2003
    213
    Dallas Area
    Ric
    It impresses me, anyway. The fact that all that stuff actually fits inside the gearbox case!
    Now, if only I can remember how it goes back together... :)
  2. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    What kind of wear did you find in there? Were you able to get parts without too much difficulty?
  3. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Really nice work, by the way. Thanks for the pic.
  4. lou staller
    lou staller Formula Junior
    Dec 21, 2002
    378
    Orange County Ca
    Lou Staller
    I am impressed! You're my hero! It seems as if you're ready to tackle anything. I thought the rear brake calipers were 'over-engineered' with all those little pieces until I tore into them. Now that I'm finished with one they are as simple as can be.
    By the way, how did you get the case so clean? What did you use to clean it? Painted or natural? It looks awesome!
  5. fly
    fly Karting
    Nov 20, 2003
    124
    Sydney, Australia
    Steve
    Great Pic Ric, thanks for sharing it… by the way, how did you get the case so clean?
  6. Dale
    Dale F1 Veteran
    Oct 7, 2003
    5,211
    uk
    Dale Juan
    Hi Ricrian very nice job your doing there,nice and clean all inspected for wear new bearings and seals while your in there,well done nic pics to
    cheers
    Dale.
  7. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,544
    Commifornia
    The Bad Guy
    Oh very nice Ric! And all this because you were bored. LOL.
  8. fatbillybob
    Aug 10, 2002
    25,728
    socal
    Ric,
    Impress yourself more..open the Diff and you can increase your parts by 20-30%
  9. 328GTB
    328GTB Formula Junior
    305
    Texas, USA
    Carmine
    Great shot! What's the motivation for the teardown? Or did you get carried away...
  10. Bmyth-FDC
    Bmyth-FDC F1 Rookie
    Oct 4, 2002
    2,742
    Southern California
    Byron
    Ric,
    Great picture! Reminds me when I had my tranny apart with fatbillybob and the parts were everywhere! Good luck with the repairs! :)
    Byron
  11. william Heung
    william Heung Rookie
    Dec 4, 2003
    21
    maybe its the ignorance me, but I don't seem to be able to find the icon to open the great pictures that everbody was talking about. Am I missing somethig?
    Best Regards
    William Heung
  12. ernie
    Nov 19, 2001
    22,544
    Commifornia
    The Bad Guy
    Yeah you are Will. You have to log in. Then the pictures will appear when you look at a thread.
  13. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,169
    I don't see the gear that changes from longitudinal direction to transverse direction. Did you leave it in the case?
  14. fatbillybob
    Aug 10, 2002
    25,728
    socal
    Mitch it is in the case with main shaft and a bunch more gears. You know Ric...you probably do...once you pull those shaft end bearings you screw the relation of the main shaft to the pinion gear so you have to shim the pinion or you will blow something.
  15. ricrain
    ricrain Karting
    Nov 1, 2003
    213
    Dallas Area
    Ric
    :) ...part of the reason it's still in there...
  16. ricrain
    ricrain Karting
    Nov 1, 2003
    213
    Dallas Area
    Ric
    Inspection mostly, I figured since I had it out of the car, I'd replace the prawl springs, as they're reported to weak fairly quickly.
  17. fatbillybob
    Aug 10, 2002
    25,728
    socal
    Ric,
    You have come so far...I would take the rest of it out. One box I fixed did not have this part in spec and was missing teeth here. I suspect that these boxes loose the preload here and then the pinion migrates into the main shaft. I would at least prusian blue the pinion to mainshaft to make sure the obvious. You can't check the preload with the mainshaft in place.
