Injection cleaner? | FerrariChat
Injection cleaner?
Discussion in 'Technical Q&A' started by Prugna 328, Nov 12, 2003.
  1. Prugna 328
    Prugna 328 Formula 3
    Sep 10, 2003
    1,233
    L.I.N.Y.
    Gregory
    Does anybody ever use fuel injection cleaner? Is it safe in an Ferrari? Thanks!
  2. CraigFL
    CraigFL Formula Junior
    Jan 17, 2001
    954
    Panama City, FL
    Craig
    If you search past threads you'll find that most like Chevron Techron
  3. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,079
    Southeast USA
    Mike Charness
    Chevron Techron is great, but I also like Lucas "Injector TuneUp"
  4. 4re gt4
    4re gt4 Formula 3
    Apr 23, 2002
    2,279
    Roseburg, OR
    Hans E. Hansen
    In the late '80s, Techron was the "official warranty repair" for bad injectors in GM cars. GM would pay for injector replacement only if the Techron treatment failed.
    It often worked.
  5. Verell
    Verell F1 Veteran
    May 5, 2001
    7,017
    Groton, MA
    Verell Boaen
    About mid-way thru the driving season my 308 usually starts running slightly rough. A bottle of Techron in about 1/3 to 1/2 tank of gas makes it disappear in 50-75 miles.
    It also removes any moisture that may have collected in a gas tank.
    I once got some bad gas that must have had some water in it. My car
    would barely run. Bucked & sputtered like you wouldn't believe.
    Dumped a couple of bottles of Techron in the tank & the problems were gone in 10-15 miles!
    At least one local mechanic soaks clogged injectors in it overnight,
    then blows it off. Claims it restores a clean spray pattern almost
    every time. Even badly clogged injectors respond to it.
  6. 4re gt4
    4re gt4 Formula 3
    Apr 23, 2002
    2,279
    Roseburg, OR
    Hans E. Hansen
    Shaken with a little orange juice, and it also makes a fine cocktail.
  7. bobafett
    bobafett F1 Veteran
    Sep 28, 2002
    9,193
    Use Swepco 503... (at least I think it'd 503. I'll confirm when I buy some more bottles). That stuff works brilliantly and has been SERIOUSLY field tested (one owner used it with every tank in his TR. did 100k miles in it including runs (and a win) at virginia city hill climb).
    --Dan
  8. Doc
    Doc Formula Junior
    Sep 13, 2001
    886
    Latham, New York
    Bill Van Dyne
    A Ferrari mechanic just told me yesterday that he is using Lucas brand fi cleaner. He thought that it worked even better than Techron ( he loves Techron too) and is much cheaper . I'll be giving this new recommendation a try soon.
    PS--i hope that the fi cleaner works better than Lucas electrics!
  9. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,079
    Southeast USA
    Mike Charness
    By the way, Lucas is a supporter of the Ferrari Club (FCA), specifically as an event sponsor in our Southeast Region. I use their FI cleaner "tuneup" regularly, as well as their oil additive. They're very involved in motorsports racing (see www.LucasOil.com)
