News
Installing Hyperflows Yourself...How Hard Is It?
Discussion in '348/355' started by billyfitness, Feb 19, 2008.
  1. billyfitness
    billyfitness Formula Junior
    Feb 14, 2006
    581
    Overland Park, KS
    Bill Leavitt
    I just purchased a set of Hyperflows and am debating on installing them myself as it appears many of you have.
    Do you have any advice, tips, or DIY info you can pass on? I am very handy, work on my other cars a bit but have left the Fcar stuff to a mechanic.
    For instance: pulling the bumper, just jack the rear end up or jack stands all around?
    Any help/tips are appreciated,
    -Billy
  3. PAP 348
    PAP 348 Moderator
    Moderator Owner
    Dec 10, 2005
    86,844
    Mount Isa, Australia
    Pap
    Jack up rear of car...............remove exhaust and hook in. :p:p
    Make sure the engine is DEAD COLD, then soak all the nuts on the exhaust/cats with WD40 for as long as possible. :):)
    Hopefully they will not be too tight remove. ;);)
    It is an easy job mate. Have a go if you think you are handy. Its only an exhaust, remember. :D:D
  4. Ferrari Fanatic
    Ferrari Fanatic Formula 3
    Apr 2, 2003
    1,267
    SoCal
    2 more tips:
    1) I pull of the rear wheels as it makes access from the side a lot easier
    2) hope you have fingers like "ET"
    On a scale fr 1 to 10, 10 being the hardest.
    Tech level: 3 as you are just spinning nuts.
    Knuckle Buster: 5 as it is kinda tight.
    Frustration Level: Average off 5 depending on how things go.
    Also, pre soak all of the bolts the night before. Also the clamps are a piece of a sh.. and I swear are made of old Japanese pot metal. The crack pretty easily.
    Now get out there and get er done so you can terrorize all your neighbors with with F-1
    sounds :)
  5. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,002
    Southern Md
    Robbie
    I picked up a set of used Hyperflows also--just trying to find time to install them..If I told you guys the price--you would shoot me...:D:D:D:D
    Do any other exhaust componenets need to be loosened or removed?? Or just remove cat and install cat?
  6. recoil
    recoil Formula Junior
    454
    Virginia
    Steve
    Robbie,
    Find me a set!
    Steve
  8. f355spider
    f355spider F1 World Champ
    Rossa Subscribed Owner
    May 29, 2001
    17,269
    Hugh G. Rection
    +1 this job is really straight forward, and not that difficult.
  9. Ricambi America
    Sponsor Owner
    Steve... shoot me a PM if you're serious. :)
  10. billyfitness
    Feb 14, 2006
    581
    Overland Park, KS
    Bill Leavitt
    Thanks for the tips guys. A couple more ?'s & comments:
    --> How do you get the bumper off? (Is it necessary at all or just go from the top and through the wheel wells?)
    --> Two jacks or just one to lift the rear end. (There was a post a while back stating to use two, one on each side of the Tranny at jacking points.
    --> Most agree that I buy replacement Exhaust Clamps by Hill Engineering now. (I assume D at R has them)
    --> I think the exhaust just has to be loosened and not removed
    --> This will have me with Tubi Headers, (only a year old), Tubi Exhaust, & HF Cats...I can't wait!
    -Billy
  11. 285ferrari
    Sponsor
    Sep 11, 2004
    20,002
    Southern Md
    Robbie
    No bumper removal neccesary...
  13. 355Aussie
    355Aussie Formula Junior
    634
    George
    No bumper removal necessary.
    All you have to do is remove the top heat shield and air boxes.
    Then undo the bolts that hold the cats in place bewtween manifold and exhaust.
    You may have some difficulty with the bolts but some WD40 will cure that.
    Next slide out the old cats and replace with new Hyperflows that will slot in easily.
    I did not have to remove tyres, bumper or exhaust.
    It was pretty easy for me.
  14. Shark49
    Shark49 Formula Junior
    Mar 31, 2005
    773
    Boone, NC
    Nathan
    It was easy! The only trouble was that i had to chip off a rusted exhaust donut. Combined with the hyperflow, it turned my mild mannered mondial into what a ferrari should sound like!
  15. 285ferrari
    Sponsor
    Sep 11, 2004
    20,002
    Southern Md
    Robbie
    So pretty easy to get them from the top?? Looking at mine--I don't see if they go in one way or the other--Is there a front and back to the cat--Does it flow both ways? Both sides are interchangable also?
  16. stuckinkuwait
    stuckinkuwait Formula Junior
    Jul 25, 2004
    630
    Northern New Jersey
    Lenny S
    Billy, I have Hyperflow cats and a Tubi on my car and the sound is great!
  17. billyfitness
    Feb 14, 2006
    581
    Overland Park, KS
    Bill Leavitt
    Thanks for the continued tips George.
    Robbie...there is definitely a left and a right and a front and a rear. Look at the attached flange to the header and attached mounting bolts.
    -Billy
  18. Ferrari Fanatic
    Apr 2, 2003
    1,267
    SoCal
    +1 Yep, forgot that one: Remove the sheild and air boxes.
  19. f355spider
    May 29, 2001
    17,269
    Hugh G. Rection
    ??? Are you removing the cats through the top?
  20. Ferrari Fanatic
    Apr 2, 2003
    1,267
    SoCal
    No but it gave me better accessability to muffler and other fasteners. I don't like to scrape my knuckles.
  21. 285ferrari
    Sponsor
    Sep 11, 2004
    20,002
    Southern Md
    Robbie
    OK---Well while in the garage tonight I kept looking at the Hyperflows sitting on my shelf and couldn't resist... Got the stock cat off the passenger side and fitted the Hyperflow in place----will finish tomorrow...PS - Did all this from above never jacked up the car at all....
  22. MufflerMan
    MufflerMan Formula 3
    Jun 12, 2005
    1,543
    Sacramento Ca
    Colby Sandman
    Wow from the top, nicework. I have never done it from the top as I always put them on a lift. Prepare to have some problemswith the clamps, we always replace them to insure no problems later on. We remove the diffusers from the bottom and then remove the old and install the new. 355's are much easier than the 360's. Good luck!
  23. 285ferrari
    Sponsor
    Sep 11, 2004
    20,002
    Southern Md
    Robbie
    Wasn't easy, but I have no lift and figured if I could turn my hand into elastic man it would work. Hopefully the drivers side isn't any harder than the pass. side because the pass. side was a bit$% by myself working from above. I think I dropped that 13mm wrench 18 times....The only clamps that actually come off are the ones between the muffler and cat--I had both of those replaced back when I installed the secondary cat bypass pipe with Hill ones...My mechanic had a few extras laying around..
  24. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,964
    Milton, Wash.
    Jeff B.
    WD40 is useful for lots of things, but not for freeing rusty nuts and bolts. There are dozens of products that work much better as a rust penetrant.
  25. recoil
    454
    Virginia
    Steve
    You taking pics of the install?
    Steve
  26. 285ferrari
    Sponsor
    Sep 11, 2004
    20,002
    Southern Md
    Robbie
    I was going to, but it is difficult stopping to take pics every time I remove or loosen a bolt or nut.Then with my dirty hands, didn't want to go messing with the camera...
  27. 355Aussie
    634
    George
    A bit late with my reply to your question on the Hyperflows. If it helps I dropped the wrenck 36 times!!!!!
    But as you can see it can be done from the top without jacking car up.
    I have the Hill ones to and that certainly makes it easier.
    I think you have the X-OST on so would be interested to find out what it will sound like.
    MY X-OST is oln its way. I have mille miglia on with the Hyperflows at the moment and the sound is really great but interested to see what they sound like with X-OST.
    When you start the car up make sure you check for air leaks where the cat bolts onto the manifold. Don't worry about slight leak from cat to muffler.
    Good to see you getting them on
  28. 285ferrari
    Sponsor
    Sep 11, 2004
    20,002
    Southern Md
    Robbie
    Hopefully I will get them on tomorrow...
