Installing SRI Gold kit today - little help? | Page 3 | FerrariChat
Discussion in '348/355' started by ketel, Jul 4, 2013.
Thread Status:
Not open for further replies.
  1. johnk...
    johnk... F1 World Champ Owner
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    Is this the one? NAPA AUTO PARTS
    It's a pig tail but you know how to removed the terminals now. :)
    Also, if that's the right one search other stores for 1989 BMW 325i sensor connector. They were used everywhere, FI conncetor, CTS connect, idle air control valve connector, ......
    NAPA is a little costly. The housing alone is a $3 part.
    Also it's good to have a pig tail around since it come in handy for testing various sensors.
  2. fatbillybob
    fatbillybob Two Time F1 World Champ Consultant Owner
    Aug 10, 2002
    29,376
    socal
    Maybe I got it wrong but how can one air temp connector cause all those problems? I see no way that can happen. I can understand the air temp code but not the others. But I'm not obd2 genius. Was the purpose of doing the gold kit to make a good car better or eliminate ghosts? If the latter...
    The plug may truely be bad now but if you depin the plug and connect the pin right on the sensor you got connection. If you still get codes it is not the pins fault and the potential for you to have done the plug right is there.
    To debug look carefully at everything done so far. If dave does not have the pluginstoc k you can try here: Electrical
    Fix the plug with new. Then clear your obd2 codes. Then see if they come back. If this all started as a ghost chasing excercise then the best bet is to just complete the gold kit install and debug your car from there because you will have new ghosts. If ghostbusting you need to check everything 3 times making sure to get excellent crimps and no swapped wires. Try to use the repinning exercise as a way to eliminate wiring as a source of the problems. Trust yourself. There is nothing to this. Many of us have done this and you can too. You wire is either crimpped or not. Your wire is either in the right socket or not. Work slowly and methodically to make sure these two things are done and their can be no error. Your wiring will then be sound as it can be and you can eliminate wire as the source of ghosts.
  3. ketel
    ketel Formula 3
    Aug 6, 2007
    1,356
    Sausalito, CA
    No yelcab. I had the other faults earlier. I just have another one now - P0113 for the air temp sensor.
  4. ketel
    ketel Formula 3
    Aug 6, 2007
    1,356
    Sausalito, CA
    Yes, I think that's a compatible unit. Obviously, I just need the housing, not the wiring. Will try Napa tomorrow and see if they have any local stores that carry it.
  5. SoCal1
    SoCal1 F1 Veteran Owner
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Take your time and go after each code one by one. You will get a great understanding of OBD2. Dont get frustrated and freak out. OBD2 becomes easy and a great tool once you get into it's head. When they went from 1 to 2, I was so happy
    Get your air plug done first.
  6. ketel
    ketel Formula 3
    Aug 6, 2007
    1,356
    Sausalito, CA
    No, as I replied to yelcab, the other CELs were already there. The P0113 code for the air temp sensor is new.
    Both. I've had CELs since I bought my 355. I wanted to do the kit for some time to enhance performance and for all the other reasons people invest in this project. I realized that I can throw money at the problem by buying new 02 sensors and thermocouples and the like and still not fix the issues or I can invest in the kit, which I wanted to do anyway, and see what CELs remain after the kit is installed.
    I'm a little unclear on this. Are you suggesting I remove the terminals from the supposedly bad plugs? If so, how would they then fasten to the male plugs and how would I check for good connection? I like the idea just unclear on the process.
    ketel
  7. yelcab
    yelcab F1 World Champ Consultant
    Nov 29, 2001
    13,694
    San Carlos, CA
    Mitchell Le
    Ok, if that is the case, just keep plugging away and finish the kit install to see what you get, then chase down the error codes one at a time.
    What FBB means is to remove the pins from the housing and connect them together without the housings, thereby eliminating the housing as the problem.
    Good luck.
  8. fatbillybob
    Aug 10, 2002
    29,376
    socal
    Let's say the sensor has to male pins embeded in a female body. You put the gold female pins into the male mangled body and you fear that the pins are loose and not making good contact. So I say prove that it is the mangled body and extract the female new gold pins from the mangled body. Slip the new wired gold pins individually on the sensor in the proper place. You know you got contact and then you can clear the codes and see if the air temp code returns. A tug on the newly crimped gold pins and you guarantee a good connection of pin to wire. Therefore your code has to come from somewhere else like connection to the ECU, frayed wire somewhere else, bad sensor. You just can't leave the connection this way obviously because the connection is not secure. That is what the mangled plug is supposed to do...hold pin positions, protect, seal out dirt etc.
  9. Loser
    Loser Formula Junior
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    I believe you can probably wrap the bare gold connector with a bit of electrical tape to keep it from shorting to the next pin over, then just push it onto the male pin. Do this for each pin in the connector. This will temporarily get your car to run until your new plug housing arrives.
  10. johnk...
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    Seems like you are starting at the horses ass. I would think that before you start installing the gold kit you should be checking for bad sensors, wiring continuity, and finding out what all the different codes are for. P0154 is an O2 sensor code. It's pretty easy to pull and test an O2 sensor. Any code above P0999 is manufacture specific. I don't know if there is a resource that lists them.
  11. GerryD
    GerryD Formula 3
    May 5, 2010
    2,448
    North of TO
    Guido
    Sorry but I think this has to be said.....Those not mechanically or electrically inclined should not be attempting this job.
  12. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    THIS is a lively debate that done in this manner helps everyone involved with a better understanding of the problems and the systems, this is a Net Positive.... if only all of the technical discussions would go this way, so very much could be learned on here.
    Ketel, I dont supply the plugs anymore but that doesnt mean I dont still have some 470 odd pieces of that part on the shelf from my initial order of them..... just a call and one is in route, simple as that. I have tens of thousands of connections and plugs that are no longer or never were supplied, but were ordered in to perform tests with to see if it was warranted. IF it is supplied, it has proven that it cant be done effectively without it. IF it isnt supplied, testing showed it has a high rate and reasonable expectation that "it" was not "Needed" to do the job.
    Cost/risk analysis.... it was a terrible headache in the design given there was one infinite variable involved, the technical abilities of the "installer". It is for this reason that after a specific success was duplicated numerous times in our own shop, we needed it tested by individuals that were not so close to the design to make sure we could duplicate the results outside of our efforts. As Pro's, we have every tool imaginable at our hands, the car owners do not.... can the ease of install and the results we had noted, be duplicated with only the tools provided? Beta testers were chosen carefully, some with excellent hands on experience, some only knowing which end of the car was dangerous.... and from that we answered our questions on if enough tools were provided. Trust me, if my hands were not tied in regard to the 'cost', there are a great many more bits that would be supplied. When it comes to results, cost be damned, it gets included and the cost IS what it IS. Feedback is what has defined this kit and will continue to improve it.
    Actually John, my experience shows that this individual ghost chasing technique is no longer (and actually never was) the most effective manner in which to fix these problems. Most are assuming that a given code is the direct fault of the component mentioned in the code, and that assumption is incorrect. That given code, as FBB correctly stated, is an indication that the ECU is not seeing parameters that it is expecting to see. This condition can be a problem with multiplicative values from a number of sensors not adding up correctly, grounds with high resistance, connections with high resistance.... or maybe even a bad sensor. Yet another consideration is the possibility that the failure was corrected but the codes saved in the ECU memory were not erased OR a relearn of all the operating parameters in the computer was not initiated so IT is forced to take a hard look at a whole new package of operating parameters to decide if all is well. Given time the ECU's were do all of this on its own (2.5 and 2.7 relearn the parameters each time the starter is engaged, the 5.2 takes many drive cycles). I will state that in the last 4 years I have not replaced a single sensor on any car coming through the shop, not a single one...... you decide if that statement has merit and who that it displeases or pleases. One can have shill's on Both sides or a debate.... I choose not to have any on mine BUT........
    I am a Distributor for most all of the companies you noted as well as a great many more that folks have never heard about. I purposely did not have my name put on their dist. lists because I dont need the headaches that come with that..... this is plenty for me already! On a number of components, they simply can not be purchased, we Made them because they were not available at any cost.
    As I already have a permanent standing on Ferrari's Legal Staff's Christmas Card list, I do not duplicate any of their drawings re sensor locations. It is in the WSM, prominently on the first page, and done so well that there is zero reason for me to attempt to improve it. Remember, if it isnt provided, there is good reason.... Ferrari doesnt take kindly to such things. We both put a great deal of effort into our own IP, we both protect it passionately and I can respect their position on that matter. Im not one to look for legal loop holes, I am already like Pigpen on Charlie Brown.... trouble finds Me plenty good already, I need not look for it!
  13. Dave rocks
    Dave rocks F1 World Champ BANNED
    Nov 23, 2012
    16,047
    Orchard Park, NY
    Dave Lelonek
    Side note: Are you doing this work with the battery switched "off"? I hope so.
    Take a step back and I'm sure you will be successful
  14. yelcab
    Nov 29, 2001
    13,694
    San Carlos, CA
    Mitchell Le
    Wow, if that statement also includes O2 sensors then it is truly a magnificent solution !
  15. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    My mistake, yes I have replaced O2 sensors but only on 360's, not 348/355/550's. Aside of the consumable O2 sensors, no engine management sensors have been replaced.
  16. johnk...
    Jun 11, 2004
    11,293
    CT
    John Kreskovsky
    I agree that if a code is thrown it is not necessarily a bad part. But it's not a ghost. A thrown code is an indication of a problem: bad sensor, broken wire, bad contact.... I guess it's just the anal engineer in me that says find the source of the problem before you start fixing it. Certainly replacing a sensor won't fix a bad connection any more that fixing a connection arbitrarily will fix a bad sensor or broken wire.
    I must add that with all my cars (8) since OBD I was introduced every code I have seen has been accurate. Most recently my 2002 Toyota truck indicated an open O2 heater. A quick measurement of the sensor showed it was indeed the heater, not an bad connection or broken wire/bad ground. And as for my recently acquired 95 F355, it threw a coolant temp code and a 5 minute check showed that the sensor was indeed bad.
  17. Loser
    Apr 11, 2008
    791
    Gilroy, CA
    Tom
    As an example, my car has a P0102 code indicating a bad MAF. I have replaced the MAF, wires from the MAF to the ECU, connector pins (twice), and even the Motronic ECU. I still get the P0102 code, so it must be something else in the system. I've been trying to troubleshoot this one for four years now.
  18. dantm
    dantm Formula 3
    Nov 1, 2003
    1,104
    YYZ, BOS, SFO
    Dan B.
    Dave,
    From your extensive experience with the gold connector kit, can you advise on the connector footprints that are in the F355 2.7? I need to build some test-debug cables (such as the ECU cable with the test momentary switch) as well as a Thermocouple 'fake' probe.
    I was able to match the Metri Pack 150 2-pin female connector to the CAT ECU input, but the Metri Pack 150 3-pin connectors seem to be 'keyed' so that they only go in one direction. Therefore the male connector from Metri Pack does not mate to the female one that's already on the car.
    Any thoughts or direction suggestion?
  19. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    I was going to say that, but did not want to offend anyone. :)
    Working with old, dirty, in situ, modular electrical connectors is almost always a "fiddle fest" at times. It does require a bit of skill, a basic understanding of electric circuits, and a general "good with your hands" person to do it efficiently. It is also a different type of skill as it requires someone to be delicate, as opposed to changing a car's oil or something more grossly mechanical.
    But, with perseverance and commitment, I think almost anyone can do it ---- just might take a while.
    FWIW, one could also go to their local salvage yard, pull a harness (with the connectors) off an older German car (Bosch system) and practice pulling / inserting technique on that --- so that mistakes / damage won't be as likely on the "real thing" :).
  20. Kaivball
    Kaivball Three Time F1 World Champ Owner
    Jan 11, 2007
    35,997
    Kalifornia
    I did the gold kit myself about 2.5 years ago.
    Have not had a CEL since.
    I did one to two connectors a night. Took my time, made space in the garage.
    I removed the exhaust and air box assembly. Them decided to refurbish the fuel injectors "while there".
    Getting my engine out done now and will finally do the ECU connectors.
    Took lots of pictures before cutting.
    Measures and loomed thrice before cutting and triple checked the pictures before inserting plugs.
    It can be done by the average Joe. Read the instructions and do some practice connectors. I still destroyed 2 connectors and easily replaced them (one was a 5-pin from VW... :) (Bosch)).
    Worth every penny, IMHO.
    I think I called Dave once.. ;)
    Kai
  21. fatbillybob
    Aug 10, 2002
    29,376
    socal
    I think everyone should read Dave's post #62 again. There are many truths there.
    John, These problems have been going on for decades and only increased in magnitude as the cars got more complex. There are many problems that have been identified and no need to rehash them here. Other makers don't seem to have these problems and when they do the "recall" system seems to fix the problems. Once the Ferrari is out the dealer door you are mostly on your own. SRI is the only company to solve them. Your fixes are the way it should go but not the way it does go on the fleet. Most are ghost busting real codes not quite telling us exactly where the problems are. Unfortunately most real pro shops are still using stabilant-22, electrical contact cleaner, and dielectric grease products and replacing parts on our nickel. Ferraris just suck. They are not wired like a jeep where you can ford water and keep driving. In a 348 you got wet if you drive in a light rain. In A 550 you can't even wash vigorously with a hose for fear of nucking your entire electrical system! I have just about debugged a 2nd 550 with that exact unfortunate scenario.
    Kai and others I strongly strongly recommend everyone do the supremo part of the gold kit which is doing the ECU connector pins. On 550's we get water corrosion in there due to Ferrari engineering prowess. And EVERYONE gets oem female ECU plug pins separating and making poor contact to the male ECU pins. How do you guys like this picture? Today, I have just pulled another pair of 550 ECU's today and the ECU plug pins are spread and taken a "set". This is a real source of "garbage in garbage out" that is eliminated with the gold connector kit.
  22. JSBMD
    JSBMD Formula Junior
    Mar 17, 2007
    454
    The OC
    I bought the kit a couple years ago. I planned to install myself, but after peering into the engine bay, wire cutters in hand, I completely chickened out. I am not a caveman, in fact I am a physician, but still felt overwhelmed when I considered the scope of the task at hand, and the potential damage which could be done.
    In the end, I waited until my engine-out service, and paid my maistro to install the kit for me. It went well, but even he had a learning curve to the installation. He is not keen to do another, last I asked.
    Were I to do it again, I would plan a road trip to Boulder, CO and schedule an in-house install by Dave's crew at SRI. They have done so many that this would probably be a one or two day deal, and I would get a cool road trip out of it, plus the opportunity to meet the Master himself, and to thank him personally for all his dedication to the marque and the solution for many of its inherent flaws. I doubt my own Ferrari tech would feel "cheated on" in that instance.
    Was the kit worth it? I think so. My car ran well before, but with the kit seems to run a lot smoother in the mid-range. Idle is smoother than before. Just passed smog test easily (but had to swap back to stock cats in order to do so--Fabspeeds do not cut it at the test station). No warning lights for a while now.
    So, Ketel, or anyone else contemplating this kit, I say do it. But don't be afraid to ask Dave about a visit for an installation in their shop.
  23. ketel
    ketel Formula 3
    Aug 6, 2007
    1,356
    Sausalito, CA
    So gang, Day two. I decided to throttle back on my expectations and ambitious schedule. I realized after Day One that the notion that I would tackle this endeavor "over the July 4th weekend" was clearly a baked notion. No friggen way. This is a bear and needs to be respected as a bear.
    So, Day 2 was taken at a much more modest pace. First, I had to undo the problems I created from Day one. Mission one was to hunt down a 2-pole female connector to sub in for the air temp connector that I mangled the day earlier. I located one at Napa Auto Parts about 10 miles up the road. Cost? $15. (See photo of mangled connector with terminals askew and new connector.) It came with the harness attached but, now equipped with SOME knowledge from my Gold Kit experience, I quickly dispatched this projected by using Dave's pick tool to pry out the rubber seal, used the FBB2 tool to poke at the terminals and pushed the terminals out from the backside. With fresh connector in hand it was a pretty simple task to remove the gold terminals from the mangled connector and house them in the fresh and new connector. They snapped on effortlessly.
    Next, I tackled another Drivers side O2 sensor. An hour later it was done. I then cleared the faults. Given it was only 2pm I considered what other projects I could reasonably go after, but decided against it. Instead, I took Francesca for a drive and, by golly, she ran soooo much better. No rough idle. No searching. So hesitation on the power. Just smooth.
    But of course, her being a Ferrari, she waited until I was confident I was in the clear before the CEL came back on. Dang it. Even though her behavior improved, I now have 7 CEL faults. Still getting the air temp sensor fault (P0113) like before even though I have a fresh connector plug and triple-checked that the gold terminals were lined up properly. So, I am not done correcting that problem.
    The hunt (and the project) continues. I am bloodied but unbowed. The goal remains as before but now I see this as a long-term goal -- not something that is going to be achieved in a weekend or two. Tomorrow, perhaps two sensors? Either way, this is such an involved, interdependent endeavor that it almost requires that with each step, a step back is taken to assess the improvement (or damage) created and then eliminate or isolate it.
    Final thought: I respect those of you with the perspective or the wallets to just farm this out to a mechanic. Good for you. I am not going to do that. As frustrating as this has been at times, I have already learned a ton about my 355. And with that, a great deal of respect and appreciation for these machines and those who've made it their lifes work to turn wrenches on them. An earlier poster reported about opening his engine bay and chickening out. I know this feeling. I had it about 48 hours ago. But I decided to crap in my pants and jump in the pool. Damn the torpedoes. It's a car. I'm reasonably intelligent. I will make mistakes. Those mistakes will cost me and set me back, but I will overcome them and I will learn a ton in the process. This is partly why I got the 355.
    Tomorrow is a new day. Right bank O2 sensors? You're next.
    ketel
  24. pnicholasen
    pnicholasen Formula 3
    Jan 14, 2011
    1,364
    South of Philly
    Paul Nicholasen
    Glad you're getting the hang of it!! Glad you have a more realistic time frame for completion. I was thrilled when I did my 2nd ECU plug in 90 minutes, and that's with the new plug so no old pin removals, so it's not a one day project.
    Question to Dave Helms: just curious, how long does it take your best tech to do one of these?
    Comments to others considering doing the kit:
    1) If you have a bad back, think twice about doing it with the engine in. You're going to be spending a lot of time bent over with you're head buried in the engine compartment. Get some good fender covers too.
    2) Aside from the crappy plugs and the short length of the wires on the car, I was also disturbed to find a fair amount of wire corrosion inside the insulated wires. If I was trying to strip a wire and the insulation wasn't coming off easily, usually when I finally got it off, the wire would be a nasty black color instead of shiny copper. Not sure if others have found that or not, but it sure can't be optimal for transfer of electrons back there. If there was sufficient wire length, I would keep cutting back wire 'till copper color was found, if not I just cleaned it off with the little wire brushes supplied in the kit, but worried about the crap inside the insulation that had not been stripped. Don't know who supplied the wire for Ferrari at the time, but they should be shot. If I was a metallurgist, I would take a piece of wire and get it analyzed, I'm suspicious there's more pig iron than copper in there. Between the engine harness, the door-to-body connectors, and the climate control computer, the electrical system of the 348 seems to be it's weakest link.
  25. drbob101
    drbob101 F1 Rookie Owner Silver Subscribed
    Nov 26, 2012
    3,821
    Tinton Falls, NJ
    Bob Ferraris
    Delphi supplied the harness on my car. Good 'ole made in the USA
Thread Status:
