Interior restoration / cement | FerrariChat
Discussion in '308/328' started by rolindsay, Jul 15, 2009.
  1. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    #1 rolindsay, Jul 15, 2009
    I will soon be (re)starting my '79 308GTB's interior restoration. The car is in great shape but just needs to be freshened up. Specifically, I would like your advice on which upholstery adhesive you would recommend to re-cement down the edges of the leather and/or vinyl where they are lifting from the fiberglass substrate. The generic stuff I have used in the past just can withstand the heat of a car's interior. Advice? -rick
  2. speedy
    speedy Formula Junior
    Oct 18, 2005
    625
    Plano, TX
    James Gardner
    #2 speedy, Jul 15, 2009
  3. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
  4. Jeff Kennedy
    Jeff Kennedy F1 Veteran
    Oct 16, 2007
    6,582
    Edwardsville, IL
    Jeff Kennedy
    Typical professional glue we use for corporate aircraft is 3M 1357 and 1300L. I think 1357 is for spray while 1300L is for brush application.
    Jeff
  5. Jdubbya
    Jdubbya The $10 Trillion Man
    37,462
    PNW
    I used Weldwood on mine, it's holding up just fine. It was recommended by the upholstery shop that did all my work.
  6. AHudson
    AHudson F1 Rookie
    2,761
    Florida
    Adams Hudson
    I used Weldwood too. Works awesome, and if you sniff it for very long, you can begin to hear and even see the Jethro Tull concert from 1972. Just a side benefit.
  7. pippo
    pippo Formula 3
    Sep 25, 2005
    1,913
    FL
    pippopotemus
    Yup....Welwood. Its a neoprene based cement, and that is the key. Why? Cuz is resists heat better than other types without breaking down. It is the choice also (and related) to restoration of convertible tops too, and if it will withstand a top's heat/uv ray intensity, it will do well interiorly (a word?)
  8. h00kem
    h00kem Guest
    Dec 15, 2004
    734
    Texas
    Weldwood
  9. klatu
    klatu Formula Junior
    Apr 13, 2009
    277
    San Diego
    Rob Mckinney
    Yup Weldwood is good, only I started hearing the Anita Briant concert from 68.
  10. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    #10 rolindsay, Jul 16, 2009
    Reminds me of experiences with "Aircraft Stripper". Emmit Rhodes' "Fresh as a Daisy" comes to mind.
    BTW, while on the theme of noxious chemicals; They sell a variant of Aircraft Stripper that is badged "Low Odor". If you should wonder what they removed to make it low odor, I can tell you. They removed the stuff that strips paint! Low Odor Aircraft Stripper is useless.
  11. Jdubbya
    37,462
    PNW
    I tried to make sure the garage door was open when using the weldwood but it still can leave you feeling pretty good. What was worse was the POR 15 paint I used in the trunk area. Imagine being bent over inside that small space with a brush full of that stuff for awhile!! I kind of floated back into the house!
  12. klatu
    Apr 13, 2009
    277
    San Diego
    Rob Mckinney
    Try orange limonene, it smells like organges and works great.
  13. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,419
    Toronto / SoCal
    Rob C.
    When choosing an adhesive you will likely use something different between the vinyl and the leather portions. In a 308 the ONLY factory leather are the seats and surface of the door skins. Everything else is vinyl. It is important to know this because you need an adhesive that is resistant to 'plasticizers'. These are oils that permeate out of vinyl and is used to make it supple and flexible. Unfortunatly these plasticizers attack most glues that are not specifically designed to work with them. That said I researched and used 3M Spray 80 to great success on my 308 interior. I am not saying that Spray 80 is the only choice however the plasticizer thing is important to ensure a good and lasting adhesion. Good luck with the project
  14. AHudson
    AHudson F1 Rookie
    2,761
    Florida
    Adams Hudson
    I think they used to call that a "bad trip". Hope you're okay!
    That stuff is THE KING of noxiousness (just made that word up. Must be the Weldwood talking!) The POR15 and paints like that are crazy smelly. I'm waiting for the headline, "POR 15 Employees All Claim They've Been to Mars".
  15. chairpilot
    chairpilot Formula 3
    Mar 3, 2007
    1,547
    LA, CA & Olympia, WA
    PlateClipGuys
    John,
    Weldwood makes a few different glues, some for carpentry. Which glue did you use?
  16. Jdubbya
    37,462
    PNW
    I just used the original contact cement. Like I mentioned the upholstery shop recommended this and it is what he uses. He thins it and sprays it but I just rolled or brushed it on right out of the can.
    This stuff here..... http://www.dap.com/product_details.aspx?BrandID=46&SubcatID=8
  17. mustardfj40
    mustardfj40 Formula 3
    Jun 17, 2004
    1,142
    Northen California
    Ken
    I bought a quart of the same glue from Orchard Supply Hardware for $11.50 but haven't used it yet. Do you have to wait 15 minutes before gluing them together?
