430 - Is there a plug and play adapter to upgrade to a aftermarket radio? | FerrariChat
430 Is there a plug and play adapter to upgrade to a aftermarket radio?
Discussion in '360/430' started by Eric C, May 29, 2020.
  1. Eric C
    Eric C F1 World Champ
    Mar 20, 2009
    10,969
    St. Louis, MO
    Eric
    I believe I have the optional hifi option. Looking to upgrade my Becker to a Alpine, but looking for a plug and play adapter. I don’t want to fool around with cutting and splicing wires. Is there one out there?
  2. Eric C
    Mar 20, 2009
    10,969
    St. Louis, MO
    Eric
    This is for my f430 by the way.
  3. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,724
    Just East of Weird
    Bob
    I believe Scuderia Audio sells one but not sure it’s what you are looking for. But they seem to be very helpful.
    https://scuderiaaudio.com/
    Sent from my iPad using Tapatalk Pro
  4. tstuli
    tstuli Formula Junior
    Jun 12, 2018
    379
    NC
    I think something like this should work
    C$ 4.94 | 16Pin Car Stereo Radio Harness ISO for Alpine JVC Radio to ISO Radio Play Plug Auto Adapter Wiring Harness Connector
    https://a.aliexpress.com/_d8s8ATX
  5. hwyman
    hwyman Formula Junior
    Jun 25, 2015
    329
    Canada / Los Angeles
    Discount Car Stereo will make you a harness. Tell them what you're looking for and they'll sort you out.
    mike32 and whatheheck like this.
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,921
    Isle of man- uk
    Anyone know which Alpine radio /CD player models that will actually fit ?
  7. RedNeck
    RedNeck F1 World Champ
    12,040
    The CSA
    Me
    You can make one or have one made. I had to go through and figure out color codes when I first got my car:
    For subwoofer equipped cars:
    +12V constant = Red/white
    +12V switched = Orange/Black
    Illumination=Not used
    GND=black
    + Rear right = Green
    - Rear right = Green/black
    + Front right = Violet
    - Front right = Violet/Black
    + Front left = Brown
    - Front left = Brown/black
    + Rear left = Grey
    - Rear left = Gray/black
    Control output for amplifier = Red
    Volume-Speed control = white/yellow
    For cars NOT equipped with subwoofer:
    GND=black
    - Front right = Grey
    + Front left = Violet/Black
    - Front left = Green
    More info on this thread
    https://www.ferrarichat.com/forum/threads/anyone-have-the-color-codes-for-radio-harness.542706/
    Edit: I didn't see that was for a 430, not a 360, but I would imagine it would be largely the same
    hwyman likes this.
  8. Dean Palmer
    Dean Palmer Formula Junior
    May 21, 2010
    407
    St. Petersburg, FL
    Dean Palmer
  9. kes7u
    kes7u Formula 3
    Oct 18, 2017
    1,210
    Shorewood, MN
    Kevin
    Am I missing something? I'm seeing numerous different colored bare wires. Is this plug and play somehow?
    Kevin
    Sent from my SM-G930P using FerrariChat.com mobile app
  10. tstuli
    Jun 12, 2018
    379
    NC
    Yeah it’s just the standard ISO harness from them. You need to buy their overpriced $35 part and splice it into your harness that comes with your head unit.
    Or you can get the same thing but already spliced into the harness for about $4 from my link :)
  11. Dean Palmer
    May 21, 2010
    407
    St. Petersburg, FL
    Dean Palmer
    Tstuli posted a finished connector, and it will work if all the pin contacts are exact, but our cars don't seem to be mentioned in that listing even thought he Becker stereos are quite common across brands, so just be sure to meter and test, or be sure of the connections before powering up. The price is right for sure.
    The one I posted relies on the buyer to connect the correct wires from car side to stereo side. These adapters require that you simply connect the proper wires between the adapter and the wiring harness of your new stereo. You then have plug and play.
  12. hwyman
    Jun 25, 2015
    329
    As mentioned there is standard DIN connector, you then tell someone like Discount Car stereo what deck your connecting to ie: pioneer, alpine and the pin the other end into a plug that simply plugs into your deck or you can solder the connector that comes with your deck into the DIN harness
