Jalpa thread | Page 26 | FerrariChat
Jalpa thread
Discussion in 'LamborghiniChat.com' started by SVJTech, Nov 12, 2009.
  1. Olivier NAMECHE
    Olivier NAMECHE F1 Veteran
    Aug 18, 2007
    5,099
    CANADA
    Olivier
    in UK at eurospares....
  2. Olivier NAMECHE
    Aug 18, 2007
    5,099
    CANADA
    Olivier
  3. PineChris
    PineChris Formula 3
    Apr 17, 2013
    1,082
    California
    Chris
  4. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,064
    Switzerland
    Raymond S.
  5. Spirit of Italy
    Spirit of Italy Karting
    Jan 3, 2015
    143
    Norway
    Hans S
  6. vyprgt2
    vyprgt2 Karting
    Sep 2, 2005
    186
    CA
    If true, that is super low mileage. No pics of front trunk or engine compartment, but seems clean and correct (except for radio).
  7. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,064
    Switzerland
    Raymond S.
    Visit their homepage, there everything is posted, including vin plates in the engine bay etc.
  8. P300V8
    P300V8 Formula 3
    Mar 8, 2010
    1,645
    London U.K.
    VIN 12189 Price Euro 189k. Can this be a coincidence?
  9. MrOrganic
    MrOrganic Karting
    Jun 28, 2013
    234
    Hermosa Beach,Ca
    R
    Anyone know how to remedy this issue so as not to happen????
    Thanx
    R
    also source for parts or interchangeable parts #'s
  10. Jalpa_Mike
    Jalpa_Mike F1 Rookie
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    #635 Jalpa_Mike, Jul 9, 2015
    Do you have an early Jalpa with the (2) Benditalia/Bonaldi brake boosters, one behind each headlight?
    To my knowledge, the later Jalpa's with the single brake booster never had a lock-up issue, only the early cars.
    Those boosters are from an 60's era Alfa Romeo and I had mine rebuilt by a shop in California.
    Home Page
    You can still purchase the boosters new, but the problem is that the Jalpa uses a metric size brake pipe fitting, whereas some of the boosters utilize a different thread size (see attached photo)
    Alfa Romeo, Fiat and Lancia Brake Boosters and Hoses
  11. MrOrganic
    MrOrganic Karting
    Jun 28, 2013
    234
    Hermosa Beach,Ca
    R
    thanx mike!! its a 84' brakes are just very "hard"
    …..would replacing master cylinder help??? read the stock cylinder sucks
  12. Check your vacuum lines for leaks first. More than likely Mike is correct & you have bad boosters. Replacing the stock master won't solve the problem.
  13. Jalpa_Mike
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    #638 Jalpa_Mike, Jul 9, 2015
    As EarlyCat says, it is more than likely the boosters. One way you'll know for sure, is crack open one of the bleed nipples on a caliper that is locking up and the brakes should immediately release.
    The problem is usually the small spring loaded piston behind the 5-pointed air valve diaphram on the bottom of the booster. It won't realease the pressure and so the brakes think someone is still pressing the pedal.
    Once you take the boosters out of the car and start disassembling them, you'll probably find the diaphrams have failed and brake fluid is getting into the air chamber. Just take a look at what mine looked like!
  14. Jalpa_Mike
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    #639 Jalpa_Mike, Jul 9, 2015
    Here is a good exploded diagram of the booster.
    The parts in question on my car were #10 & #11. The seal had failed and was allowing the poston to jam.
    I decided to send both mine to that place in California. They resleaved it, rebuilt the entire booster with new diaphrams, seals, springs, clips, etc.
    After I reinstalled them, never had a problem again.
  15. MrOrganic
    MrOrganic Karting
    Jun 28, 2013
    234
    Hermosa Beach,Ca
    R
    thanx Cat!
    thanx again mike, which place in cali???
  16. Jalpa_Mike
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    Its called Power Brake Exchange. They have 2 places in California. I can't remember which one I mailed my units too...
    The link is up in my Post #635. For some reason it is just showing as "Home Page", but click on it and it will take you to their website.
  17. MrOrganic
    MrOrganic Karting
    Jun 28, 2013
    234
    Hermosa Beach,Ca
    R
    THANX BRO!!!
  18. MrOrganic
    MrOrganic Karting
    Jun 28, 2013
    234
    Hermosa Beach,Ca
    R
    K&N air filters for Jalpa, make any difference???
    anyone know part # or is there another co. that works better with a 84' Jalpa
    thanx!!
  19. MrOrganic
    MrOrganic Karting
    Jun 28, 2013
    234
    Hermosa Beach,Ca
    R
    Vacuum hose was disconnected from engine for whatever reason (connected it) & we BLED the brake fluid (audi dot4) (brake fluid was dark)
    Brakes now feel good
  20. Jalpa_Mike
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    Yep, for some reason people do that. If not there, they'll also disconnect the vacuum reservoir tank too.
  21. MrOrganic
    MrOrganic Karting
    Jun 28, 2013
    234
    Hermosa Beach,Ca
    R
    thanx!!
  22. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,064
    Switzerland
    Raymond S.
    Lamborghini Jalpa Problems
  23. HOF Ferrari
    HOF Ferrari Formula 3
    2,033
    Canton, Ohio
    AFG
    #649 HOF Ferrari, Aug 2, 2015
  24. HOF Ferrari
    2,033
    Canton, Ohio
    AFG
