Just Lowered F430...NICE! | FerrariChat
Discussion in '360/430' started by eyeman1234, Nov 25, 2017.
  1. eyeman1234
    eyeman1234 Formula 3
    Dec 25, 2006
    1,881
    Boca Raton, FL
    :) My F430 was just lowered from U.S. spec. to about European spec. (about 1/2 inch) with new alignment.
    The handling is so much better...who knew? No problems with bottoming out on my roads.
    808Forza likes this.
  2. BlacktopRacing
    BlacktopRacing Formula Junior
    Sep 18, 2016
    916
    Pittsburgh
    Dale
    A lot of us. Congrats, and welcome to the fun world of questioning whether or not that's a dead animal on the road up ahead or just some leaves.
    Dale
  3. 02360spider
    02360spider Formula 3
    1,730
    Dartmouth
    Richard oliveira
    Wait euro spec is a different height is the same with the 360?
    Sent from my FRD-L14 using Tapatalk
  4. buddyg
    buddyg F1 Veteran
    5,455
    West Michigan
    Buddy
    This thread stinks without pics!
  5. eyeman1234
    Dec 25, 2006
    1,881
    Boca Raton, FL
    I hear you- I'll post pics
  6. Freddan
    Freddan Formula 3
    2,175
    Vansbro (Sweden)
    Fredrik
    still to high :)
    but it looks good anyway ;)
  7. 3POINT8
    3POINT8 F1 Rookie
    4,433
    I think it looks great good work
    eyeman1234 likes this.
  8. bocaf430
    bocaf430 Formula 3
    Jun 10, 2014
    1,361
    LI, boca raton
    looks great.... black also looks good
  9. kreh
    kreh Karting
    Feb 21, 2006
    216
    OC
    Kim Reh
    eyeman1234 and Bcutrupi like this.
  10. Lonnie
    Lonnie Formula Junior
    May 22, 2013
    499
    NY/Delray Beach FL
    Lonnie Mandel
    Looks good I saw it at the shop when I dropped off my 360
  11. eyeman1234
    Dec 25, 2006
    1,881
    Boca Raton, FL
    Lonnie, your Rosso gated 360 is BEAUTIFUL! I had one but yours is a looker- prettier than mine ever was...
    Lonnie likes this.
  12. Lonnie
    May 22, 2013
    499
    NY/Delray Beach FL
    Lonnie Mandel
    Thanks it's in great shape with some very special options.... I will probably get buried in it...lol
  13. djempire
    djempire Formula Junior
    Apr 30, 2012
    613
    Toronto
    Serf
    Is there a good DIY process in lowering the F430? On my P car I measure all 4 corners and then proceed. Is there a different method for the 430?
  14. BlacktopRacing
    Sep 18, 2016
    916
    Pittsburgh
    Dale
    It is a good idea to set the alignment at the normal, or high, ride height because lowering will increase negative camber, which is what you'd want for performance driving. This makes it possible to raise and lower your car yourself, based on need, without having to reset the alignment every time. For example, for normal driving, you only want minimal negative camber to maintain streetability, and then lower the car .75 inches and pull in more negative camber for performance.driving . This is just an example, but if you minimize the negative camber on the high side, then lowering it would improve the desired camber settings when needed. If you want to ride around all the time in a low setting, just for appearance, then you will want to set the alignment in that setting. Set it and forget it.
  15. Palladin
    Palladin Rookie
    Sep 25, 2015
    6
    Vancouver, Canada
    Jack
    This might sound like a dumb question, but can you lower it yourself easily without an alignment shop?
  16. Speedspeed
    Speedspeed Karting
    Jul 15, 2017
    71
    Fl Keys
    charles
    Looks great lowered !!!!
  17. eyeman1234
    Dec 25, 2006
    1,881
    Boca Raton, FL
    Correction: It was lowered 3/4 inch
  18. eyeman1234
    Dec 25, 2006
    1,881
    Boca Raton, FL
    They were removed and adjusted 3/4 inch
  19. fc2
    fc2 F1 Veteran
    Nov 2, 2006
    5,263
    Silicon Valley Ca.
    Frank C.
    I don't know where you guys drive, but my stock ride-height 16M hits in a number of spots around our house. We do live in the hills over Silicon Valley and there are "chin slappers" all over the place. There are areas where I need to slow to 5MPH or suffer the sound of my front end slapping the road. If I lowered my car even a pinch, I fear I'd find all sorts of new places where my car hits.
  20. Zed82
    Zed82 Formula Junior
    Sep 28, 2017
    490
    Sweden
    I was just getting a quote to raise my F430. It´s a pain to drive when lowered.
  21. ttforcefed
    ttforcefed F1 World Champ
    18,876
    i did this on an oem suspension. i left thinking it looked great and a month later i brought it back to be raised. it was sloppy and scraping everywhere. Yes i had an alignment done by P1 in stamford and it didn't matter. I dont believe the euro cars and US cars have the same suspension parts. something is different.
  22. Zed82
    Sep 28, 2017
    490
    Sweden
    How many hours did it take to raise it again? My shop is telling me the alignment is £350 because they have to adjust all kinds of settings. Then they also need approx. 6-8 hours to just raise it.
  23. ttforcefed
    18,876
    unfort i have no idea.
  24. Zed82
    Sep 28, 2017
    490
    Sweden
    Did you have a shop to do it? How much was it?
