News
Kevlar Clutch
Discussion in '360/430' started by Oengus, May 28, 2009.
  1. Oengus
    Oengus F1 Veteran
    8,404
    Between timing belts or OH, SC, CO, CT
    Chas
    I just had a Kevlar clutch put on my 360..........I dont know how to explain it but it feels amazing. I guess more solid would be a good word, Im very happy with it and the way it feels pedal to foot.
  3. duskybird
    duskybird F1 World Champ
    Rossa Subscribed Owner
    Jan 20, 2007
    10,673
    29 Electoral Votes
    Bill B.
    Where did you get the disc?
  4. brokenarrow
    brokenarrow F1 Rookie
    Sep 25, 2006
    3,646
    Txass
    Bill
    #3 brokenarrow, May 28, 2009
    Really? Okay, let's kick-off the questions:
    1. Where did you get it?
    2. How much?
    3. Expected life?
    4. Any modifications required or parts?
    5. Is it a custom clutch?
    6. Is it a set with pressure plate and disc?
    7. Can you use your flywheel?
  5. Oengus
    Oengus F1 Veteran
    8,404
    Chas
    NJB in Columbus Ohio did it for me.
    They had it sent out.......
  6. Oengus
    Oengus F1 Veteran
    8,404
    Chas
    1. NJB in Columbus Ohio
    2. $3700
    3. I got 50k miles out of my factory clutch.........so I would expect that for sure. (6 speed manual)
    4. No
    5. No just has a Kevlar overlay as far as I understand
    6.
    7. Yes
  8. brokenarrow
    Sep 25, 2006
    3,646
    Txass
    Bill
    Wow. Got any pic of the parts?
  9. Oengus
    Oengus F1 Veteran
    8,404
    Chas
    Sorry Bill I dont
    Ill check with NJB and let you know.
  10. Oengus
    Oengus F1 Veteran
    8,404
    Chas
    I was told that it should be 2x to 3x longer than standard life but obviously driving habits are a BIG factor. They resurface disc and flywheel and add new o-rings and seals and replace throw out bearing if required.
    Having said that I did get 50k + out of my original clutch...........so Im certainly not going to expect 100k + out of it ;) ;)
  11. zippyslug31
    zippyslug31 Formula 3
    Sep 28, 2007
    2,072
    PDX
    Kevin M.
    #9 zippyslug31, May 28, 2009
    Cool, glad somebody was able to get this done.
    Last year I had my clutch redone (after 28k, manual trans) and when I inquired with both an f-car dealer and a local lambo dealer (who services f-cars) they both acted like I was insane. Really blew me away with their reaction so I just went with factory stuff.
    Figured if the stock stuff lasts me another 28k I'll be happy.
  13. MalibuGuy
    MalibuGuy F1 Veteran
    Sep 18, 2007
    5,061
    Since the factory clutch gave you 50K miles, what are the expected advantages of the Kevlar clutch?
    I don't know how accurate it is to compare the old worn out clutch to the new one in terms of grip and action. A new factory clutch would probably feel better too, especially after resurfacing the flywheel and replacing seals, etc.
    Where did you get the info about the kevlar alternative?
    Sounds interesting.
  14. enzo thecat
    enzo thecat F1 Rookie
    Jan 27, 2008
    3,609
    Midwest
    Enzo Thecat
    They did the same for my 355 Spider. Its funny, I paid to have the car sent to Oh to NJB, then they pull out my clutch and send it BACK to my home town to get the kevlar coating. No wonder these cars are expensive! But what a difference and I loved the tight crisp feel of my clutch.
  15. Oengus
    Oengus F1 Veteran
    8,404
    Chas
    NJB just outside of Columbus Ohio
    The advantage for me was under 4k compared to........?
    They are great guys and do all of my service work........I would recommend them to anybody:)
  16. Oengus
    Oengus F1 Veteran
    8,404
    Chas
    Too funny. It does feel tight and crisp.........
  17. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,008
    Northern California
    Greg Calo
    There are two firms I know of that do Kevlar clutches:
    http://www.clutchmasters.com/ in Rialto, CA
    http://www.hrclutch.com/ in Bensalem, PA
    Both do a great job. They will resurface the flywheel, resurface the pressure plate and rebuild w/newer and slightly stronger springs, and resurface the clutch disc with Kevlar for under $800.00 for all three.
    Hill T/O bearing strongly recommended.
    Both have experience with 360 clutches.
  18. netman
    netman Formula 3
    1,883
    OC SoCal
    Can kevlar be used with F1 trans?
  19. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,008
    Northern California
    Greg Calo
    Sure can.
    Have a few acquaintances who have done it and are very pleased.
  20. masar
    masar Formula 3
    Aug 19, 2007
    1,355
    Czech republic
    Petr
    Not sure if kevlar is different from ceramic but i just did clutch change on my Lambo 3 weeks ago. Went for ceramic clutch from Rennsport. Replaced just clutch disc because the rest was fine (car has only 3500 miles) and it cost me 250 usd. Clutch feels great and i hope it will stay much longer than the ****ty Lambo factory one.
  21. ferrarilou
    ferrarilou Formula Junior
    Apr 13, 2004
    513
    US
    Lou Menditto
    In my view, the jury is still out on use of kevlar for F1. I tried a kevlar clutch in my 360 F1 figuring it was a reasonable experiment. Since I own my cars a long time and drive them allot, the benefits of extended clutch life were something I'd get to enjoy directly if it worked. Was great for the first 300 miles. I was thrilled. Then, very strangely, it started slipping on acceleration in 4th gear, sometimes 5th and 6th, for example when I would poke the gas pedal to zip past someone. Sometimes it slipped for no explainable reason. Called HR, they said that we should have gone with ceramic on one side and kevlar on the other because the kevlar overheats quickly. I believe the suggestion was that the ceramic be on the pressure plate side, but I haven't done this yet and so I can't swear to it. Anyway, I'm still torn between trying another experiment or just going back to OEM. There is one mitigating issue that keeps me from completely blaming the kevlar - it is that the shop has noticed that my clutch position sensor is intermittently blipping an erratic reading. When I get the clutch replaced I'll be getting a new sensor as well.
    I know another 360 F1 owner who tried the same kevlar clutch. His failed differently - apparently slipped right from the start and never felt really right. He has recently gone to ceramic and kevlar. Spoke to him a few days ago and we're waiting for him to put a mountain trip on it to see how it holds up.
    Lou
  22. Skidkid
    Skidkid F1 Veteran
    Aug 25, 2005
    6,662
    Campbell, CA
    John Zornes
    Please keep us updated Lou. I will be in for a clutch pretty soon.
