Latest pictures of MM Enzo | Page 10 | FerrariChat
Discussion in '288GTO/F40/F50/Enzo/LaFerrari/F80' started by S Brake, Jan 17, 2009.
  1. toddjw73
    toddjw73 F1 Rookie
    Feb 5, 2004
    3,506
    Nor-Cal
    Todd Westbrook
    I'm getting antsy now! If it ends up at Bonneville, I will drive out for sure to see it.
  2. Napolis
    Napolis Three Time F1 World Champ Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Rock On!
  3. TexasMike
    TexasMike F1 World Champ
    Feb 17, 2005
    10,485
    Austin, Texas
    Michael C
    Thanks for the update!
  4. Napolis
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Here's how we did it in P 4/5.
  5. EnJi
    EnJi Karting
    Dec 12, 2007
    92
    The Netherlands
    Well, make it Predje
  6. Bill S
    Bill S Formula 3
    Oct 2, 2004
    1,995
    That's a very clean integration.
    What about shear strength? That is, the bolts tearing through the carbon fiber in a side impact. I suspect a steel plate would be embedded in the carbon to help that.
  7. Simon^2
    Simon^2 F1 World Champ
    Oct 17, 2005
    12,313
    At Sea Level
    Hmmm... a 300mph doorslamber at Bonneville?
  8. Napolis
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    It's plated on the bottom and glued and sandwiched as well as through bolted.
    The bars that attach to the rear suspension are plated and bolted to the rear roll hoop as well which ties it all together. Even though the diameter of those tube seems smaller than what the MM Enzo uses it's built from a very high strength alloy and if P 4/5 is dropped on it's roof it deflects less than .5 of an inch.
    Best
  9. CMY
    CMY F1 World Champ
    Oct 15, 2004
    10,142
    Redondo Beach, CA
    Chris
    I had no idea that was there.. I think I would have to nominate that for the slickest cage install I've ever seen, it's just too bad you don't have a removable panel to show it off. ;)
  10. mattymouse33
    mattymouse33 F1 Rookie
    Oct 25, 2004
    4,634
    We'll set aboot ye!
    Matthew
    Hmm, great thread. keep us posted
  11. Napolis
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    Do you have a lot of work left to do?
    When should this be ready for testing?
  12. lilturbododge
    lilturbododge Karting
    Jul 7, 2008
    152
    SC
    Justin
    Why can't ever live near areas where this happens. I would work for free :)
  13. NWaterfall
    NWaterfall Formula Junior
    Aug 2, 2009
    564
    The Track
    Waterfall
    I do! And I will! Tjs1 if you ever need any help with anything, pm me!
  14. rossocorsa13
    rossocorsa13 F1 Rookie
    Jun 10, 2006
    2,557
    Nashville, Tennessee
    M
    Off topic, but wanted to ask:
    Jim, why wasn't this included in the original structure? Is it simply not necessary for normal crash regulations, or did your custom cabin design necessitate stronger roll-resistance? It just seems like a pretty simple, common-sense part of a hi-performance car.
    Cool picture nonetheless.
    And keep the updates on MMENZO's rebuild coming, please!!
  15. Napolis
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    By original structure I assume the Enzo. Not required and VERY expensive to fabricate in the alloy we used which is thin enough to fit within the structure. Beryllium is also very toxic when welded or machined, (Not when that's finished) and very few are able to fabricate it safety.
    http://www.osha.gov/SLTC/beryllium/index.html
    "beryllium is a critical component of many military and aerospace applications, and though it is expensive to produce, costing more than silver, it is not often replaced by other materials."
  16. Latsyrc
    Latsyrc F1 Rookie
    Jun 23, 2008
    2,798
    Utah, USA
    Travis
    Hehe.
    I may have to make a trip down next Monday if you will be there. :) Thanks for the updates and good to hear from you. It looks like it's going well!
  17. mattymouse33
    Oct 25, 2004
    4,634
    We'll set aboot ye!
    Matthew
    Crikey that sounds the business.
    Jim, I imagine you've been asked this already but do you think the 458 is in any way influenced by your car?
    To me it is, just having a quick look at the two tone 458 pictures i saw, Ferrari have clearly introduced beauty back into their cars as a matter of priority. Obviously i dont know what Im talking about but short and sweet, my opinion is that your car and the 458 have 'the look' of a supercar and ooze beauty, something that has been missing since the F50. Each to their own though :)
    regards,
    Matthew
  18. bgck13
    bgck13 Formula Junior
    Feb 7, 2007
    304
    Somewhere
    learn something new everyday
  19. bgck13
    Feb 7, 2007
    304
    Somewhere
    While this wasn't addressed to me I agree. And do think it was influenced by it. With that said I am still hoping for a modern day Testarossa. MSRP $350k without options...low 4's fully equiped. Something more exotic and supercar looking to slot in between the 599 and the actual super ferrari (F40, F50, Enzo).
  20. Napolis
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    I also think P 4/5 did influence the 458.
    Best
  21. Napolis
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    The main problems we found with the Enzo in the wind tunnel was too much inlet and not enough outlet. Because of outlet restrictions the inlet air actually backed up and created drag.
    Another issue was unbalanced downforce. It will be very interesting to see how your CAD program sees it vs what we saw.
    IMO an issue you have to address is getting more tire especially with your HP increase. I'd pay a lot of attention to this.
    Please keep us up!
  22. bgck13
    Feb 7, 2007
    304
    Somewhere
    Bugatti has a 365mm rear tire. I am guessing the stock enzo is 335 or 345. That wouldn't be a bad start.
  23. EnJi
    EnJi Karting
    Dec 12, 2007
    92
    The Netherlands
    If I may ask, what do you two petrol heads mean with 'non-balance in the car'?
    My knowledge of aerodynamics is just enough to understand the importants of it. And that small changes to the shape of a car can have a huge effect on the handling at high speed or low speed for that matter.
    Do you mean it is very unstable and lacks proper grip at a range of specific speeds? Is the Enzo perhaps not realy thought through enough? Or is it like form above function (a proper aero-package) instead of the other way around, like most people would expect with the Enzo.
    I might blow this whole thing up way bigger then it actually is, but I remember that people where saying the Murciélago was instable as well. One guy even has a website claiming the car is dangerous. He crashed his car and tells all about it: http://www.lambounfall.de/indexe.html
    If you think even further, it might even explain some accidents, perhaps... Maybe more supercars are not all that aero-ballanced out so not to harm the design.
    Just my 2cents.
  24. Napolis
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    There are several issues here. An imbalance between inlet and outlet into the engine compartment for example can cause aerodynamic drag and poor engine cooling but in most cases will not unsettle the car.
    An imbalance between front and rear downforce can cause real handling issues.
    Here's a good discussion of some of these issues:
    http://ferrarichat.com/forum/showthread.php?t=232922
  25. 3M7M5
    3M7M5 Karting
    Sep 26, 2004
    183
    Not the best pics, but a few taken in 2004 at the Monterey Historics (Laguna Seca). If my memory serves me correctly, Losee was doing a few laps in support of the Make-A-Wish Foundation.
    Back then I was thrilled to see the very same Enzo I had read about in July 2003's R&T. Little did I know that it would become even more famous with the chop and second R&T article, the tragic accident, and now the rebuild/TT.
    So happy to see its peaks and valleys didn't end in a valley. My best to Richard.
