Left rear squeak | FerrariChat
Left rear squeak
Discussion in '348/355' started by LmnsBlu355, Mar 18, 2010.
  1. LmnsBlu355
    LmnsBlu355 Formula Junior
    Dec 28, 2009
    284
    NY
    Jordan S.
    Drove my "new" 355 today for the first time with the top down. When I hit small bumps or undulations, I hear a squeak. Sounds like its just behind the drivers seat. Opened the door while driving slowly on bumps but the noise is still there. I think it made the same squeak with top up. So I don't think its the top or the door.
    Anyone have any suggestions on where to start looking? Any simple way to diagnose?
  2. f1karting
    f1karting Karting
    Jul 19, 2006
    235
    BC Canada
    Jan H
    I had a squeek as well .. but mine was a mouse living in the car ;)
  3. PAP 348
    Dec 10, 2005
    100,215
    Mount Isa, Australia
    Pap
    Congrats on the new 355 Jordan! :D:D
    No simple way to diagnose noises like that mate. :D:D
    Just have to keep trying to find it. Noise, like electrical gremlins are the hardest form of diagnosing when working on any piece of machinery. :D:D
    Good luck, hopefully you find it without giving you too much stress. :D:D
  4. mike_747
    mike_747 Formula Junior
    Dec 15, 2008
    794
    Seattle
    I had and still have to some extent the squeek you are talking about. In my case it is like a bird chirp.
    For me it was dried out and shrinkun rubber bushings/washers that are used to mount the radiator. Over time these shrink a little, so especially when the car is cold there is a small amount of movement between the rad and it's mounting points - hence the squeek. Once warm and things expand a little this squeek is not as loud.
    I had my fasteners tighten and this helped a little. Eventually I'll just have them all replaced, left and right.
  5. J. Salmon
    J. Salmon F1 Rookie
    4,367
    VA
    This is probably obvious, but if the seat back is touching the firewall, it will squeak.
  6. Dutchman
    Dutchman F1 Veteran
    Dec 4, 2002
    6,184
    EU
    Ton
    Especially when you drive over speedbumps. :)
  7. LmnsBlu355
    Dec 28, 2009
    284
    NY
    Jordan S.
    Thanks for the info. I'll check this first.
  8. LmnsBlu355
    Dec 28, 2009
    284
    NY
    Jordan S.
    Nope. Not the problem. 5' 8" with plenty of room btwn the seat and firewall. :D
  9. Vegas-Guy
    Vegas-Guy Formula 3
    Nov 25, 2007
    1,828
    Austin, TX
    Reg
    Can't help with the squeek but congrats on the new car...:)
  10. LmnsBlu355
    Dec 28, 2009
    284
    NY
    Jordan S.
    Thanks.
  11. LmnsBlu355
    Dec 28, 2009
    284
    NY
    Jordan S.
    Just an update. The squeek is gone :)
    I had a leak at the clutch cover. I ended up changing triple seals, TO bearing, re-greased the flywheel and changed the rt inner Cv boot. To do this, I removed the rear bumper, muffler, exhaust bypass pipe and valve and rt catalytic converter.
    After re-assembly, a Bonus. No more squeek. Im guessing it was coming from part of the exhaust system. :) :)
  12. PAP 348
    Dec 10, 2005
    100,215
    Pap
    Good to hear brother! :D:D
  13. AceMaster
    Feb 6, 2009
    34,776
    Ontario, Canada
    Excellent
