Lip above Bumper on a 348 | FerrariChat
Discussion in 'Technical Q&A' started by 92verdescuro348ts, Jan 11, 2004.
  1. 92verdescuro348ts
    Dec 14, 2003
    54
    Seattle Washington
    Carlo
    Has anyone out there removed this part before? I have removed the six screws that I can see, but it appears that there are two points on the left and rigt side that are still not allowing for me to remove it. Any ideas, one was that there might be a Tac weld on the outer points.
  2. 92verdescuro348ts
    Dec 14, 2003
    54
    Seattle Washington
    Carlo
    I want to get this back on the front page, I know someone out there has removed this part. Anyone out there???
  3. azfast1
    azfast1 Karting
    Jan 10, 2004
    208
    You are correct, it is tack welded on both sides during assembly to keep it aligned. The best way to cut the welds are with a thin chisel if you are not removing the fenders. Good luck
