Look what I got | Page 4 | FerrariChat
Look what I got
Discussion in '348/355' started by angelis, Oct 9, 2009.
  1. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    Will probably keep them. They'll join my 348 seats, rads and other bits I have in storage.
    50/50 as to wether I'll actually put the centre lock wheels. Still haven't found out teh price of tyres.
    Anyone know what size tyres the centre locks would need?
    8.5 x 18 front
    11 x 18 rear
  2. PAP 348
    Dec 10, 2005
    100,249
    Mount Isa, Australia
    Pap
    Nice, id keep them too! :D:D
  3. jmillard308
    jmillard308 F1 Veteran
    May 29, 2003
    6,691
    Perth West Oz
    John Millard
    Sy
    If you look at the Hoosier DOT Radial site -
    https://www.hoosiertire.com/specrr.htm#SPORTS CAR DOT RADIAL
    They provide sizing options for a variety of rim widths - applicable to all tyres.
    *Note the comment about recommended widths*
    Regards
    JM
  4. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    Thanks John.
    Will check it out.
  5. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    You will want to run Pin Drive for these wheels albeit you might be able to modify to suit.
    I have a couple of F40 corners I was thinking of experimenting with had I gone that route. There are enough old CanAm early 70's era spares that pop up that you should be able to find a cheap workable solution that will certify in crack testing and wont break the bank. Some of those were designed for 24" wide slicks creating far more load than your car will ever generate.
    Monday I will try test fitting the pin drive hub I have to a Lola, McLaren and Lotus F5000 wheels I have on the wheel rack and see if they ran the same pin spread and shaft diameter....sure look the same from memory.
  6. fatbillybob
    Aug 10, 2002
    29,380
    socal
    I am so happy to be instrumental in helping you spend your money! I think you and Dave will have the hottest 348's on either side of the pond.
    Now if you get a wing please get a decent one. These wings work!
    http://www.aprperformance.com/index.php?option=com_content&task=view&id=33&Itemid=44
    And here is the CFD data for the wing:
    http://www.aprperformance.com/index.php?option=com_content&task=view&id=181#5
  7. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    I can honestly say... i have no idea what that means. :D
    What's a Pin Drive?
    We're going to see if Testarossa hubs will work. Worse case scenario, I'll make a table out of them.
    You won't be so happy when my wife finds out it was your idea and comes looking for you!!! :D
    You forgot Andy's 348. ;)
    Saw it on a Honda... it's just too "in your face" for me. It's more looks than performance for me to be honest.
    Been thinking about manifolds lately. Called up to see how much Tubi manifolds cost, but they are mega money here in the UK. Nearly the price of the Le Mans engine itself. :(
    Have got all the bits and will be posting them off to Simpsons. Going to drop by there week after next to have a good luck and meet the guys.
  8. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    #83 davehelms, Oct 18, 2009
    Do some research on the F40 hubs. The LM wheels are driven not by splines like the TR or a 250/330 with Boranni wheels, but by 5 sleeved pins extending from the seating face of the hub that go into matching holes in the backside of the wheel. It is these pins that transfer the torque of the engine and braking forces to the wheel.
    Some of the CanAm era wheels had an inner taper that the wheel seated on to center it and some had the shaft matched to the wheel opening and relyed on the nut to center the wheel and the pins to drive it. On the LM wheels the centerlock nut was a male taper that seated in a female recess in the wheel (Bruce always gets worked up with this M / F thing...rest assured he will chime in now as he was involved in the Panzer version of this). On the TR centerlock nut (actually a bolt)...it clamps on the outside of the wheel...the wheel is the male and the bolt the female.
    Using the TR setup for this will require a great deal of machining before its useable. I will take a few photos of a pin drive and post them.
    Dave
  9. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    #84 davehelms, Oct 18, 2009
  10. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    #85 davehelms, Oct 18, 2009
    English (Cooper) 'King Cobra' variant I have hanging on the wall waiting for me to have a life and restore.
    I believe you will find many spares of this nature in your area and using them will save a great deal of headache. Think Ferrari parts are expensive? Wait until you start throwing aound the names Lola and McLaren and you will go water-tight....I have found this to be a very real medical condition working on these!
  11. ferrari 512 tr
    ferrari 512 tr F1 Rookie
    Nov 16, 2008
    4,181
    Australia
    Paolo
    wow interesting
  12. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Really what's interesting is the device they made up to tighten a winged knock off when its set inside a 23" wide wheel and you can not get a swing at it with a hammer! A design surely inspired by what ever they were smoking at the time it was thought up...better living through chemistry I thought. Took me 6 months of looking at it in the 20 boxes of spares before I understood what its function was. Brilliant and they didnt waste any time machining up a hex nut when using the wide wheels.
  13. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    Are u saying moonshine guys have big nuts?????????????
    These pics should get you banned...
    First pic looks like nipples...were u tryin to get that cow utter look?? If sooo u succeeded
    That BBS wheel in green makes me wanta puke!!!!!!!!!!!!!!
  14. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    #89 bcwawright, Oct 18, 2009
    ASSSSSSSS SOOOOOO!!!! The panzer version was the best ever. We worked on this setup for many years.
    Front hubs were aluminum w/titanium drive pins,,,hub carrier was magnesium...one corner cost more than a 348..lol
    Rear hubs were cad plated steel w/titanium drive pins in an aluminum hub carrier.
    You will develope a hate for center locks when you have to carry the torque wrench around....mine had a 6' extension bar which I had to put all my weight on to get it to proper torque spec.
    And you'll really hate them when you are leading a 24hr race at the 22hr mark and the car comes in for a tire change and one of the nuts seize on the hub....happened more than once.
    ShineKen likes this.
  15. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    Panzer trash...didnt have any money left over for coolant after the hubs were made!
  16. bcwawright
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    yada yada yada......air was much cheaper, plus when the car made a pit stop I didn't have to waste precious time topping off the coolant tank. Ooops, forgot about the time we ran coolant to the brake rotors..lol
  17. davehelms
    davehelms F1 Rookie
    Jan 3, 2004
    4,629
    Dave Helms
    That would be an UDDER with teats (only 4 mind you) you peanut farmer...dang!
  18. zgato1
    zgato1 Rookie
    May 13, 2008
    6
    Hey Guys, Has anyone been in contact/had dealings with GaRedCars/SL comp in Atlanta the last few months? I've been calling/emailing them last few weeks with no luck. Thanks, Jim
  19. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    Thanks for all teh info regarding the wheels.
    Having had a long think about it, I've decided not to put them on. Will probably end up selling them now.
    As for the engine, should be all ready and delivered to me early next week. Thenn we start playing around with the electronics.
  20. ghardt
    ghardt Formula 3
    Apr 18, 2004
    1,260
    Texas
    Jerry
    Same problem. No communication (phone or email). Are they gone? Out of business? In jail? Long vacation?
  21. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,275
    MA
  22. Ricambi America
    Sponsor Owner
    Do you mean for these wheels? Sy had them shipped to me in North Carolina:
    http://www.ferrarichat.com/forum/showthread.php?t=263108
    You'd have to PM him about them... but I think they are for sale. I'm just holding them for him.
  23. AceMaster
    Feb 6, 2009
    34,793
    Ontario, Canada
  24. ztunelover
    ztunelover Formula Junior
    Oct 1, 2009
    641
    Calgary, AB
    Krish
    Have you considered f40 halfshafts, and hubs, I mean thats what the lemans 348s used so that would definitely work for you shouldnt it?
  25. angelis
    angelis F1 Veteran
    Jun 18, 2004
    6,401
    London, England
    Sy
    Lots of $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$ :(
