looking to get a 4 post lift HAVE QUESTION? | FerrariChat
Discussion in 'Boxers/TR/M' started by blkdiablo33, Apr 23, 2020.
  1. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,366
    do you guys bolt the lift to the ground or free standing lift company rec no need to bolt down?thanks
  2. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    Get a two post lift :)
  3. ago car nut
    ago car nut F1 Veteran
    5,267
    Madison Ohio
    David A.
    Do you want it to park a car for space, or serious work? For serious work 2 post gives complete access!
    turbo-joe likes this.
  4. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    And leaves you with space below to park another car.
  5. boxerman
    boxerman F1 World Champ
    18,830
    FL
    Sean
    4 post no need to bolt to the floor.
    For work 2 post has its beneifits in terms of wheels off easy, but then spring a car on a two post with wheels hanging is not good.
    In a 4 post you can get a built in rail jack that gets 2 or 4 wheels off the surface.
  6. Cobraownr
    Cobraownr Formula Junior
    931
    Edgewater, MD
    Donald Silawsky
    I have a free standing (not bolted to the floor) 4-post lift. There were no problems with a car on top from a 5.8 earthquake in August 2011. By sheer coincidence, I was standing at the rear of the lift when the earthquake hit. No drama. Get the widest, tallest lift that will fit. In a contest between your head and the lift, the lift will always win. Same for outside mirrors on your car and the lift side columns. The jack bridge is a good idea.
    blkdiablo33 likes this.
  7. blkdiablo33
    Jul 12, 2004
    4,366
    just for space
  8. ago car nut
    5,267
    Madison Ohio
    David A.
    Maybe then a 4 post is best for you.
    Manda racing and fridolin_pt like this.
  9. Manda racing
    Manda racing Formula 3
    Feb 25, 2015
    1,247
    Bakersfield, Ca
    Mark
    Image Unavailable, Please Login I don’t care for my mid-lift — wish I had the type where arms on outside posts and I can swing them under the car. Not lay on my back and try to pry heavy arms up with my finger tips after lining up planks of wood for height.
  10. EZORED
    EZORED Formula 3
    1,018
    Scottsdale, AZ
    Dennis
    #10 EZORED, Apr 23, 2020
  11. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,159
    Canada
    Newman
    I don't bolt mine down and they come with wheels you attach so they can be moved around as required. My neighbour moves his forward every summer to park his snowmobiles behind his cars and moves the hoist back in the winter when the cars are stored.
  12. ago car nut
    5,267
    Madison Ohio
    David A.
    My two post lift has to be bolted down.
  13. tstuli
    tstuli Formula Junior
    Jun 12, 2018
    374
    NC
    Found mine seemed much studier once bolted down. Felt better that way.
    Also without it bolted down, the lift tends to “walk” a bit and cars are driven on and off it.
    turbo-joe and blkdiablo33 like this.
  14. Newman
    Dec 26, 2001
    14,159
    Canada
    Newman
    Of course.
    He was asking about a 4 post though which does not have to be.
  15. teveo
    teveo Formula Junior
    Oct 1, 2005
    403
    Norway
    Trond Vidar
    The 2 posts is the professionals choice, give access to any area of the car but I dont like lifting older cars on those lifts. If you have the concrete base and have it professionally installed and plan to work on newer cars it may be the best choice.
    Myself I have a 4 post and prefer it due to the age of my "collection" of older vehicles (1956-1986). I hate lifting older cars on a 2 post lift and especially the Porsche 356 or E-type they just dont have lifting points. Do also get a rolling bridge jack and you will be able to do almost every job on that 4 post lift.
    Pending what work you wanna do; having lifted a series of cars on the QuickJack I would say it is one of the better options if you want flexibility. Just pack and stash the lift as you may and use it wherever you find a flat spot. Superb for engine and suspension/wheel work.
    Sorry, your question was about bolting so here it go: "No I do not bolt it down make sure your lift support free standing though, mine do". :)
  16. sixcarbs
    sixcarbs F1 Veteran
    9,109
    SF
    I always thought having a pit would be a cool and safe way to go, but doesn't really help if you have to drop an engine form the bottom, and does nothing for extra parking.
    http://www.premierpits.com/gallery/
  17. Newman
    Dec 26, 2001
    14,159
    Canada
    Newman
    Bear in mind that the shop floor has to have the right concrete pad under it for a two post to mount to and not have the fasteners pull out or break the floor. No matter how you lift a vehicle the weight will be biased front or rear. The hoist will constantly be trying to tip so whatever it's fastened to better be good. Typical house garage pads are not thick enough so that's something to consider. Some 2 post lifts have long extended mounting legs which can stop that (but you can trip over them) and others have a small plate as a base.
    xplodee likes this.
  18. ago car nut
    5,267
    Madison Ohio
    David A.
    I use a safety tall screw jackstand when car is on two post lift.
  19. Newman
    Dec 26, 2001
    14,159
    Canada
    Newman
    good idea. Doesnt do any good when you’re raising or lowering a car though.
  20. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    Smart- where do you position it?
    Is there really an issue on the suspension leaving a TR on a two post lift for a 4month winter or is this a bit overblown?
  21. ago car nut
    5,267
    Madison Ohio
    David A.
    Under the frame front and back.
    xplodee likes this.
