355 - Loud Rattle from Clutch Area | Page 3 | FerrariChat
355 Loud Rattle from Clutch Area
Discussion in '348/355' started by Qavion, Oct 27, 2021.
  1. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,682
    San Carlos, CA
    Mitchell Le
    If they did not charge you for "rebuilding the Voith damper" then the grease was not replaced.
    MAD828 likes this.
  2. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,639
    Elliott Caras
    No chance the Voith was overhauled Ian. I have done this job 4 times now and there aren’t many ‘techs’ who venture into the Voith especially in Australia. Just spoke recently with a Ferrari trained tech of 11 years has never opened one.
  3. MAD828
    MAD828 F1 Rookie
    Oct 8, 2011
    2,639
    Elliott Caras
    Also if it’s not leaking evidently does not mean a past leak hasn’t been rectified and then the old contaminated Voith put back into action. The last Voith I re did was part of a triple seal leak repair. I wasn’t going to do the Voith but upon opening it up for inspection the grease inside was badly contaminated with gear oil and stunk like it too. So was worth the extra effort to rectify.
  4. Tarek307
    Tarek307 Formula 3
    1,349
    Long Beach, CA & Alexandria,Egypt.
    Tarek Salah
    any update on this?
  5. Qavion
    Qavion F1 World Champ
    14,595
    Ian Riddell
    Nope.. maybe next month... :rolleyes:
  6. Qavion
    14,595
    Ian Riddell
    Next, next, next month.... Small update. My tech doesn't think the rattle is due to a bearing fault. He thinks a slightly rough idle is contributing to an imbalance (hence the rattle). He found the cat temperature higher on the left bank (395C vs 297C) and subsequently found cylinder #7 spark plug looking a little black.
    The leads and coil pack seem ok, so he's going to test the fuel injectors on that bank later today.
  7. 26street
    26street Formula Junior
    Jan 30, 2021
    473
    Westchester New York
    Mark k
    This is a real hunt for you guys hope you find it I’m sure you will share too
    Qavion likes this.
  8. Qavion
    14,595
    Ian Riddell
    Update: Well, believe it or not, the rattle has gone with the replacement of 8 spark plugs and a new OEM fuel injector. Very happy, even though I bought lots of expensive parts that I didn't need.
    Thanks for the input!
    Tarek307, Mark HT and 308 GTB like this.
  9. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    That's great to hear, Ian. I can't understand that sonic response to a bad fuel injector and 8 spark plugs.
    Barry
    MAD828 and Qavion like this.
  10. Qavion
    14,595
    Ian Riddell
    Yes, same here. Since the problem seemed to arise after a long period of non-driving, with my current gearbox issues, I'm going to get lots of opportunity to reproduce this contributing factor.
    Meanwhile, my tech is looking into it... and my contribution will probably be buying lots more expensive parts that I won't need. :D
  11. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,285
    CT
    John Kreskovsky
    Yep. Misfire, rough running can often cause noise in manual transmission or dual mass flywheel. Typically they go away if the clutch is depressed because that stops the rotating mass in the trans from interacting with the engine, but with a dual mass flywheel not so much.
    Think of a marble in a box. You accelerate the box forward and the marble hits the back of the box and stay there. But if the box decelerates, the momentum of the marble causes it to roll forward and strike the front of the box. When the box accelerates again, the marble doesn't accelerate until it strikes the back of the box. Rattle. Same type of thing happens in a transmission or dual mass flywheel when the engine RPM is unstable.
    SoCal1 and Qavion like this.
  12. Tarek307
    Tarek307 Formula 3
    1,349
    Tarek Salah
    Congrats man, that makes sense..misfire, engine is imbalanced sort of..leads to sounds
    Qavion likes this.
