Lowering 308 Front Suspension | FerrariChat
Discussion in 'Technical Q&A' started by Ksullender, Dec 9, 2003.
  1. Ksullender
    Ksullender Formula Junior
    Sep 3, 2003
    887
    Is there a way to lower the factory front suspension on a 308. I would like to lower the front of mine to give it a more level stance. I was hoping for an adjustment that could be made versus bolt on modifications.
  2. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    You will need to either install a spring lowering perch,
    or install a set of adjustable shocks with springs like I did.
  3. Steve Magnusson
    25,453
    No adjustment is provided.
    Go to the old FChat site and search on "lowering 308" (AND mode, parts of words) -- you should get ~40 relevant threads discussing the 4 methods (from ~$200 cost to ~$3K cost):
    1. Deeper lower spring perches.
    2. Send your Koni to Truechoice (or similar) to (be rebuilt and) have adjustable lower spring perches added to the lower shock case.
    3. Find shorter (and usually stiffer) 4" OD springs.
    4. Replace existing (4" spring) Koni with adjustable aftermarket (2.5" spring) shocks per Dave's post.
