Lowering our rides.. | Page 2 | FerrariChat
Discussion in '458 Italia/488/F8' started by zaid458, Nov 30, 2011.
  1. zaid458
    zaid458 Rookie
    Jan 21, 2011
    21
    i am starting to think that the only possible reason ferrari have intentionally "raised" their cars is to make room for improvement once they have their lightweight scuderia versions released???
  2. GRahal09
    GRahal09 Rookie
    Nov 28, 2011
    47
    Has anyone has any issues with lowered cars that the lift system throws lots of warnings and error lights? I am waiting for my car to be delivered, but the previous owner says it has a light on for the front lift because he lowered it. Anyone else had this before?
  3. Gofast430
    Gofast430 Karting
    Jun 2, 2013
    205
    Overland Park, KS
    Don Dearmore
    Image Unavailable, Please Login Here is my 2013 Italia. Just dialed the springs down. Don’t forget the alignment. Have to use spring replacement if you have a front lift.
  4. RayJohns
    RayJohns F1 Veteran
    7,830
    West Coast
    Ray
    I lowered my 458 myself - 15mm lower in the front on the stock coil overs; just turned the collars down. Has to build my own spring compressors though :)
    Ray
  5. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,248
    Mel
    mark1000+ likes this.
  6. RayJohns
    RayJohns F1 Veteran
    7,830
    West Coast
    Ray
    multi-link suspension - by its design - pretty much holds the alignment constant thru travel. Just lowering a few mm isn't going to have much of an impact
    Ray
  7. Melvok
    Jul 25, 2008
    14,248
    Mel
    Well ... measuring is the only answer Ray :D
  8. RayJohns
    RayJohns F1 Veteran
    7,830
    West Coast
    Ray
    Never huts! :)
    Ray
  9. Baitschev
    Baitschev Formula Junior
    Jan 8, 2017
    262
    Vienna
    I like lowered ferraris
    My rear Shock absorbers the treads sticking
    No movement possible.pls help
    I think i have to cut the Big nut and install new one
    Do you have any causes like this?
  10. geochin
    geochin Formula Junior
    Jul 3, 2012
    306
    NJ
    George
    Per my dealer, after production at the factory, they actually raise all the cars delivered to states. Also confirmed they will lower my incoming 488 Spider if I choose to and it is not hard thing to adjust. But told ride will be harder than the 488GTB I had that I didn’t lower.
  11. Rbwiii
    Rbwiii Formula Junior
    Aug 9, 2014
    606
    Cali
    BW
    In my opinion to do it right...Novitec springs standard 20 inch rims with spacers gets you the best look and handling
  12. Melvok
    Jul 25, 2008
    14,248
    Mel
    Wel, that is not strange, is it ? :D
  13. Charleswang089
    Charleswang089 Karting
    78
    Canada
    Charles Wang
    Have the dealer lower the vehicle. If the dealer knows what they are doing, you can ask them for Speciale alignment which gives the car a little more aggressive camber which improves corner in and out of turns.
  14. Oengus
    Oengus F1 World Champ
  15. martini13
    martini13 Rookie
    Aug 2, 2017
    12
  16. bus stop
    bus stop Rookie
    Jul 26, 2016
    7
    Oengus that looks absolutely beautiful. I've been thinking of lowering mine and really love the stance on yours. Do you mind sharing the manufacturer of your wheels. I've been searching for something similar.
    Wheelb likes this.
  17. Oengus
    sure bus stop, ADV.1 CS 21" FRONT, 22" REAR with Gloss Gun Metal finish + Novitec lowering springs.
    Contact David at wheels boutique
    [email protected]
    Wheelb likes this.
  18. Wheelb
    Wheelb Formula 3
    Sponsor
    Feb 17, 2009
    1,585
    Miami, Florida
    Wheels Boutique
    Thank you for the recommendation! I love working with you on yours and the final outcome was picture perfect. :cool:
    Feel free to contact me directly so I can provide you with more information on the setup above.
  19. Oengus
    I can tell you that David was awesome to work with.......
    Wheelb likes this.
  20. Macki
    Macki Rookie
    Oct 3, 2017
    34
    Germany
    Simon
    I asked my dealer if they can lower my soon to arrive new 488 GTB.
    he told me that it is not possible, because i have the lift system.
    anybody else got that info?
  21. Wheelb
    Wheelb Formula 3
    Sponsor
    Feb 17, 2009
    1,585
    Miami, Florida
    Wheels Boutique
    If the car has front lift it will not be adjustable through the factory suspension. For cars equipped with the front end lift we use Novitec springs which lowers the car and you do not lose the lift function.
  22. spyder625
    spyder625 Formula Junior
    Jun 16, 2017
    726
    NJ
    looks great lowered... i would love too do the same but worried about clearance when i use the lifter
  23. Wheelb
    Wheelb Formula 3
    Sponsor
    Feb 17, 2009
    1,585
    Miami, Florida
    Wheels Boutique
    Measure the front clearance with both the front lift fully up and fully down and subtract about 30 mm from each number. That's the drop that you can expect from the Novitec springs and it will give you a good idea on whether or not it's acceptable and tolerable for your usage.
  24. Napoli
    Napoli Formula Junior
    Nov 18, 2017
    958
    NOYB, Ray!
    My dealer told me the opposite.
  25. Oengus
    my front lift works perfectly with the Novitec springs
