Lusso Dash | FerrariChat
Lusso Dash
Discussion in 'Vintage (thru 365 GTC4)' started by John Vardanian, May 29, 2017.
  1. John Vardanian
    John Vardanian F1 Rookie
    Jul 1, 2004
    3,046
    San Francisco Area
    John Vardanian
    Does anyone have a diagram of (or know) what the dash switches do? There are seven in the middle and one to the left of the wheel. Thank you in advance.
    john
  2. T308
    T308 Formula 3
    May 12, 2004
    1,008
    Southern Cal
    From memory (possibly flawed) Headlight, Windshield Wipers, electric fuel pump, fog lights, fan, heater, dash light dimmer.
  3. T308
    T308 Formula 3
    May 12, 2004
    1,008
    Southern Cal
    Forgot the interior light switch, that's the one on the left side below the key.
  4. hhibbett
    hhibbett Karting
    Aug 24, 2008
    97
    Hi John,
    I have an old wiring diagram that someone sent me a while ago. I will try to dig it up and will send it to you.
  5. Caeruleus11
    Caeruleus11 F1 World Champ
    10,913
    @hhibbett, if you have a diagram I would very much appreciate seeing it, so long as you are comfortable sending it. If so just PM me an email address. Thank you.
    My notes are similar:
    Below ignition: Interior Lights
    Lower right of steering column from L->R: Left Vent, Right Vent, Choke
    Under tach/speedo the central 7 switches from L->R: Headlights, Wipers, Autoflux (fuel pump), Rheostat (I think this is instrument illumination), Fog/Aux lights, Left Blower, Right Blower
    Next to these central 7 is a small dial, this is the trip ODO reset.
    Hope this helps!
  6. hhibbett
    hhibbett Karting
    Aug 24, 2008
    97
    It has been quite a while since I got it (15 years or so). It might have just been someone jotting it down on a piece of paper. Either way, I will send it to you as well. I will let you know when I find it, and you can send me your email address.
  7. John Vardanian
    Jul 1, 2004
    3,046
    San Francisco Area
    John Vardanian
    Thanks Hoffman and everyone.
    john
  8. hhibbett
    hhibbett Karting
    Aug 24, 2008
    97
    I found the information. It was sent to me by a gentleman, from Hawaii, that I met at Concorso Italiano in 2000. Here is what I have
    In addition to some Weber carburetor information, I have a "250 GT Schematic Wiring Diagram", a hand-written dash layout of 5223 GT/L (which illustrates the functions of each of the knobs on the dash - seems to match T308's responses), and a sheet which identifies the fuse box circuits (left and right fuse box markings).
    The 250 GT Wiring Diagram does not designate if it includes the 250 GT/L, or if is it meant for the 250 GTE or ...... I have been told previously that there is no specific GT/L wiring schematics; the 250 GT information should suffice. I'll let someone here with more detailed knowledge comment on that. Same is true for the fuse box information. It does not state the actual model.
    Let me know which of this information you would like, Caeruleus11. John, I got your PM. Would you like all three?
  9. John Vardanian
    Jul 1, 2004
    3,046
    San Francisco Area
    John Vardanian
    Got them. Thanks Hoffman.
    john
