MD CLUTCHES, anyone have one installed? | Page 2 | FerrariChat
Discussion in '348/355' started by FLORIDAsnakeEyes, Dec 20, 2015.
  1. FLORIDAsnakeEyes
    FLORIDAsnakeEyes Formula 3 Silver Subscribed
    Jul 7, 2015
    1,154
    Sarasota, Florida
    OC
    And to reply to those of you who ask about the flywheel; why mess around with repacking it etc?
    I am all for upgrading.
    I'll let you know how it works out.
  2. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Great
    What are you hoping for as far as difference in engine performance?
  3. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,919
    Richmond
    Pete
    What's the cost? Might be worthwhile next time I'm due for a clutch.
  4. m.stojanovic
    m.stojanovic F1 Rookie Silver Subscribed
    Dec 22, 2011
    3,300
    Serbia - Niš
    Miroljub Stojanovic
    I think that the decision to go for a solid flywheel should be because it eliminates the hassle with the dual mass one: grease leaks, rattles, difficult hot start, re-greasing etc. I wouldn't bother with a light flywheel unless it is a race car and you want to squeeze out every possible bit of additional acceleration. The engine torque will be the same; only, during acceleration, a tiny bit less of that torque will act on the spool-up of the flywheel and a tiny bit more will act on the speed-up of the transmission (and the wheels).
  5. SoCal1
    SoCal1 F1 Veteran Owner
    Jun 14, 2011
    8,636
    SoCal LA/OC/New Mexico
    Tim Dee
    Cant remember the price just contact Andrew
    I have a light flywheel in one of my challenge cars. BOY HOWDY, She revs like a loose girl should
    See Bruces video of one revving, idle to redline in a split second
  6. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Looks great.
    Why did ferrari put a dual mass flywheel in the 348/355 and then abandon it for the 360 onwards?
  7. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    What's the purpose of the special grease in the 355 flywheel?
  8. FLORIDAsnakeEyes
    Jul 7, 2015
    1,154
    Sarasota, Florida
    OC
    From what I understand (I really don't know) it's supposed to be to keep sound at rattle of springs down. But again, I don't know. This is just what I read here on F chat.
  9. FLORIDAsnakeEyes
    Jul 7, 2015
    1,154
    Sarasota, Florida
    OC
    this is 90% of why I did it. 10% to see if it really does rev faster. It won't matter, I am no Shoemaekr.
  10. FLORIDAsnakeEyes
    Jul 7, 2015
    1,154
    Sarasota, Florida
    OC
  11. SoCal1
    Jun 14, 2011
    8,636
    Tim Dee
    Thats Hot !!!
  12. m.stojanovic
    Dec 22, 2011
    3,300
    Serbia - Niš
    Miroljub Stojanovic
    The main function of the dual mass flywheel is to dampen the torsional vibration generated by the engine, i.e. by the combustion strokes in regular intervals acting on the crankshaft which can also cause strong resonant torsional vibrations at various RPM points. This is more of a problem in the case of in-line 6 cylinder engines (due to long crankshaft) so, using it in the Ferrari's V8 is probably more for luxury - less vibration, smoother idle and reduced rattle of the downstream transmission.
    The grease (special only for its high temp. properties) is there to eliminate the noise/rattle of all the moving bits and pieces inside the flywheel. The flywheel rattle (when the grease leaks out or gets thinned - diluted by transm. oil) seems to also fool the knock-sensors into registering this as engine pinging and causing the ECU-s to retard the timing unnecessarily; this is believed to be the reason for difficult hot starts.
  13. FLORIDAsnakeEyes
    Jul 7, 2015
    1,154
    Sarasota, Florida
    OC
    Yikes/
  14. INTMD8
    INTMD8 F1 Veteran Owner Silver Subscribed
    Jun 10, 2007
    6,815
    Lake Villa IL
    Looks really nice^^ Interested to hear your driving impressions once it's together.
  15. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Have to wait till March at the earliest to see how the car behaves once fitted then��
  16. desmar84
    desmar84 Rookie
    Aug 13, 2008
    8
    Oak Grove MN
    Mark Schlangen
    Rebuilding voith now on my Mondial t. Andrew at MDClutches supplied everything! Great guy and very knowledgeable. It was difficult to find a machine shop to resurface the friction surface but it can be done.
  17. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Looks pretty nice .... :)
  18. Rifledriver
    37,288
    No, it is to dampen the torsional problems associated with the long shaft from the crankshaft to the flywheel. The grease in concert with the springs are what is actually doing the dampening.
  19. m.stojanovic
    Dec 22, 2011
    3,300
    Serbia - Niš
    Miroljub Stojanovic
    You are absolutely right, I did not think of the long shaft.
  20. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Brian
    What do you think of the MD replacement flywheel?
  21. m.stojanovic
    Dec 22, 2011
    3,300
    Serbia - Niš
    Miroljub Stojanovic
    As Brian very well pointed out, the part to consider (if thinking of going for rigid flywheel) is the rather long shaft connecting the crankshaft to the flywheel. Any single torsional impact on the shaft (like too sudden release of the clutch) is absorbed in both cases - in the original design, by the springs in the flywheel; with a rigid flywheel, by the springs in the clutch disc. So there is no real problem here.
    However, the torsional vibration of the long shaft could be a problem. This vibration is caused by the pulsing torque from the crankshaft acting on one end of the long shaft. In the original design, there is a relatively small weight rigidly attached to the other end of the shaft (the moving disc in the centre of the flywheel) so the danger of resonant torsional vibration is small. The rest of the flywheel weight plus the weight of the clutch is a "sprung weight". I believe that the original dual mass flywheel is carefully designed to minimise torsional vibration of the long shaft.
    When going for a solid flywheel, we are rigidly attaching a significant weight (the new flywheel plus the weight of the clutch assembly) to the end of the long shaft. The question is how will this added weight affect the torsional vibration along the long shaft. It is, in effect, a ballast at one end of the long shaft against which the pulsing torque at the other end (from the crankshaft) can cause serious torsional vibration of the shaft. The real danger is the shaft entering into resonant torsional vibration (at certain rpm) which can cause shaft breaking in two, not immediately but over time due to material fatigue.
  22. lotusk
    lotusk Formula 3
    Nov 3, 2003
    1,840
    London UK
    Very good info
    Have to think about it
  23. F355Bob
    F355Bob Formula 3
    Nov 4, 2003
    2,002
    Madison, Wisconsin
    Formula GT in Germany makes a new stronger shaft for this reason.
