Michelin Pilot Sport 4S for 360: Ordered • Installed • Fits! | Page 6 | FerrariChat
Discussion in '360/430' started by Alpintourer, Oct 12, 2018.
  1. HJZ360
    HJZ360 Karting
    Nov 27, 2017
    68
    Weslaco, Texas
    Harold John Zurlo
    I bought the same set today!
    Alpintourer likes this.
  2. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,678
    Silicon Valley
    I can’t answer the question of where in the UK you can find them, but performance tires are made in batches based on expected demand, so if they are out of a particular size, it might be awhile before they’re stocked again. You might have to look around some and perhaps even the continent if none available in the UK.
  3. Mrjb
    Mrjb Karting
    Jan 12, 2022
    93
    Matt
    Thanks for the input. I’ll see what occurs as we head towards spring. I presume that 225/40 just isn’t hugely in demand.
  4. tomw
    tomw Formula 3
    Feb 25, 2004
    2,413
    London
    Tom
    UK chap here. I usually buy my tyres from Camskill. Out of interest I checked their stock and they have PS4S fronts available in 2 days and the rears in 6 days. I wear 225/35/19 and 285/35/19 though.
    I swapped my old P Zeros for PS4Ss last spring and it's made the car much nicer to drive.
  5. Mrjb
    Mrjb Karting
    Jan 12, 2022
    93
    Matt
    Yeah I saw they had 19’s but will need 18’s on the starfish wheels
  6. velocegiallo
    velocegiallo Karting
    101
    California
    Has anyone installed Michelin Pilot Sport 5's on their 360? This tire is available in the OEM sizes. Speed rated Y (186 mph). I know they are one step below the 4S, but as a stock size alternative option I am considering. Any comments?
    cavlino likes this.
  7. Aku
    Aku Rookie
    Oct 27, 2021
    30
    Why should anyone do that? The PS4S is perfect for everyday use.
  8. velocegiallo
    101
    California
    Agreed. As well as slightly higher performance. However, PS4S does not come in OEM size which affects speedometer and ASR slightly. PS5 comes in the OEM size so not issues in that regard. So the pertinent question is; does the slightly better performance of PS4S outweigh the negative speedometer/ASR issue?
    cavlino likes this.
  9. Arkaid
    Arkaid Rookie
    Dec 29, 2014
    9
    NYC
    I was not able to find the PS5 in stock in the USA in those sizes (I do know it exists but only the UK tire shops seemed to have them) so instead went with the PS4S in the sizes recommended in the initial post in this thread. Only ~100mi on them so far but no rubbing / drivability issues and car seems to both ride better / grip better and has a bit more turn-in than the Pirellis on it before. Mind you, those tires were 10yrs old...
  10. P1key
    P1key Karting
    Nov 9, 2022
    82
    Jeff Pike
    Having used the car on track I found it to be extremely well balanced, and not lacking grip by any stretch of the imagination, so when my Pirellis wear out I'll most likely be replacing them with PS5s. Maybe later this year if I do a few more track days, lol :D
  11. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,686
    Honolulu
    Kevin
    Has anyone tried the 225/45 w/ the 285/40 combo in the PS4S on a 360?
  12. Kevin Rev'n
    Nov 29, 2009
    24,686
    Honolulu
    Kevin
    This combo would match OEM for aspect ratio (height) but be slightly wider since the OEM widths are not available in this tire? Is it because they are wider that it is not smart to use the OEM height or was the OEM height choices not available when this thread was created?
  13. Finpat
    Finpat Formula Junior
    Sep 17, 2021
    251
    Finland
    Kari Lehtinen
    I have OEM sized PS5 on both 348 and 360. No issues on street driving, a good, high quality tire as you can expect from Michelin. No serious track time with these toys anyways.
