430 - Modern Ferrari 430 Tail Light - Possible GROUP BUY? | Page 13 | FerrariChat
430 Modern Ferrari 430 Tail Light - Possible GROUP BUY?
Discussion in '360/430' started by TommyTheV, Nov 3, 2022.
Clear or Smoked
  1. Clear
  2. Smoked
Results are only viewable after voting.
  1. TommyTheV
    TommyTheV Karting
    Sep 17, 2022
    221
    San Diego, CA
    Tommy T.
    Welcome to the club Joe :)
    GogglesPisano likes this.
  2. nchhotu
    nchhotu Formula Junior
    316
    Roseville, Ca.
    Nick
    Glad you liked them. They look awesome! Great write up!
    colorfull likes this.
  3. colorfull
    colorfull Formula 3
    2,340
    Franklin Park, New Jersey
    John Napoli
    That is the perfect situation for using it!
    With the gleam on your car, gonna be a total showpiece!
    In pics it seemed to make a bit of difference the car color, but in person I think not so much, they will look great on any F430.
  4. boba fett
    boba fett Formula 3
    1,123
    England UK
    Thanks, I am actually excited to get them fitted, weather is shocking here though!
  5. colorfull
    colorfull Formula 3
    2,340
    John Napoli
    They're not going anywhere, take your time! I always take much longer to do these things as I take my time with every single aspect of it. It's probably therapeutic.
    I have found one caveat though,.... you have to manage your enthusiasm.
    After seeing them glow, I burst into the house and told my wife, 'THESE LIGHTS ARE ABSOLUTELY GORGEOUS!'
    She says 'I don't recall you ever talking about me like that!' :eek:
    I'm a backpedaling master but I wasn't getting out of that one....
  6. Mel Spillman
    Mel Spillman Formula Junior
    723
    Sugar Land, Tx
    Maybe one of these days Byron will make his taillights for a 360 and we can do another group buy!!!!
  7. colorfull
    colorfull Formula 3
    2,340
    John Napoli
    #307 colorfull, Jan 7, 2023
    It's a fairly straightforward install, but the 2nd side went smoother and faster than the first, hopefully this is helpful.
    PBE Taillight install procedure
    Tape off under the lights
    Snip the wire wrap tie inside the engine bay
    Remove 3 nuts on R2 (or L2) - R2 had more room, so probably better to start with this side
    Watch out for slotted washers, 2 of my lights had them, fortunately the insulation below makes a nice catch tray
    Label position/screw location of washer that is under the nut so you can put it back as it was, since it is shaped to the car
    Slide taillight out (feed wire from the back), disconnect the connector
    Label taillight (R2) and stow in box
    Clean and label connector (R2)
    Feed connector gently through slot angling it to get it through
    Clean area and mount
    Repeat on outer light (R1)
    Both lights out
    Insert PBE R1 taillight so it's flush with the mount bracket (feed the wires down under the car mount bracket) with no washers and see where it sits
    Insert rubber washers against the lights where it needs to move up, or right/left. If a screw doesn't need a rubber washer for positioning, just add a metal flat washer
    Once position looks good by just inserting it, hold it there, then add the washer you marked up before and a lock nut
    I tightened the top nuts almost firm to keep the lights high, then tighten the others and then going in turn, tighten the nuts firm, setting final positioning, watching movement (it will move a millimeter or so)
    Check for clearance from the car on the sides of the lights while you're doing this
    Once they're both installed and fitted, connect the lights to each other with the smaller connectors
    Connect the harness to the lights, then the car
    Test
    Zip tie up the wires
    You're done!
    This procedure, with the equipment and materials above, install went really smoothly.
    Good luck gents!
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  8. mathewr
    mathewr F1 Rookie
    Sponsor Rossa Subscribed
    Dec 7, 2011
    2,918
    Deep in the Heart of Texas
    Ferrari Wheel Guru
    Well done! Thanks for sharing!
  9. colorfull
    colorfull Formula 3
    2,340
    John Napoli
    My pleasure, hope it saves time and makes it an easier go.
    Honestly I found doing it relaxing and enjoyable!
  10. RacingReyes
    RacingReyes Rookie
    Jan 7, 2023
    2
    Aurelio Reyes
    Wow they look great!! Do you know where i can get a pair of those taillights?
  11. colorfull
    colorfull Formula 3
    2,340
    John Napoli
  12. ByronKong
    ByronKong Rookie
    38
    Byron Kong
    thank you sir
    从我的 iPhone 发送,使用 FerrariChat
  13. colorfull
    colorfull Formula 3
    2,340
    John Napoli
    you're welcome, you've earned it!
    we do have to see how they fair over time, at this point though I can easily say this is one of the nicest mods I've seen for the F430.
  14. ferrari 4404
    ferrari 4404 Rookie
    Jun 15, 2014
    36
    Greece
    Kostas Liaskos
    Hello from Greece
    Has anyone installed the new lights? photos please
  15. colorfull
    colorfull Formula 3
    2,340
    John Napoli
  16. ferrari 4404
    ferrari 4404 Rookie
    Jun 15, 2014
    36
    Greece
    Kostas Liaskos
    Congrats Ferrari scuderia 2023
  17. GogglesPisano
    GogglesPisano F1 Rookie
    3,213
    East Bay, California
    Joe
    Got my lights today! Super pleased with how they look in person and can’t wait to install them. Most importantly though, they came with stickers that I get to stick on my toolbox :D
    AandSC, colorfull and TommyTheV like this.
  18. TommyTheV
    TommyTheV Karting
    Sep 17, 2022
    221
    San Diego, CA
    Tommy T.
    Ya! Welcome to the club Joe. We finally got you convinced huh? :p
    PS: Yes they sent pretty quality stickers.
  19. ferrari 4404
    ferrari 4404 Rookie
    Jun 15, 2014
    36
    Greece
    Kostas Liaskos
    When you install them, pictures please
  20. 66ss427
    66ss427 Formula Junior
    439
    N. Myrtle Beach, SC
    Dominic
    If it’s stickers you like, PM me your mailing address and I’ll send you lots of them !!!
  21. GogglesPisano
    3,213
    Joe
    Man, why was I even on the fence about these? They're 100% better looking in person that I could have expected. I am so glad I pulled the trigger eventually even though I missed the GB price. Definitely not as bright as the Scud Ing Swiss that I just removed, but it's better than stock. I feel like the rear end has been refreshed. The clear centers always made a weird eyeball look to me and dated the rear. The blacked out centers are definitely the way to go while keeping the outers nice and bright red. I will say that I do wish there was some slight design in the plastic on the upper portion of the light, but it's an overall improvement so I'll take it.
    Pictures attached. Please excuse my cluttered garage, we don't get much room out here in the bay area :D
  22. colorfull
    colorfull Formula 3
    2,340
    John Napoli
    Completely agree with all your comments Joe and they do look simply fantastic!
    And that's not even powered on, light 'em up and they are near otherworldly!
  23. GogglesPisano
    3,213
    Joe
    Agree. The glow around the entire back section is a nice touch.
  24. boba fett
    boba fett Formula 3
    1,123
    England UK
    Well they look incredible. Much better than I thought they would, it’s taken years off the rear end. I need to get mine done now quick sharp!
  25. ferrari 4404
    ferrari 4404 Rookie
    Jun 15, 2014
    36
    Greece
    Kostas Liaskos
    Veryyyyyyyy beautifulllllllllll 2023 Ferrari f430
