mondial-electrical problem / switches ? | FerrariChat
Discussion in 'Technical Q&A' started by stevej33, Mar 23, 2004.
  1. stevej33
    stevej33 Karting
    Feb 16, 2004
    76
    Lincoln, UK
    Steve Jollands
    hi there all,
    ive got a problem with my electrical bonnet and boot release system on
    my 84 mondial qv. none of the 3 switches operate the release catches,
    so im having to use the emergency cable release, which is a real pain!
    the fuses are all ok, and when i put 12volts across them they all work fine.
    anyone come across this before, or have any idea where i need to look??
    cheers
    steve j
  3. norm
    norm Karting
    May 30, 2003
    204
    Rochester, NY
    Have you sprayed the solenoids with a light oil? Some times the solenoid( the piston portion of actuator)can stick. It's just strange that all (3)would have the problem. You may want to make this a priority. If the solenoid isn't working, and you were to break the pull cable, you will have a major problem getting the bonnet up.
  4. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Applicable to most Mondial switches
    turn off power at battery
    try spraying the switch contacts and inside the switch with Radio Shack electrical cleaner - clean and work the switch action a few times
    let solvent dry off
    reconnect power
    has saved me a few times.
    good luck
  5. Philjay50
    Philjay50 Formula Junior
    Jan 16, 2003
    595
    Chester, England
    Philip
    Now get ready for this one ! I had the same problem, sometimes the switches would work sometimes not. I sprayed pushed and cleaned all the obvious connections.
    In the end I took the speedo out so I could get to the back of the switches, Once removed I could see that not only where they switches but also relays.
    I took the fronts off and cleaned the connections, this was partially successful, What I discovered was that the connectors on the back of the switch are rivited on ! and were very slightly lose, the only reason I notice this was while pressing the switch to test it, the connection got pretty hot.
    The answer was to take the switch off conpletely ( not big deal) and I just compressed the rivets. Problem solved, a couple of hour tops to do it.
  6. stevej33
    stevej33 Karting
    Feb 16, 2004
    76
    Lincoln, UK
    Steve Jollands
    cheers guy's..........
    got myself a job for the weekend!!
    thanks for the advice
    steve j
