Mondial gas odor question | FerrariChat
Discussion in 'Mondial' started by garciacg, Apr 18, 2009.
  1. garciacg
    garciacg Rookie
    May 28, 2004
    45
    Newport Beach
    Carlos G.
    Hi gang,
    I have a question regarding my 1988 Mondial Cabriolet. There seems to be a strong gas odor everytime I go into the garage. The car has been fully serviced recently and the gas tanks were taken out and repowdered. The fuel injector system has been rebuilt. I checked the gas cap and it appears to be sealed appropriately. I know that older cars can have gas odor, but this is very strong to the point where it makes it difficult to be in the garage.
    Has anyone else experienced this??? Any assistance will be greatly appreciated!!!
    Cheers,
    CG
  2. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    You have to find the source of this. Breathing gas fumes is not good for you. The Fire danger is very serious as well. Is the car running way too rich? This can be a source of fumes from the exhaust but I think you have a leak somewhere. You have to go step by step.
    Good Luck Finding It
  3. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    I would check the filler tube neck to see if it's sealed up,but something is defintiely wrong. 1980's cars do not vent gas. A tech can pressurize the system and find the leak.
    Dave
  4. garciacg
    garciacg Rookie
    May 28, 2004
    45
    Newport Beach
    Carlos G.
    Yes, it seems to be running rich. I have had my mechanic check the car and didn't find any leaks. I did smell the pipes and could smell gas fumes. I will have to get it checked again.
    Thank you for the quick reply!!!
  5. DenisB
    DenisB Formula Junior
    Jul 21, 2007
    511
    Cape Cod Ma.
    Denis B.
    if you can smell the fumes in the pipes- won't that cause a buildup in the cats and then be a 'major" issue??
  6. garciacg
    garciacg Rookie
    May 28, 2004
    45
    Newport Beach
    Carlos G.
    yep, that is my concern. I have left my mechanic a message. Thanks!
  7. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #7 snj5, Apr 18, 2009
    If the hoses on your vapor recovery or fuel system have never been changed, then they may have become cracked and weep fuel. Another frequent culprit is the fuel accumulator.
    Suggestion to inspect fuel system - time est 1.5 hours:
    1. Lift up Right rear side and remove RR wheel and forward fenderwell. Please then place car on jackstand under main frame member.
    2. Against the firewall you will see the fuel accumulator and fuel pump. Inspect and TOUCH the hoses where they are fastened to the accumulator and pump, and see if there is gas dripping from the top drain of the accumulator. Also check the hoses atatching to and the fuel filter.
    3. At the very upper back outboard top of the fuel tank there are several (4?) nipples where the gas return line and vapor recovery system attach. Inspect each of these connections thoroughly, as the hoses here can crack and weep gasoline giving you the odor you complain of. Since you just had your tanks done, I am betting something is loose or deteriorating in this area.
    4. Examine the hoses thoughout the vapor recovery system where they attach to their respective cannisters and attachments.
    Good luck and let us know.
  8. garciacg
    garciacg Rookie
    May 28, 2004
    45
    Newport Beach
    Carlos G.
    Excellent information! Thank you much and I will provide an update once I get a chance to inspect it.
    I really appreciate everyone taking the time to provide all the feedback :)
    Cheers,
    cg
  9. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #9 snj5, Apr 18, 2009
  10. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,381
    Northern VA
    Dave W
    #10 davebdave, Apr 18, 2009
    Can't help you there but you have excellent taste in cars, as does my wife (daughter pictured)....
    Ciao,
    dave
  11. garciacg
    garciacg Rookie
    May 28, 2004
    45
    Newport Beach
    Carlos G.
    Thank you Russ for the diagram. This is very helpful and I really appreciate it! Will keep you posted on the outcome.
    Cheers,
    Carlos
  12. garciacg
    garciacg Rookie
    May 28, 2004
    45
    Newport Beach
    Carlos G.
    Hey Dave, awesome cars!!! I have a 73 Fiat 500 yellow as you see on my signature. The Ferrari is black. Love both of them! I will some pics when I get a chance.
    Cheers!
  13. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    It's common for carb'd cars to exude a smell of gas after the engine is shut down and the car is sitting in the garage - this is fuel evaporating out of the float bowls. But, a fuel injected car should definitely not exude a gas smell - they have sealed systems with an evaporative recovery system. Take a look at the floor and see if you see any fuel dripping. And, don't smoke around your ferrari until you find the leak!
  14. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #14 snj5, Apr 20, 2009
    Sure - here is one labeled with the big pieces
  15. garciacg
    garciacg Rookie
    May 28, 2004
    45
    Newport Beach
    Carlos G.
    Thanks again Russ! I have been pretty busy traveling with work, so I have not had a chance to begin the search.
    On another note, do you know how to adjust the idle on the 3.2 model? I don't know much about italian cars unfortunately (American cars I can work on :) ) I found the screw to adjust it, but it is at the lowest level already, therefore, I cannot lower it anymore (currently it idles at 1500, which is to high).
    Cheers,
    Carlos
  16. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    #16 snj5, May 17, 2009
    Well, the K-jet the idle is adjusted with the big screw air bypass doofer. If it is idling to high with the idle adjust all the way out , you may have stuck temperature air bypass valve (not uncommon - a volkswagon K-jet part). And if you have never done it, change the O2 sensor. There are a lot better K-jet guys on here than me, hopefully they will chime in.
    Good luck!!
  17. garciacg
    garciacg Rookie
    May 28, 2004
    45
    Newport Beach
    Carlos G.
  18. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,652
    Argent/Brasil
    Guido
    #18 theunissenguido, May 18, 2009
    Hi, maybe your gascables are to short. It can be reset on the throttle. Nr 45 on the picture (2X).
    You have to pull out the fine metal split and turn the internal screw outwords. Loosen this little bolt on the other side and turn the THREAD SPHERIC HEADS (nr 45 on the picture) against clockwise to give the cable more play...there are 2 like this on your throttle...if it is a Mondial T.
    I hope it helps..
    Guido
  19. garciacg
    garciacg Rookie
    May 28, 2004
    45
    Newport Beach
    Carlos G.
    Thanks Guido. This is not a Monidal T, it is 3.2.
    Thanks again for the information...
    Carlos
  20. theunissenguido
    Jan 21, 2004
    2,652
    Argent/Brasil
    Guido
    #20 theunissenguido, May 19, 2009
    Then a 3.2 has only 1 THREAD SPHERIC HEAD nr 41 on the picture.
    Guido
  21. garciacg
    garciacg Rookie
    May 28, 2004
    45
    Newport Beach
    Carlos G.
    Thanks Guido. The number 41 screw was already to the lowest level, unfortunately. I took it to my mechanic today and he adjusted the idle in a minute :) He took of the air filter box and made the adjustment from there.
    Now, I just got to figure out where the gasoline odor is coming from.
    Ciao,
    Carlos
