More 308 carb sync - tolerance in kg/hr in carb airflow? | FerrariChat
Discussion in 'Technical Q&A' started by Mike328, Jan 30, 2004.
  1. Mike328
    Mike328 F1 Rookie
    Oct 19, 2002
    2,655
    Boulder, CO
    From some research in the archives, I've seen some data that suggests you should try to syncrhonize your carb airflow rates between barrels/carbs to +/- 1/4 kg/hr.
    Here's the thread:
    http://www.ferrarichat.com/discus/messages/256120/267063.html
    I think I could get +/- 1/2 kg/hr... But consistent 1/4 kg/hr is optimistic...
    That said, maybe this accuracy is plenty accurate for the carbs? Is there a spec on the tolerance for kg/hr in carb air flow?
  2. ferrarifixer
    ferrarifixer F1 Veteran
    8,520
    Melbourne
    Phil Hughes
    If everything is healthy and well prepared, the only thing stopping perfect synchronisation is the amount of time you're willing to spend doing it. Remember to fully close all bypasses initially and only open those that need it, to keep you in range.
    Being within 1/4 is perfectly acceptable and a good place to stop fiddling, but you can go for perfection if you have the urge or time.
    If a butterfly is bent, or spindle problem etc, or other engine trouble, you may have trouble getting close.
  3. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    Anywhere from 3 1/2 - 4 /12 Kg/hr is fine.
  4. 4re gt4
    4re gt4 Formula 3
    Apr 23, 2002
    2,279
    Roseburg, OR
    Hans E. Hansen
    I didn't have much trouble getting all holes to just a shade under "4". Like 3 3/4 or 3 7/8.
