MSD Ignition system for Ferrari. | FerrariChat
Discussion in 'Technical Q&A' started by jscar71, Jun 28, 2005.
  1. jscar71
    jscar71 Formula Junior
    Jul 14, 2004
    354
    Montreal Qc, Canada
    JScar
    I have an 84 mondial, anyone ever add an ingnition system on there Ferrari.
    MSD or any other?
    If you have added one, what do you suggest and what is the difference if any?
  2. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    I installed an MSD 6AL ignition with an SS Blaster high vibration coil in my BB512i. I chose the high vibration coil because it is black like the stock Marelli coil and after I put a Marelli sticker on it it looks stock. My Boxer runs better than ever...I highly recommend this modification.
  3. mk e
    mk e F1 World Champ
    Oct 31, 2003
    12,917
    The twilight zone
    The Butcher
    I use an MSD DIS4 on my car...but it also has a haltech ECU
  4. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    I installed an MSD 6A on my 77 308.
  5. tomberlin
    tomberlin Formula Junior
    843
    Bethesda
    tom berlin
    Dave,
    Are you still running points? How does it work? How many distributors?
  6. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    16,267
    wisconsin/chicago
    bo
    Franklin, any insight on how difficult it was to do? Did you just buy 2 modules? Was it a simple swap???
  7. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    Points are gone, I am running a single dizzy Norwood conversion.
  8. Verell
    Verell F1 Veteran
    May 5, 2001
    7,017
    Groton, MA
    Verell Boaen
    Search the bodies of posts in the old fchat archives, Several MSD conversions posted there.
  9. jeffdavison
    jeffdavison F1 Rookie
    2,544
    Suwanee Georgia
    Jeffrey Davison
    I'm running an MSD DIS4 with Denso Coil-on-plugs in my F355.
    me so happy :)
    JD
  10. Dr Tommy Cosgrove
    35,351
    Birmingham, AL
    Tommy
    for a V8 QV motor, what MDS model # and parts do you need?
  11. jscar71
    Jul 14, 2004
    354
    Montreal Qc, Canada
    JScar
    RESULTS???
  12. shifty308
    shifty308 Karting
    Aug 7, 2004
    75
    coulterville ca
    steven schiffler
    i have the millermon with msd and i really like it, it idles better (stronger spark) and is eaiser to adjust, plus cheaper replacement parts and adjustable rev. limiter. can't be beat!
  13. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    88 Mondial 3.2 - converted to a single Mallory Unilite distributor and a MSD 6 AL box, with an MSD coil.
    Conversion covered in old threads.
  14. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    "Results"
    No more expensive distributor caps, rotors, plug wires.
    Car stays in tune longer, no points wear or drift.
    Better burn, higher voltage coil, wider plug gap.
    The engine acts like a single 8-cylinder in unison, instead of two 4-cylinders fighting each other.
  15. markcF355
    markcF355 F1 Rookie
    3,493
    Schmeckelstan
    Mark
    Sorry for the highjack, but does anybody know what the numbers mean on the Denso cops?
    Also, Jeff, thanks for the cad file you sent. I am changing over to cops/MSD at the end of summer.
  16. jscar71
    Jul 14, 2004
    354
    Montreal Qc, Canada
    JScar
    So i own a 84 mondial cabriolet euro version. Does anyone know the part number / numbers I need for my car. MSD is my preference.
  17. Jhusey
    Jhusey Rookie
    Jul 19, 2013
    1
    Is it posible to get the cad file to make that conversion??
    thanks !!
  18. DinoRossa
    DinoRossa Karting
    Nov 4, 2012
    65
    New Zealand
    Chris Mulvena
    I have a 308DinoGT4. I replaced the points/cam with MSD pickup and billet reluctor (1 in each dizzy - just cut off every second fin on the reluctors), then used signal to feed HEI style module as per the later GT4's/308's. Hid the modules under the coils so looks stock and fires right up every time. Used MSD hi vibration coils. Sorry should have taken photos but....
    I have used the HEI modules on several engines and they work great, only 4 wires to hook up and you can buy bits anywhere.
    Regards
    Chris
    Peter likes this.
  19. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    #19 chrismorse, Jul 23, 2013
    When I got my 77, it had two msd 6 units, all else stock. It ran like **** because the rubbing block(s), point(s) were in bad shape.
    I went with the Norwood ignition conversion:
    Chrysler mag pick up, recurved advance.
    modified ford rotor, (easy to do),
    Od of the cap mounting area on one distributor slightly turned down to accept a $16 Chevy 8 cylinder cap, (basically, a 265 cap, which does not have the point setting window).
    Whamo, 20 k miles reliability,
    One distributor to time, (looks like a euro single distributor set up)
    A $100 bill lets you replace pick up, cap rotor at any napa out in east jesus Wyoming.
    To this I added a msd 6al, blaster coil and msd wires.
    Very reliable, idles nice, no plug fouling, (.050 gap).
    But, if I had it to do again, I would look at some of the newer computer controlled coil on plug set ups, with a manifold vacuum input for added advance at cruise, because, I still get 16 mpg and I am sure that I am leaving some HP on the table compared to a computer setable system.
    I am sure that the old two distributor, (eachwith two sets of expensive points) and the need to pull the distributors every time to reset the points on a distributor machine, the added complexity of syncing two distributors and the horrific cost of the caps was a major reasonthat the cars got the reputation for being tricky and expensive to maintain. Sure, the carbs take a bit of time to sync, but once that is done and you have the ignition updated, these cars are not that bad to maintain.
    HTH,
    chris
    Peter likes this.
  20. 335s
    335s Formula Junior
    Jan 17, 2007
    870
    SF Bay Area
    T. Monma
    I can certainly understand a retrofit to an early vehicle where carbs are used, and the Marelli distributors are mechanical advanced, the points actuallly pass the juice-as oppossed to them acting as a "swithching trigger" device, colis which have a limited saturation capacity for a collapsing field, all in syatems which MIGHT(USA spec cars) have an additional set of points DESIGNED INTO THE SYSTEM which retard all slow speed activity by 4 or 6 degrees up to 10-12 degrees. All in carb cars which require 11-13% increase in fuel volume of flow(USUALLY a min 1 step up in idle jets, and in BAD cases down 1 in mains too...) to approximate the eqivalent enrgy potential (BTU) of" back then real gasoline"...
    What I fail to understand is why you need to increase the firing line Kv at idle when most Bosch cis ignition boxes are "blasting" at idle in the 25-30Kv range, and in late multi valve with LH ranges in the 50 Kv area(the wider gapped plugs require this as a function of the distance increase and the MUCH leaner idle mixtures controlled through the Lambda system's faster integrator circuit-think of how slow this circuit acts in a 308/328QV!)????
    this still has electronic referencing and timing "maps"(6-8 per module, all active and accessable, dependent upon which circuit's pin is grounded, in my memory) Mondial 8 bulletin actually shows how to do this i seem to recall...This means that no ignion "parts" are being used for any more than a swithching circuit to "trigger" the spark
    does the MSD function as a super saturator for the coil?
    How much of an increase is the aftermarket suite of parts providing, and what is its designed functionality? In a 355 I find it unbelievable that it offers a measureable improvement-so long as cylinder chamber sealing is at the 2-4% leak down range, a choppy idle here, with usual deteriorating intake guides MIGHT be masked by this add on, but in a tight motor, I these things idle purrrfectly...after this, they use PLASMA fired plugs-so forget trying to tell me that add ons will improve this sytem, because it can't-IMO...
    For this to work in more than a seat of the pants, subjective manner of feeling better affair....are there any real testing results? I mean a driving trace of the FTP-75...the LA -55 driving trace....run on a CVS with cold bag driving trace....how is it going "up the big hill?'...the steady 30, the staedy 20...hoit restart....cold bag?
    Quantifiable numbers?
    I'd LOVE tpo see a trace with gas bag numbers....
  21. Dannytestarossa
    34
    key west Florida
    Daniel A Coll
    undefined
    can I use this MSD system on my 1991 Testarossa?
  22. Steve Magnusson
    25,157
    Why do you need to? Replacing the rather unreliable DinoPlex system on a Boxer that still has a mechanical distributor advance with an MSD system makes sense, but the MicroPlex system on a TR is very reliable and relatively easy to fix when something does go wrong. What "problems" are you having with the stock MicroPlex system?
  23. JCR
    JCR F1 World Champ
    10,019
    H-Town, Tejas
    MSD boxes have had reliability problems for years. Plus and a street car CD ignition is inferior to inductive ignition.
  24. ago car nut
    ago car nut F1 Veteran
    5,267
    Madison Ohio
    David A.
    Was told the newest MSD boxes made in China have a 10% failure rate. Not as good as the original MSD box. The hot rod world doesn't care much for them anymore.
