Buy
MSD spark amp for 328
Discussion in 'Technical Q&A' started by dhs-9, Mar 10, 2004.
  1. dhs-9
    dhs-9 Formula Junior
    Feb 6, 2004
    292
    Has anyone ever used a MSD module with their 328. If they have how did it work out. Also wouldnt you need two since there is two coils
  3. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    MSD is not compatable with the dual coil single ecu 328 Microplex or Digiplex ignition. MSD requires distributor triggered ignition (points, optical, Hall). It can replace the early points triggered Dinoplex ignition. You are correct that that you need one per coil.
    MSD is compatable with the non electronic ignition 308s with distributors.
    best
    rt
