My experience owning a Ferrari 360 Spider F1 after 7 months of ownership | Page 3 | FerrariChat
Discussion in '360/430' started by whatheheck, Oct 2, 2014.
  1. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I know. Same spot you took yours!
    Your 360 is a beauty!
    Dan
  2. GyllesSmyth
    GyllesSmyth Karting
    Apr 3, 2013
    138
    Kirkland, Washington
    CGS
    Thanks, so is yours; look forward to seeing it again at RTC.
    I stop in at Carillon Point all the time, but usually walking or biking since I'm just a few blocks north of there in Kirkland.
  3. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    This weekend is the last meet for ERTC. Parking thugs said they are tired already as it has been a very busy year :(
    Before going to ERTC I usually stop by Carillo Point too to just watch and enjoy the view.
    Beautiful view indeed.
    I will surely see you around. Drive safe.
    Dan
  4. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,100
    Calif
    Brett
    I never have that problem...manual trans...it sounds like the clutch either is not fully disengaging completely ie: clutch plate/bearing still slightly pressing on the clutch plate causing slippage? Or is the clutch close to replacement? F1 I assume right? I was surprised to hear your smelling clutch going forward although I have heard of this reversing in the F1...
  5. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Hi Brett,
    Its a known shortcomings of the F1 transmission based on what I've read here.
    F1 transmission feathers the clutch big time on uphills and also when backing up and this is where the most clutch wear happens.
    Manual transmission is different story as the driver is in full control of clutch engagement.
    I'm sure F1 owners would chime in soon.
    Dan
  6. F.Watson
    F.Watson Rookie
    Sep 16, 2014
    40
    Thanks for your report.
    The car looks superb especially with those wheels.
    Just bought my first Ferrari, a 360CS with 10,000miles on the clock, so very interested in your experience.
  7. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Thanks for chiming in and I appreciate the kind words.
    Congrats on your 360 CS! And such low mileage too!
    Kindly share photos when you get the chance and some more detailed info about your new car.
    Dan
  8. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,100
    Calif
    Brett
    I guess I would think the transmission software knows the car is in need of power and not feather anything...but what do i know?...Not much here....couch jockey...interesting though..great looking car...I have a TDF blue 360 spider but really like the cuoio interior...mine is beige buy I still like it....;)
  9. 993man
    993man Formula Junior
    877
    New Zealand
    Graham
    I have only ever spelt burning clutch once, and it smelt expensive.
    But that was reversing up a slight, like really slight hill, if you can even call it a hill.
    So now I don't park on hill where I have to reverse.
    Sorted.
  10. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Smart man you are Graham. Me too, I now avoid uphills if I can help it.
    And yes, the smell of clutch doesnt smell cheap :)
    Dan
  11. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Thanks for sharing your ownership experience.
    Just on the F1 and clutch slip, I'd recommend trying to get someone else to drive your car and ideally for you to drive theirs. What you describe may be down to your clutch being significantly worn but it could also be down to your technique which perhaps could be improved leading to longer clutch life.
    Best.
  12. GaryR
    GaryR Formula 3
    Dec 11, 2006
    1,006
    Valencia, Spain
    Gary R.
    Does the CS TCU upgrade help with this?
  13. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    THanks for chiming in Greg.
    Great recommendation and I will definitely do that. I will need to get my clutch replaced first as currently F1 popping out of gear is becoming more frequent, as mentioned by Ferrari of Seattle as clutch continues to wear out.
    Any F1 techniques you can recommend?
    I had two BMW M6's with SMG transmission and never had an issue with clutch engagement. One member stated its because BMW M6 uses wet clutch and ours on the 360 is a dry clutch.
    Thanks again.
    Dan
  14. FerrariDublin
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Most drivers of F1 system strive to get an early positive start and achieve full engagement quickly. E.g. Don't try and "nurse it", particularly when starting up a hill, but wait till there is sufficient space ahead of you and move off with positive use of the accelerator. Some will also cite initial press of pedal, slight pause for clutch to engage fully then move on with purpose.
    Your problem sounds like the clutch is just near or at end of life but I'd still recommend you try and drive another healthy car and have that person try yours. The pooling of knowledge has to be good you both.
  15. teej
    teej Formula Junior
    Jul 1, 2009
    475
    Pacific Palisades
    Are you lugging it up the hill, meaning go up the hill at low RPMs?
  16. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Thanks Greg.
    Based on what you suggested below it appears I am driving the F1 just as you suggested.
    My clutch is just worn out. Thanks again.
    Dan
  17. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    No, I wait till the clutch fully engages then I press the gas pedal hard enough to go up hill properly.
    Ferrari of Seattle master mechanic mentioned to me no one is perfect. Every F1 owner out there will smell a slight burning of clutch once in a while and that is perfectly normal.
    Just so everyone is aware, I am 53 years old, started driving when I was 16 and learned on a manual transmission. Been driving a manual transmission for over 30 years.
    My two BMW M6 was an SMG, similar to an F1 but there is no issue with clutch slippage like the 360 F1 so I had to learn this type of transmission quickly to fully enjoy the car.
    I learned from this board after a month of ownership on how to properly drive an F1.
    I.e, just like a 3 pedal car wait till the clutch fully engages before hitting the gas pedal hard. Some also said blip the gas pedal as clutch engages faster. Did that too and learned it fully.
    I can honestly say after 3 months of ownership I now know how to drive an F1 car.
    Just wondering if there are other techniques out there I should learn.
    Thanks for chiming in.
    Dan
  18. F.Watson
    F.Watson Rookie
    Sep 16, 2014
    40
    #68 F.Watson, Oct 7, 2014
    http://www.ferrarichat.com/forum/attachment.php?attachmenthttp://www.ferrarichat.com/forum/attachment.php?attachmentid=1962714&stc=1&d=1412710369id=1962712&stc=1&d=1412710144
    As you can see the car is Rosso Corsa with black leather interior. It has both seat belts and harnesses. No radio. I have just had a major service carried out at my local Ferrari dealer.
    The unique selling point of the car is the sound that it makes, like nothing else on earth.
    Not planning to do thousands of miles a year, but trying to take it out for some exercise at least once a month (weather permitting). Considering taking it on track days next year.
  19. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Beauty!
    Have fun and drive safe!
    Dan
  20. weebz69
    weebz69 Karting
    Jul 11, 2014
    85
    Gilbert AZ
    Jason W.
    I got ya beat, I owned mine for about 2 months now. A week after I bought it the heat exchanger failed. When they went yo replace it they found a motor mount was bad. Replaced that, also steering rack was leaking went the cheap route and got it rebuilt. All said and done $8100 50 hours of labor. Bringing the car in for a flush today because there is still oil in the coolant. But over all I love the car. Its a piece of Art but man Ferrari needs to hire better engineers lol. Enjoy your ride love the Red!!!
  21. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Thanks for sharing your experience Jason.
    I consider these cars like super high end super sexy great looking girlfriends.
    They cost a lot more to keep and maintain :)
    Dan
  22. Hardistyfezza
    Hardistyfezza Formula Junior
    Yep! Don't make great long term partners, but great fun once in a while!!!
  23. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    +1!
    Agree!
    Dan
  24. Cyt
    Cyt F1 Rookie
    Feb 1, 2014
    3,744
    Cyt- Chin
    #74 Cyt, Oct 18, 2014
    My 8 months ownership (feb). Being a nice spring day today, I had it out for a short drive n photo with the local iconic building...,
  25. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    Nice car and great shot!
    Dan
