My Ferrari F355 GTS | Page 10 | FerrariChat
My Ferrari F355 GTS
Discussion in '348/355' started by Senshi458, Oct 24, 2021.
  1. Tarek307
    Tarek307 Formula 3 Silver Subscribed
    Sep 26, 2018
    1,349
    Long Beach, CA & Alexandria,Egypt.
    Tarek Salah
    LOWER!!! it looks like a 4x4 now..you can just lower it a bit for a more sportive look
    Senshi458 and lanab like this.
  2. lanab
    lanab Formula Junior
    Feb 21, 2016
    512
    Stockholm, Sweden
    I agree, the car sits way too high which makes the wheels look small.
    Senshi458 likes this.
  3. Senshi458
    Senshi458 Formula Junior Sponsor Owner Rossa Subscribed
    Oct 17, 2015
    883
    Norway
    Reza
    :DHehehe yeah but then the car will be hard to use in Norway, the roads in centrum of Oslo not the best :confused: I will keep as is for now :p
  4. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,449
    Los Angeles
    We're not in high school any more Tarek, it's not "cool" to be "slammed"!! o_O
  5. Matt Andrews
    Matt Andrews Formula Junior
    Dec 31, 2006
    515
    Newport Beach, CA
    I actually raised mine some last night. too low makes it too made is scrape everything and hitting on the bumpstops makes handling unpredictable. I think it looks more "sporty" to have good travel. to each their own. I know some people like slammed. I like to be able to drive. :p
  6. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,449
    Los Angeles
    It's very much true that lowering a car too much results in poor handling. Suspensions are designed to have X amount of travel. Go much lower than stock and the geometry gets messed up and the shocks/springs can't do their job.
  7. ShineKen
    ShineKen F1 World Champ Silver Subscribed
    Aug 3, 2007
    19,892
    Southern California
    Nostradamus
    Over the years, @Mitch Alsup has written the bible on 355 suspension.
    https://www.ferrarichat.com/forum/threads/f355-suspension-analysis.13258/
    You have Fiorano Handling Pack. His advice would be to go 1 inch lower than factory specs.
    https://www.ferrarichat.com/forum/threads/lowering-355-suspension.395397/#post-142032914
    A) The challenge cars are significantly lower than stock. But they have different tires (racing slicks), different springs 2.5XR 4X front, and shocks to match. Oh, and different anti-roll bars. This just proves that one can successfully lower the car--if you are willing to change almost everything other than the hubs and a-arms.
    B) The high speed stability (i.e. aerodynamic oversteer/understeer) is set by the front ride height. Raise the front moves the aerodynamic center of pressure rearward causing understeer. The low speed oversteer/understeer, is then controlled by the rear ride height. lower the rear to induce understeer.
    C) due to the geometry of the front and rear suspensions, raising or lowering the rear will perform 1.6 times more change in the oversteer/understeer relationship than the same movement at the front. Thus, the rake of the car is dependent on the ride height!
    D) With the stock anti-roll bar, the factory ride height makes for a quick but not overly quick car (balalnced oversteer/understeer.) If you lower the ride height and use the factory rake, you will want a different front anti-roll bar (i.e. stiffer.)
    E) none of this maters if you stay under 120 MPH anyways.
    C'dwic and Senshi458 like this.
  8. ShineKen
    Aug 3, 2007
    19,892
    Southern California
    Nostradamus
    Alot of owners, including myself, make the mistake of lowering the rear too much without considering/measuring the rake of the car and unfortunately the car's understeer/oversteer characteristics are sensitive to it. I felt it immediately as soon as I did it. In short, whatever you do, just make sure there's rake :).
  9. ShineKen
    Aug 3, 2007
    19,892
    Southern California
    Nostradamus
    Rake on the 355 is a little hard to tell visually because of the odd shape of the sideskirts. Measuring would be best.
  10. ShineKen
    Aug 3, 2007
    19,892
    Southern California
    Nostradamus
  11. Tarek307
    Sep 26, 2018
    1,349
    Tarek Salah
    Ken i want to bring you my car and have you lower it and rake it properly lol...how can we arrange that..pretty plz haha
    Senshi458 and ShineKen like this.
  12. ShineKen
    Aug 3, 2007
    19,892
    Southern California
    Nostradamus
  13. ShineKen
    Aug 3, 2007
    19,892
    Southern California
    Nostradamus
    Lol.
    I'm linking all this just as easy reference for myself because eventually I will need to configure a new setup with my FHP suspension.
    With stock setup, I'd go by the book, which is probably what you don't like :). Stock height and play within 0 and 15mm front to rear rake (rear higher). Play with rake by adjusting rear first. Alot of it will be based on feel and personal preference once you drive and it's all a tedious matter of adjusting the height with tools by millimeters at a time.
    Unfortunately, mine will be based off FHP specs, so I can't help you much there.
  14. 308 GTB
    308 GTB F1 World Champ Rossa Subscribed
    Feb 7, 2002
    11,725
    New Jersey
    Barry Wolinsky
  15. ShineKen
    Aug 3, 2007
    19,892
    Southern California
    Nostradamus
    For whatever it's worth, my car with stock suspension , but upgraded Advan A052 tires felt superb and balanced. I do have 235's instead of 225 in the front though. I took pictures of damper height measurements somewhere before I removed them. You can follow those heights if you still have the standard springs if I can find the pics. My car was probably 1/2 inch lower than factory specs. Not too high not too low, but another half inch lower with the FHP suspension, I'd imagine would be a nice balance between visual appeal and performance.
  16. ShineKen
    Aug 3, 2007
    19,892
    Southern California
    Nostradamus
    On a side note, I believe most rear mid-engine V8 Ferraris are sensitive to the rake issue.
  17. ShineKen
    Aug 3, 2007
    19,892
    Southern California
    Nostradamus
    I’ve read somewhere some have observed an FHP car to sit roughly 10mm lower than standard, which is close half an inch. Would be nice if someone could confirm this.
  18. Philipnz
    Philipnz Karting
    Apr 12, 2015
    223
    Whitianga New Zealand
    Philip Hart
    I'll measure mine tonight when I get home
    Senshi458 and 308 GTB like this.
  19. OCKlasse
    OCKlasse Formula Junior Rossa Subscribed
    Oct 5, 2006
    709
    Newport Beach, CA
    Brandon K
    OK Boomer.
    ryalex, Senshi458, ShineKen and 2 others like this.
  20. Philipnz
    Philipnz Karting
    Apr 12, 2015
    223
    Philip Hart
  21. C'dwic
    C'dwic Formula Junior Owner Silver Subscribed
    Apr 23, 2021
    493
    France
    Interesting all you write here ! Could be serious with what i will do with my New steering rack challenge installed.
    I will send you a message by WhatsApp Ken to know what you think ?
    ShineKen and Senshi458 like this.
  22. Matt Andrews
    Dec 31, 2006
    515
    Newport Beach, CA
    LOL. My 355 has tires older than you. Get out of here with that.
    OCKlasse and Senshi458 like this.
  23. ShineKen
    Aug 3, 2007
    19,892
    Southern California
    Nostradamus
    https://www.ferrarichat.com/forum/threads/355-coilover-height-difference-question.258652/#post-139037022
    “Ride height is measured from the center of the rear pivot bolt on the bottom a-arm on a dead flat level surface.
    The fender clearance is irrelevent, get the ride height set on each corner with the tires at operating pressures (40 PSI) with the drivers weight in the drivers seat and possibly 0%, 50%, or 100% of the passenger weight in the passenger seat (0% is for never any passenger, 50% is sometimes a passenger, 100% is always a passenger). 1/2 tank of gasoline,... If the ride heights are set properly at the a-arms and you have a fender clearance issue--this is a sign that the corners are not carrying an equal weight or that the car was in a wreck and not fixed properly. If its less than 1/4" just don't worry about it.
    Front ride height is 162mm to 171mm
    Rear ride height is 182mm to 191mm”
  24. ShineKen
    Aug 3, 2007
    19,892
    Southern California
    Nostradamus
  25. ShineKen
    Aug 3, 2007
    19,892
    Southern California
    Nostradamus
