Need a new lift for my garage. | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by dersark_painclinic, May 8, 2018.
  1. dersark_painclinic
    dersark_painclinic Formula Junior
    Mar 8, 2005
    981
    Glendale, CA
    Lazik Der Sarkissian
    FBB, I see what you meant by 4" , the MDS comes with 2" block that might not clear to remove the lateral bolts of the undertray. Either needs taller blocks like 4" . I will check this weekend to find out more. Thanks for the tip.
  2. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Dave, that is a nice one and you have heigh celling.
  3. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
  4. StuR
    StuR Formula Junior
    Jun 14, 2005
    561
    UK Buckinghamshire
    Stu R
    Dave, you might as well finish the job: projector, screen, ladder - with the lift remote you’d have yourself a full motion sim!!! Looks very impressive.
    GTUnit likes this.
  5. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Ha-ha! :) Thanks.
    I'm considering blowing the back wall out and making the garage double deep but not sure it's an economical decision. If I do that, I will bust the entire floor, add a drain, do 6" and epoxy top coat. The lift would be moved to the back section. Probably better off building a new house :)
    taz355 likes this.
  6. StuR
    StuR Formula Junior
    Jun 14, 2005
    561
    UK Buckinghamshire
    Stu R
    Knock through / connect and have it like a gallery! Next you’ll want a turntable...
    I worked with UK aircraft sims a few years back - you really could have a fun set up!! Very inspirational.
  7. JCR
    JCR F1 World Champ
    11,024
    H-Town, Tejas
    Mohawk... sweet. The Rolls of lifts.
  8. fatbillybob
    Aug 10, 2002
    29,252
    socal
    Sark,
    A lift is a bonus but you don't have to have it for the 550. You can work with a 8ft ceiling just sit on a rolling stool when you work.
  9. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    FBB, I just heard back from Bendbak salesman and he conforms your recommendation on 2 post lift if I have a room. Meanwhile I found out there is 6 " rubber block instead of standard 2" block for the other lift which I thing will give more clearance to take down the undertray. Both lifts are approved.
  10. fatbillybob
    Aug 10, 2002
    29,252
    socal
    That's not bad. That gives you 52" and rolling on a stool you can probably avoid doing the hunchback. The rocker lift also gives you clear access with the doors. Only an Asymetric twin post will do that. so on the 550 undertray the plastic surrounds the jack pads. If you put the blocks there you can't get the trays off. There is really no good place to put jack pads. So I cheat and diminish the value of my 550 by cutting that small tab of plastic so I can just the ferrari jack points and slip the undertrays right out. You will see when you first try it.
  11. dersark_painclinic
    Mar 8, 2005
    981
    Glendale, CA
    Okay! I will check again, thanks for your guidense
  12. 328GTB
    328GTB Formula Junior
    Jun 4, 2002
    305
    Texas, USA
    Carmine
  13. Archer911
    Archer911 Formula Junior
    Sep 26, 2016
    907
    New England
    Tim
    Guys for what it's worth I have a Quality Lift, 4 post, and 11ft ceiling. I bought the longer ramps and the bridge jack. I use it quite a bit and am very happy with it.
  14. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hi Carmine - 10 feet.
  15. timeckart
    timeckart Formula Junior
    Apr 9, 2015
    558
    Wildeck in Germany
    Tim Eckart
  16. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,074
    Central NJ
    Dominick
    Hello fellowchatters
    I have a simple question ..for those who have a hd-9 lift from bendpac, can you do me a favor and measure clearance between tracks and rails
    Appreciated
    Thank you
    Sent from my Moto G (4) using Tapatalk
  17. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    They don't provide a dimensional drawing?
  18. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,074
    Central NJ
    Dominick
    They do but even thier texh support could not tell me if that measurement included or excluded rails
    Nothing is that easy unfortunately ..
    I have the dimensions diagram but looking to get confirmation if measurement is inside rails or inside ramps
  19. Keith360
    Keith360 Formula Junior
    Feb 6, 2015
    570
    Santa Barbara County
    Keith Williams
    #44 Keith360, May 17, 2018
    I have what I think is the best solution for lifting and working on everything under the car. It's flush with the floor when down, and lifts to 72". I’ve removed and installed muscle car engines, transmissions, rear ends, VW air cooled engines and transmission, and all the maintenance on my 360 Spider. Wheels, brakes, suspension are a breeze.
    Kinda looks like a land speeder on Star Wars.
    Cirorsi, steved033 and Dave rocks like this.
  20. QSA
    QSA Formula Junior
    Jun 3, 2011
    302
    Kingwood, TX
    Quinn
    Very cool. What’s the make/model?
    steved033 likes this.
  21. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Truer words never spoken ;)
  22. Keith360
    Feb 6, 2015
    570
    Keith Williams
  23. steved033
    steved033 F1 World Champ
    Apr 12, 2017
    10,332
    Atlanta, GA
    Steve D.
  24. Keith360
    Feb 6, 2015
    570
    Keith Williams
    After looking at the one from Greg Smith Equipment, I’m 100% sure EE makes them for him. The only difference is the price. Although it some time ago, I paid $1,650 for mine with $60 shipping to the Port of LA,?and another $350 to clear customs and deliver to my house some 200 miles away.
