Need some numbers | FerrariChat
Need some numbers
Discussion in 'Technical Q&A' started by Demarzo, Dec 22, 2003.
  1. Demarzo
    Demarzo Rookie
    Dec 21, 2002
    49
    Southern Califronia
    I needs some torque numbers.
    1. Water pump bolts
    2. Oil sump bolts
    3. Timing belt covers.
    Anyone know these numbers? I'm about to put it all back together. Your help is needed.
    Richard
  2. fly
    fly Karting
    Nov 20, 2003
    124
    Sydney, Australia
    Steve
    Richard
    For which car do you need these numbers?
    Steve
  3. Demarzo
    Demarzo Rookie
    Dec 21, 2002
    49
    Southern Califronia
    For a 1980 308 GTBi.
  4. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Demarzo,
    Torque specs are in the "Ferrari 328 Tech Specs, Publications List, Recall Campaign, Service Bulletin Index " Also, in the FSM's, all can be found in the 'Private Document Collection':
    http://ferrari.jenkins.org/books/
    BTW, Here are some additional links to other online resources that you'll probably find useful:
    'Online Service Manual' - http://www.cameragear.com/ec/
    308 GTB Register TechTips - http://www.r-design.net/308/index_e.html
    Ferrari Club of America:Northwest Region Site: FerrariFAQ - http://www.ferrariclub.com/faq/
    (Click on Ferrari FAQ & scroll down)
    FerrariList.com:
    DIY and Mechnical information and instructions - http://www.ferrarilist.com/?query=docs&action=catlist&cat=5
    Forum: Technical/DIY - http://www.ferrarilist.com/forum/list.php?f=3
    Also the FerrariList archives are searchable.
    Another, quite new, forum is: http://www.*****************/
    Ferrari 308 FAQ - http://home.att.net/~ferrari/308faq1.htm
    Technical Articles and Writings by Tony Palladino - http://www.modena-motors.com/Technical%20Articles.htm
    SERVICE & PARTS MANUALS, SPECS & SERVICE BULLETINS:
    Private Ferrari Document Collection - http://ferrari.jenkins.org/books/
  5. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    I don't know if you'll find a torque spec for any of the nuts you mention. My experience: None of the bolts or nuts you mention should be tightened "tightly". For me, pan nuts (6mm IIRC) are tightened with a stub-handled (4") rachet wrench about 45 - 60 degrees turn past initial bite. You can go a bit tighter on the WP but remember it is a steel stud in an aluminum casing. Cam covers (from memory these are a 12mm stud) I use a 6 inch rachet wrench tightened by feel. Having said that, I thought I was being R-E-A-L-L-Y gentle with one and pulled the studs through the threads on the front cam cover. Maybe the metal wasn't ageing well (26 1/2 years) in the repeated heating and cooling. Had to pull everything apart and get a helicoil put in.
    FYI, the master tech at Continental has warned me the ones to be very careful with are the carb nuts. The Webers are a composite material (we used to call it "monkey metal" in the old days) and it is very hard to repair unlike aluminum which can be welded.
    HTH
    Philip
