Newwheel caps for my F355 | FerrariChat
Discussion in 'Technical Q&A' started by thomasg03, Jan 31, 2006.
  1. thomasg03
    thomasg03 Rookie
    Nov 23, 2005
    15
    Kirkland, WA
    I purchased new wheel caps for my F355 but I am not sure if I need to remove my wheels to install them? Does anyone know how to remove them without removing the wheels?
    Thanks,
    Tom
  2. PAP 348
    PAP 348 Ten Time F1 World Champ Lifetime Rossa Owner
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Maybe try and pick them out with a tiny flat blade screw driver. You may or may not damage the wheel using the screw driver and maybe you will damage or break the old cap. If you dont care about the old caps,just smash a screw driver through the old ones and rip em out. LOL. Or just take the wheels off to avoid damaging them! :)
  3. Crawford
    Crawford Formula 3
    Mar 5, 2003
    1,294
    Nashville, TN
    Crawford White
    I just put some on my 328 yesterday. I used a small slot screwdriver to pry around the edge.
    Put a small shim between the wheel and the screwdriver and this should minimize any damage. I used a thin guitar pick and it worked very well.
    Getting the new caps on was a bear, though! I had to lubricate the plastic rim and slightly file the edges to get it to pop in.
  4. kev 355
    kev 355 Formula Junior
    Jul 26, 2005
    528
    Burbank, CA
    Kevin
  5. thomasg03
    thomasg03 Rookie
    Nov 23, 2005
    15
    Kirkland, WA
    Thanks guys. I am pretty anal about my cars so I guess I will be pulling the wheels off!
    Tom
  6. ghost
    ghost F1 World Champ Lifetime Rossa
    Dec 10, 2003
    10,046
    Singapore
    Moved to the appropriate sub-forum.
  7. RavenFan_94
    RavenFan_94 Rookie
    Dec 10, 2005
    10
    Annapolis, MD
    Jody Presti
    You can take a small flat head screw driver and put it in the fingers of a leather glove. Works like a champ. Good luck!
  8. NYCFERRARIS
    NYCFERRARIS Formula 3
    Mar 2, 2004
    1,011
    these f-car hub caps come off very ez without removing the wheels....just do what I did (not intentionally, mind you.....just park your car on the street in new york... the sidewalk side pair will be "removed" without you doing anything.... they will just be gone when you come back... in fact all the "horsey" and "script" badges will be removed off the car after a few nighttime parking hours without much effort from you... but the nose badge does leave some paint damage when it is removed without opening the hood!
