no 2nd gear when cold | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by bobwass, Dec 1, 2003.
  1. Bryan
    Bryan Formula 3
  2. Chiaro_Slag
    Chiaro_Slag F1 Veteran
    Oct 31, 2003
    7,789
    CA
    Jerry
    Thanks for posting this! I have never worried about it as in "Oh no, my car won't shift to 2nd when cold." But, I have always been curious as to the mechanics of it & why I don't hear about it in other cars.
    Thanks!
  3. atlantaman
    atlantaman Formula 3
    Mar 31, 2002
    1,726
    Roswell, Georgia
    Charles
    here is a pic of one that i did
  4. SeaBayR
    SeaBayR Karting
    Sep 15, 2003
    66
    On the Chesapeake
    There is a new Country and Western music video out. Its based on a ‘Americal Idol” format, with vignettes.
    One set of scenes has a Parking Valet taking Capt Kirk (Shatner’s) red 360 off to park. When the Valet brings the 360 back, there’s 200 miles on it and no gas.
    The Valet tells Kirk that the car runs great but 2nd is a bit stiff.
    Shatner looks at him in shock and says “You got it in second?”
    Pretty funny for a C&W video,
    and for a 360 which usually doesn’t have this problem, either does my 348.
    Otherwise, your all in the same boat.
  5. Dr Tommy Cosgrove
    36,660
    Birmingham, AL
    Tommy
    After using syn fluid and seeing what a huge difference it makes, I can't imagine drilling any holes.
  6. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    SeaBayR,
    Saw that video while at a friends home. At the end when he mentioned second gear i was laughing my a$$ off. NO ONE else got the joke -- as i was the only Fcar driver -- and they though i went nuts. Guess it is indeed an "inside joke" of sorts.
    Enjoy the Drive,
    Steven R. Rochlin
  7. rivee
    rivee F1 Rookie
    Jan 20, 2002
    3,731
    Nowhere important, USA
    vwalfa4re, Couldn't agree more.
    When I changed over to synthetic, I couldn't believe the difference. Been that way for almost two years now.
    Used to be that I could barely get it into reverse when cold.
  8. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    THANK YOU ALL VERY MUCH!!
    While my 2nd gear is generally only problematic in cool/cold weather, knowing that there was a fix out there and not being able to get the specifics has been driving me nuts!
  9. Chiaro_Slag
    Oct 31, 2003
    7,789
    CA
    Jerry
    I guess I don't understand that either - And I think above someone mentioned that it happens in a 348 also. I am an accountant, but I still can't do the math on the 308 20 year production run??? What cars are you including there? 308, 328 - Anything else?
  10. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,582
    E ' ' '/ F
    Enzo Gorlomi
    Did the fix work?
  11. atlantaman
    Mar 31, 2002
    1,726
    Roswell, Georgia
    Charles
    The fix works pretty well--when I crank the car up I rock it between 2nd and 3rd a few times and it seems to help too--And I am using thick oil--Mobil 1 75-100
  12. DBR328&330
    DBR328&330 Formula Junior
    May 31, 2001
    605
    Winchester, VA
    Daniel Reese
    I can ask it another way: Why is it that my 88 328 (50,000 miles) NEVER has problems getting into 2nd gear regardless of temp??
  13. Verell
    Verell F1 Veteran
    May 5, 2001
    7,027
    Groton, MA
    Verell Boaen
    The most likely answer is '50,000 miles'. However, the fix could have been done before you got the car, or the hole was mfg'd slightly oversize.
    The problem varies dramaticly from car to car depending on the clearance the shift fork rod has in the hole.
    Wear will tend to increase the clearance, thus higher mileage cars tend to have milder or even no problems with it.
