News
Novitec 599 GTB Parts Available
Discussion in '612/599' started by Exotica Motorsports, Nov 19, 2007.
  1. Exotica Motorsports
    Nov 1, 2003
    3,661
    Washington
    Jason Godsil
    #1 Exotica Motorsports, Nov 19, 2007
  3. Exotica Motorsports
    Nov 1, 2003
    3,661
    Washington
    Jason Godsil
    1. Drivetrain
    - Novitec Power Stage 2
    Consisting of a new adjusted engine electronic with modified group of curves and higher cutoff speed to 8,550 RPM (thereby higher end speed). In addition, a stainless steel exhaust system with 70mm stainless steel replacing pipe.
    http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1072
    - Novitec Power Optimized ECU's
    Higher performance through new adjusted engine electronic with modified group of curves as well as higher cutoff speed to 8,550 RPM (thereby higher end speed)
    http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1073
    2. Exterior
    - Front Bumper Spoiler
    Add-on to original bumper, supports the negative lift
    http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=438
    3. Brakes
    - Steel Flex Brake Line Kit
    Includes 4 lines to fit OE system
    http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1083
    - High Performance Brake System
    Two 8-piston brake calipers and 380mm discs in the front and two 4-piston brake calipers and 380mm discs in the rear; 2 brake cooling ducts, steel flex brake lines, brake pads. Red, silver, black or customer requested colors.
    http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1082
    4. Lighting
    - Black Side Marker Kit
    http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1076
    5. Exterior
    - Side Skirt Panels
    Add-on to factory side skirts
    http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1078
    6. Tires and Wheels
    - 3-pc Wheels
    Silver 21x9” & 21x12.5”
    Black 21x9” & 21x12.5”
    http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1081
  4. Exotica Motorsports
    Nov 1, 2003
    3,661
    Washington
    Jason Godsil
    #3 Exotica Motorsports, Nov 19, 2007
  5. Exotica Motorsports
    Nov 1, 2003
    3,661
    Washington
    Jason Godsil
    7. Exterior
    - Rear Wing
    Supersport wing, wind tunnel tested.
    http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1080
    8. Lighting
    - Black Taillights
    Shines red when on
    - Black LED Third Brake Light
    Shines red when on
    - Black Reflectors
    9. Exhaust
    - Power Optimized Exhaust System
    Stainless steel with 2 90mm tips (2 left & 2 right) with or without.
    http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1074
    - Stainless Replacing Pipe
    Stainless steel replacing pipe starting from the manifolds (2 pieces)
    http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1075
    10. Exterior
    - Rear Diffuser
    Add-on, wind tunnel tested, supports negative lift
    http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1079
    11. Suspension
    - KW Coilover Supension Kit
    Includes dual adjustable stainless steel shock absorbers with separated expansion reservoir at damper housing, compression and rebound adjustable in front and rear as well as CAN control unit.
    http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1084
    - Aluminum Spacers
    Made of high strength aluminum, corrosion protected by anodize, set of 2 pieces including mounting material.
    10mm, Widens track 20mm
    15mm, Widens track 30mm
    20mm, Widens track 40mm
    http://www.prostores.exotica-motorsports.com/stores/cart.php?target=product&product_id=1085
  6. Exotica Motorsports
    Nov 1, 2003
    3,661
    Washington
    Jason Godsil
    Use our new Real Time Chat feature on our website. If there is any questions you have about prices, parts or need better pics, just click on the chat feature and we will talk to you in real time.
  8. Exotica Motorsports
    Nov 1, 2003
    3,661
    Washington
    Jason Godsil
    One set of Novitec 599 wheels in stock and ready to ship.
  9. furious_ferrari
    furious_ferrari F1 Rookie
    Nov 25, 2005
    3,129
    Vancouver, Canada
    Phil
    I like the wheels. They would look good on a black 599.
  10. Exotica Motorsports
    Nov 1, 2003
    3,661
    Washington
    Jason Godsil
    #8 Exotica Motorsports, Nov 27, 2007
  11. club0
    club0 Formula Junior
    Feb 22, 2004
    446
    Helsinki, Finland
    Unbelievably hot! :)
  13. Exotica Motorsports
    Nov 1, 2003
    3,661
    Washington
    Jason Godsil
    The wheel's center "star" is available in black as well.
  14. campanozzi
    campanozzi Rookie
    Dec 3, 2007
    1
    this car is so nice!
