OEM cdplayer's socket c2 and c3 difference | FerrariChat
Discussion in '360/430' started by 24000rpm, Aug 30, 2019.
  1. 24000rpm
    24000rpm F1 Rookie
    you see, both c2 and c3 have the cd changer connection
    which one is it really? or both have to be connected?
    or c2 for certain cd changer model and c3 for another cd changer model?
  2. Fenz
    Fenz Karting
    Nov 8, 2018
    176
    Team Europe
  3. 24000rpm
    24000rpm F1 Rookie
    so i assume i can use either c2 or c3 as aux input?
  4. f355spider
    f355spider F1 World Champ
    18,043
    What are you trying to accomplish? There are plenty of premade aux adapter cords and Bluetooth systems available that plug right into the back of these radios. Looking online may help you figure out what you need to do, based on the photos they show
  5. 24000rpm
    24000rpm F1 Rookie
    i want to accomplish 2 things
    1. to add a line in, as you said, bluetooth. That is the easy part.
    2. I am trying to understand why does the cd changer need both c2 and c3? isn't one enough? Why need so many pins? (5+3= 8 pins needed)
  6. f355spider
    18,043
    Not sure of all the details, but part of it lies in the Bluetooth for phone use. I bought a iPhone/Ipod lightning cord adapter that plugged into the C3 aux input on the back. Purchased back in 2015. Later, around late 2017, the Bluetooth phone quit working after a software update in IOS, I could hear, but the microphone no longer worked. I contacted the company in 2018 that sold me the cord, and I had to send it back and they modified it for a small fee, and now it uses both C2 and C3 to work correctly and I have Bluetooth functioning again. (at least I believe it now uses both C2 and C3...I would need to look and see to be certain, but that is what I recall)
  7. f355spider
    18,043
  8. 24000rpm
    24000rpm F1 Rookie
    ok, all done. BUT
    i found that if I don't connect c2, there will be no sound. Both c2 and the c3 have to be connected. Basically the becker thinks that I am playing a CD changer instead of the actual bluetooth receiver at work.
  9. f355spider
    18,043
    How did you do this?
  10. 24000rpm
    24000rpm F1 Rookie
    about c1. What are those line-out for? aren't line-out for 4 speakers covered already in socket A and B?
  11. 24000rpm
    24000rpm F1 Rookie
    sorry, how do I do what?
  12. 24000rpm
    24000rpm F1 Rookie
    problem.
    1. In order for the head unit to recognize there's a "CD changer", my CD changer magazine has to be in. and while I am playing bluetooth music, the cd changer is working! If I remove the magazine, the bluetooth will stop working!
    2. my single cd at the head unit will work , but there's no sound.
  13. f355spider
    18,043
    Have you consulted with the seller?
  14. 24000rpm
    24000rpm F1 Rookie
    update: the seller doesn't know anything...LOL
    so, I wrestled with the becker 6112 on the 430. Turned out, if you press "i" button, then select settings, you'll find the "aux". Finally, I can take out the 6 cd magazine and still be able to listen to my bluetooth ( from my android phone in my case) . And the head unit would display "AUX"
    still, if I switch to single cd, it has no sound, although it plays.
  15. Fenz
    Fenz Karting
    Nov 8, 2018
    176
    Team Europe
    Get rid of the Becker, it's crap.
