Oil question 2003 360 | Page 2 | FerrariChat
Discussion in '360/430' started by aseweepay, May 5, 2018.
  1. Need4Spd
    Need4Spd F1 Veteran
    Feb 24, 2007
    6,646
    Silicon Valley
    The oil expands a lot when it gets heated. You must check only when it’s up to operating temperature, and when running. Some oils foam more than others. As to whether foam is good or bad, my personal view is it’s not good. On wet sump engines, great pains are taken to baffle the oil pan and keep the oil from reaching the crank where the agitation of the crank would foam the oil. Why? Air in the oil is less effective at keeping a film of oil on your bearings. I can’t see why that principle would be different on a dry sump engine as found in a 360.
    Poi Dog likes this.
  2. Jgivoo
    Jgivoo Formula Junior
    432
    New Jersey
    Did you measure the quantity of oil taken out prior to refilling with fresh oil? It is always good practice to measure the fluids drained, confirm this quantity with the specification called for in the WSM or owners manual and refill to the 90% of the specification. Start engine and let oil heat up.
    Check oil at operating temperature and fill to midrange between min and max.
  3. ItalGerBrit
    ItalGerBrit Formula Junior
    Mar 15, 2016
    817
    S La
    Still think you should suck out oil until you can get a proper oil level reading at idle before doing anything else. This has happened to many people and removing some of the oil usually takes care of the problem.
  4. YorkieMark
    YorkieMark Rookie
    Apr 11, 2018
    24
    Mark Lewis
    Thanks everyone.
    The car is with a specialist at present and the oil level was on min with the engine warmed up and just after (<20secs) being turned off, with dipstick resting on, not screwed in.
    8.5 litres out 8.5 litres in apparently. Still the oil eventually bubbles up and over.
    I'll let you all know if / when I get to the bottom of it!
  5. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,388
    The Cold North
    Tom
    An oil change with filter, the car should take 9.5 liters of oil. Maybe a little less, or a little more depending on how long it' allowed to drain.
    When the oil is drained..the car should be warm. Drain the tank first..then the sump. Be sure to loosen the oil filter before draining.
    Once drained, and a new filter is installed, fill the car with 8 liters of oil. Let the car run until the cooling fans cycle. Shut if off. Check the stick. The level should be just at the bottom of the stick. Start and let run for another cooling fan cycle. Shut down and Re-check..level should be slightly higher.
    If the level does not change..drive the car around the block and re-check. Add accordingly until the level is mid way between min and max on the stick.
    obertRo likes this.
  6. RedTaxi
    RedTaxi F1 Rookie
    3,256
    New Zealand
    Glen
    I did my annual service yesterday. (430) I know my car takes 10 litres of engine oil to hit the full mark at hot idle. I put 9 litres in and started her up and got instant normal oil pressure and left idling for a few minutes and checked oil and it wasn't even showing on dipstick. Added 1/2 litre and drove 20mins till full temps reached. Oil was now at low mark. I topped up till 1/2 way between low and full, done.
    I have noticed I get less foaming if I set the level under full, halfway between low and full seems to be the sweet spot.
  7. RedTaxi
    RedTaxi F1 Rookie
    3,256
    New Zealand
    Glen
    Pretty sure you check the level at hot idle with the engine running. Not "shut off".
    SoftwareDrone likes this.
  8. tbakowsky
    Sep 18, 2002
    19,388
    The Cold North
    Tom
    Very well...
  9. RedTaxi
    RedTaxi F1 Rookie
    3,256
    New Zealand
    Glen
    I imagine the oil level would drop instantly once the oil pump stops.
  10. BrettC
    BrettC Formula 3
    Aug 13, 2012
    1,978
    Calif
    Brett
    Yes, you MUST check while running the engine at idle. HTH
  11. Keith360
    Keith360 Formula Junior
    Feb 6, 2015
    570
    Santa Barbara County
    Keith Williams
    Absolutely, the motor oil is no way a Heat Exchanger (Problem One). The frothy oil condition is between transmission Gear Oil. I would check the coolant for oil. Then check the coolant for combustion gas. Its a simple test.
    Worst case "Are you sitting down?", it could be a head gasket.
  12. YorkieMark
    YorkieMark Rookie
    Apr 11, 2018
    24
    Mark Lewis
    HOORRRAAYYY!
    Its fixed! It turns out that it was a small "O" ring at bottom of the disareator (part number 176388) - see 27 on the attached photo.
    £3 from Ferrari. £1 from eurospares!
    Thanks for all your replies.
  13. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,693
    Central NJ
    Dominick
    That is great .. would never have guess that in a million years
    Sent from my Moto G (4) using Tapatalk
    John_K_348 likes this.
  14. ItalGerBrit
    Mar 15, 2016
    817
    S La
    Now you did it. Everyone is now trying out how to check that Oring!
  15. John_K_348
    John_K_348 F1 Rookie
    Sep 20, 2013
    2,747
    Boston, MA
    John E. Kenney
    Haha! And way to go, I would have never thought of that either. But it makes perfect sense. I had overfilled mine last year on my first diy attempt. Smoked a bit at startup. Got it down some with a turkey baster then FoNE zeroed it in when I had my alternator replaced later in the summer. They also changed the filter and put in a new sender (oops). But they also installed new cam cap gaskets because the drivers side set was leaking. I tightened the rear one that I could see dripping a bit on the under panel and super glad I got those done. They were perished and the disareator o ring must have been too.
  16. aseweepay
    aseweepay Formula Junior
    Feb 1, 2004
    399
    Mid-West
    So, I finally had a chance to change the oil/filter etc. I used the oil change kit from Ricambi. With the Pennzoil platinum 5w-40 oil from the kit, there isn’t any evidence of foaming, which is great. The kit comes with 10 quarts of oil, the manual says the car can hold 10.5 quarts. With 10 quarts of oil, and the engine at operating temp and running when checking the level, the dip stick is dry. So, I know it can vary a little with each car, but what amount of oil do you guys seem to be putting in the car to get it to register on the dip stick about mid-way ?
  17. BrettC
    BrettC Formula 3
    Aug 13, 2012
    1,978
    Calif
    Brett
    IIRC mine takes around 9.5 quarts ish or so....
  18. Neilg
    Neilg Karting
    Feb 16, 2001
    241
    Accokeek, Md.
    Neil Green
    My 2003 360 Modena is now doing the same thing, i.e. the oil disaerator level rises to the top and is frothy when engine is hot, never used to do that, just curious as to how does the defective o-ring of the disaerator cause the oil level to rise in the tank? Thinking I need to change my o-ring also...
  19. Zcobra1
    Zcobra1 Formula 3
    Oct 9, 2012
    1,247
    So Cal
    Bert
    Well this is a timely thread.....just this morning I got my year 2000 Modena 360 back for the indie shop.
    It had an oil change with the Shell Ferrari approved oil, and boy is that stuff thin and foams a lot. I used Mobil 1 Euro before this in the car and I do not recal it being that thin, in particular when so fresh....also the Mobil 1 did not foam much if any.
    While it is hot here right now, and I checked it correctly, hot, running, after letting everything settle for 2-3 minutes, just surprised it is so thin it barely stays on the stick. And foams like crazy. I brought the shop my own oil/parts and they are very reputable, so pretty sure they used the Shell with the horsey on it......
    Based on this unscientific and neophyte observation, do not think I will use Shell again...
  20. tazandjan
    38,087
    Same conclusion we reached on mine. Switched to Valvoline full synthetic 5W-40 and have been using it for 9 years or so with no problems.
  21. Philminge
    Philminge Rookie
    Mar 2, 2018
    4
    Philip Mingerulli
    Hey Guys, sorry to revive an old thread.
    We have a 04 model 360 Modena with 10500kms on it from new.
    Last year i did an oil change, filter, coolant dump - flush twice and refil, Air filters, spark plugs, transaxle oil etc etc etc full service.
    I used Motul 300V chrono 10w40
    the car was driven once and it ran perfectly.
    12 months later we started it and it drove it last night and i did a simple oil check. its foaming badly right up to the neck of the cap....
    We are going to start with a basic oil and filter change first. if it still foams, we have to look down another avenue. maybe an Air leak somewhere?
    any more light on this topic???
    thanks
  22. 360+Volt=Prius
    360+Volt=Prius Formula 3
    1,761
    Western Mass
    Raimondo
    May be overfilled.
  23. Apollo 11
    Apollo 11 Karting
    Feb 11, 2019
    114
    San Francisco, CA
    Randy
    Maybe check that "O" ring at the bottom of the disareator they talked about earlier in the thread.
  24. ItalGerBrit
    Mar 15, 2016
    817
    S La
    Agree completely. Same thing has happened to me including smoking at hot start up after oil change. Ferrari mechanic recommended Motul because it does not seem to foam as much but it still does and looks just like the OPs photos. Removing a little oil at a time to get the level right makes sense. Sometimes "normal" is best not seen?
