Overheat 355F1 after track day | FerrariChat
Discussion in 'Technical Q&A' started by ssalahuddin, Mar 15, 2004.
  1. ssalahuddin
    ssalahuddin Rookie
    Dec 26, 2003
    11
    I took my 355f1 for a track day . After the 5th laps the temperature gauge light blinked due to overheated engine. Soon as I reached the pit, we check the water coolant, then we add at least 2 gallons of water to the radiator. After 1 hour i try to start the engine and it wouldn't start at all. The car had to be towed to the ferrari dealer and they found water inside the spark plug (they still checking for the rest of the engine) . Anybody now that if this could be a serious damage to the engine or simple drainage and gasket replacement will do the trick?
    I am located in Jakarta,Indonesia.
  2. cwwhk
    cwwhk Formula 3
    Nov 13, 2003
    1,535
    Hong Kong, Tokyo
    Wayne
    In general water inside combustion chamber is indicative of a leaky head gasket. Whether there is any permanent damage depends on how hot the engine got and for how long. What did your temperature gauge say? Did the temperature rise gradually over the 5 laps or was your engine overheated during all 5 laps around the track?
    When you tried to restart the car after 1 hour cool down, did you notice the engine cranked over slower than normal? If so then may indicate increased friction, which is not a good sign.
    Possible permanent damage may include scuffed pistons and or warped heads. BTW, I don't think it's a good idea to fill 2 gallons of cold water in an over heated engine while still hot. The thermal shock may cause more damage than good.
    I hope your car is OK and just needs new head gaskets. Good luck.
  3. pma1010
    pma1010 F1 Rookie
    Jul 21, 2002
    2,559
    Chicago
    Philip
    What is the coolant capacity of the engine? 5 gallons? Are you indicating you added 2 gallons of liquid without draining anything out (so that the motor was running with 3 gallons)?
    If not, then let's hope it is just a faulty gasket ($).
    If so, then you'll need to check that you haven't warped the head from overheating ($$$).
    Good luck
  4. Napolis
    Honorary Owner
    Oct 23, 2002
    32,118
    Jim Glickenhaus
    You must learn to look at your gauges. By the time the idiot light comes on it's often too late. Good luck.
  5. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,698
    The pertinate question is: did the water temperature simply head from normal to overheat in a single run up the scale, or did the water temp stabilize for a couple of laps and then heat for hot? What was the oil temp and oil pressure during those 5 laps?
    I run my F355 in Texas in the summertime (105dF). In the hour between runs, the water tank never depressurizes to the point you can look at the water level. If you can add water in less time than approximately 2 hours--this is bad! Adding cool/cold water to a hot engine is also bad.
    At this point, I suspect a head gasket. It ain't going to be cheap.
  6. atheyg
    atheyg Guest
    From what I understand concerning Ferrari V8s is a head gasket failure will not cause coolant leakage into the cylinders or oil, what will is a cracked head or block.
  7. tifosi69
    tifosi69 Formula 3
    Dec 23, 2003
    1,678
    Atlanta, Ga.
    Al-Al Cool J
    Good luck, sorry to hear this.
