P0421 / P0431 Trouble Codes (Catalytic Converter) ... anyone have good fix? | Page 11 | FerrariChat
Discussion in '360/430' started by bisel, May 25, 2017.
  1. Fort Worth 360
    Fort Worth 360 Formula Junior
    Jan 3, 2008
    409
    Fort worth Texas
    Can you point me to your Texas affiliates as I am in the dfw area
  2. ridege55
    ridege55 Formula 3 Silver Subscribed
    May 9, 2017
    1,385
    Manhattan Beach, CA
    Thanks Trev. I have a 430 and live in the Republic of California. I passed smog a few months ago, so I essentially have 2 years to figure this out ;)
    I cleared the codes last night and will see what happens. Your software is definitely an option if I can’t get this sorted out.
  3. Wayne 962
    Wayne 962 Formula Junior Rossa Subscribed
    Nov 27, 2003
    503
    Silly question, did you put the minicats on the front O2 sensors or the rear ones? I put mine on the fronts and we're having issues...
    -Wayne
  4. 360+Volt=Prius
    360+Volt=Prius Formula 3 Silver Subscribed
    Sep 1, 2013
    1,762
    Western Mass
    Raimondo
    Why would you put them there?
  5. bisel
    bisel Formula 3 BANNED
    Sep 12, 2012
    1,138
    Scottsdale, Arizona
    Steve Bisel
    They install in rear
  6. Wayne 962
    Nov 27, 2003
    503
    Well, the pre-cats are located in front of the sensors. The minicats are supposed to "emulate" the precats. So, they would go in the front sensors? In this configuration, the air coming out of the motor would pass through a CAT (the minicats) and then to the O2 sensor, just like the stock configuration.
    Perhaps I'm confused, or I wasn't clear - I still have the stock CATs, just not the precats in the headers?
    If the precats were removed, then why would they go in the rear? So, the exhaust would then pass through two cats between the two O2 sensors?
    Wait a sec, I am indeed confused. The O2 sensor is located *before* the precats. Duh...
    -Wayne
  7. bisel
    Sep 12, 2012
    1,138
    Scottsdale, Arizona
    Steve Bisel
    I believe you answered your question. The front O2 sensors are in the exhaust stream before any cats. They sample the exhaust gases immediately after engine manifold and are used by the ECU for stoichiometric analysis so that the ECU can dynamically make adjustments to fuel trim, etc.
    The rear sensors are only used to determine if the cats are working properly. When you removed the stock headers with precats, the rear O2 sensors are now thinking the cats are not up to snuff. By inserting the mini cats your goal is to restore enough catalytic material in front of the rear O2 sensors to make those bad boys behave themselves.
  8. yelcab
    yelcab F1 World Champ Consultant
    Nov 29, 2001
    13,549
    San Carlos, CA
    Mitchell Le
    If your new headers have no cat material, you are going to have problems even with the minicats. The signal will be too slow. You are not going to solve this with hardware. Software would be the way to go.
  9. bisel
    Sep 12, 2012
    1,138
    Scottsdale, Arizona
    Steve Bisel
    When you remove the stock headers from the 360, there is less catalytic material between the front and rear O2 sensors. This is root cause of the CEL codes being generated. The rear sensor output voltage is such that the ECU is sensing that the catalytic converter is not up to snuff.
    I invite you to look at the comparison between the 360 and F430 headers and catalytic converters ...
    You can see that between the front and rear sensor there is an amount of catalytic material in both the headers and front portion of the 360's catalytic converters. When you replace the 360 headers, you lose some of that catalytic material. The F430 headers do not have any catalytic material. Therefore replacing the F430 headers with aftermarket headers will not affect the amount of catalytic material between the two sensors.
    What those of us with the 360 have tried doing is to add mini cats at the rear O2 sensor position and then install the rear sensor on the end of the mini-cats. This is trying to restore the amount of catalytic material the exhaust gas passes through before the O2 sensor ... hopefully to get the O2 sensor's reading back where it was when the stock headers were installed. This generally works as one would expect. However, there is a secondary problem that is generated that deals with the response time.
    On the 360, the ECU not only looks at the voltage output of the rear sensor, but it also checks the timing of voltage spikes that occur with both front and rear sensors. The ECU threshold wants see that when the voltage spikes on the front that there is a corresponding spike at the rear sensor. If the timing between these spikes is too long, then this will trigger a "slow response" time CEL. When you install the mini-cats, this is a common problem.
    So, how to resolve this issue?
    I have found one solution that seems to be holding up now for several months. I removed the mini-cats and installed a pair of O2 extenders. It is worth noting that when you purchase O2 extenders, they typically have fairly small orifice for passing the exhaust gas. This orifice is too small and you will still get the CEL for slow response time. You need to open up that orifice by drilling out the body of the extender. But, an easier solution is purchase O2 extenders like this ... available on Amazon.
    https://www.amazon.com/dp/B07F7QFBGQ?tag=vglnk-c31-20
    In my case, I am using the largest orifice available with the above extenders, but the nice thing is you can easily increment and select four different size orifices using the three inserts. In my case, I am not using an insert.
    In my opinion, O2 extenders are not optimal, but so far they are working for me. If I do end up getting a slow response time code, it is an easy matter to read the code and clear it.
    A more optimal solution is to restore the amount of catalytic material between the front and rear sensors. Taking a cue from the F430 system, if one were to move the rear sensor to the downstream end of the catalytic converter, this would then restore the amount of catalytic material between the sensors. It would also dispense with the need for any mini-cats or O2 extenders. This can be accomplished by plugging the existing bung on the catalytic converter and installing a new bung as shown here ...
    I have not tried this, but I have examined the cats on my 360 and this looks perfectly doable. The rear O2 sensor have enough length of wire to accommodate re-positioning them as shown above.
    If I had known this at the start of my odyssey, I would have done this first and would not be messing around with mini-cats and O2 extenders. But, I am the point now with the larger orifice extenders which are yielding good results for me.
    Another solution is to reprogram the ECU to ignore CEL codes. I expect this solution will also provide very satisfactory results but I expect the cost is likely higher than moving the rear O2 sensor. It certainly is more costly than the O2 extenders I explained above.
    Steve
    f355spider, whatheheck and G. Pepper like this.
  10. Tarek307
    Tarek307 Formula 3 Silver Subscribed
    Sep 26, 2018
    1,348
    Long Beach, CA & Alexandria,Egypt.
    Tarek Salah
    This is a ******** nightmare -
    2004 360 Manual CS Exhaust
    Fabspeed Headers / EvolFlow 200 Cell Cats.
    Got P0421/ P0431 cleared (without making any changes) and went for another drive cycle then got P0431only. Cleared and then:
    Tried Steves extenders, and spoke with him & he's been a great help ( tried them without restrictive fittings, will add a smaller fitting tomorrow) and got P0421 alone this time.
    I live in CA and must have all readiness monitors ready, so the ECU flash thing i don't think will work, hard to get a solid sure answer it seems about that.
  11. Skippr1999
    Skippr1999 F1 Rookie Silver Subscribed
    Dec 22, 2009
    4,508
    I hate this BS. The 355 has finally been set free in my part of the country at age 25!
    JoeTSI and G. Pepper like this.
  12. fanboy01
    fanboy01 Rookie
    Jul 15, 2011
    34
    Hi Steve. Spent 3 days read this thread and it's rly helpful to me i learned a lot from it. Hope you have completely got rid of the dreaded CEL now. Maybe not the right model but i'm troubled by CEL for quite a few month. I have a 2019 Portofino with Kline 200 cell sport cats, X-pipe and stock mufflers. CEL always on unless i clear it with Capristo OBD Wizard but will reappear within 100miles driving. I believe it is caused by the sport cats so i bought a pair of no brand O2 spacers with mini cats inside on ebay. But they just made no difference CEL still on. I send a message to Big Daddies and they said their product won't work for me. I like the extra volume sport cats bring but CEL is rly a thorn in the flesh. So may i ask, apart from an ECU tune, what can i do to resolve this issue? Should i try the fabspeed 02 spacers with mini cats?
  13. bisel
    Sep 12, 2012
    1,138
    Scottsdale, Arizona
    Steve Bisel
    I still have the stock catalytic converters and the Fabspeed headers (without the pre-cats) and using the O2 spacers I mentioned in my earlier post ... the CEL I was getting has gone away. Been about several months and no issues. That is not to say that the CEL will not come back. But, if it does, I will move the rear O2 sensor further back in the exhaust flow.
    I have heard of people wiring in a small resistor into the O2 sensor lead. If memory serves me, it was a 51 ohm resistor wiring into the black lead on the O2 sensor. But, I would not be surprised to learn that this method might clear the CEL about low efficiency, but might not clear the CEL about slow response time.
    I would try getting these adjustable gas flow O2 sensor spacers ...
    You can purchase these on Amazon. Here is the link:
    https://www.amazon.com/EVIL-ENERGY-Restrictor-Fitting-Adjustable/dp/B07F7QFBGQ/ref=sr_1_5?crid=1MA1SYM36M10G&dchild=1&keywords=o2+sensor+spacer&qid=1589293498&sprefix=o2+,aps,190&sr=8-5
    They are inexpensive and I found that using two of these without the inserts yields the largest size orifice for maximum gas flow and my CELs are gone. Cannot definitely say they will fix your situation as your mileage may vary. But, worth a try for less than $25 for two of them.
    Steve
    whatheheck likes this.
  14. bisel
    Sep 12, 2012
    1,138
    Scottsdale, Arizona
    Steve Bisel
    Also on Amazon, is this adjustable flow O2 sensor spacer that is curved and looks like it results in a longer flow for the exhaust gas. There are two types of CEL codes that one is likely to get coming from the downstream O2 sensor:
    1. O2 sensor efficiency code. Caused by a missing O2 sensor or having the O2 sensor too far out of the exhaust stream. Interpretation is that the sensor efficiency is bad and would normally lead one to replace the sensor.
    2. O2 sensor slow response time. The normal interpretation is that the sensor is bad. This is caused by too little exhaust gas reaching the sensor and the car's ECU is looking for spikes in voltage at the rear sensor to be in sync with spikes on the front sensor.
    The problem is trying to balance the two. In this balancing act, I found the adjustable gas flow sensor spacers to work for me.
    Here is the link for these curved spacers ...
    https://www.amazon.com/Vibrant-11619-J-Style-Restrictor-Adjustable/dp/B00AQ7972O/ref=psdc_15730891_t5_B08562QDW2
    Steve
  15. G. Pepper
    G. Pepper Three Time F1 World Champ Rossa Subscribed
    Mar 15, 2012
    38,375
    Texas/Colorado
    George Pepper
    Months after adding the Fabspeed headers/blankets and the Fabspeed sport cats to my car, no CEL! I kept my valved Ferrari Challenge Stradale can and it sounds glorious. All the burbles and pops, and a scary scream when wide open.
    No pre cats, no spacers, nothing. It just works.
    Two years of CEL problems gone. ~shrug~
    JoeTSI likes this.
  16. fanboy01
    fanboy01 Rookie
    Jul 15, 2011
    34
    Thank you Steve. I bought an OBD reader yesterday and found the codes for me are P013A/P014A, O2 Sensor Delayed Response – Rich to Lean. I will try the O2 spacers on Amazon you recommend. So these spacers just adjust the amount of gas flow but no mini cats inside? Will they resolve O2 sensor slow response but trigger low catalytic efficiency again?
