Panel popper | FerrariChat
Panel popper
Discussion in '348/355' started by Oengus, Apr 7, 2008.
  1. Oengus
    Oengus F1 Veteran
    Anybody have an alternative for a panel popper..............I want to replace the tweeters in my 355.......
    see below quote:
    "If you plan on removing the tweeters from the dash, there are clips on top and bottom on the speaker half of the vent. Panel poppers can release the lowers and the upper can be released by rotating the ac vent upward exposing the underside of the top clip. A screwdriver under the clip can pop it to make it easier to remove. The tweeters seem to be rotate mounted on their tabs and glued there. Mine happened to have weak glue I guess and with a little coaxing came off".
    Chas
  2. Oengus
    Oengus F1 Veteran
    Thx
    chas
