Pilot bearing help | FerrariChat
Pilot bearing help
Discussion in '308/328' started by akimmel, Jul 28, 2013.
  1. akimmel
    akimmel Karting
    Aug 13, 2009
    189
    Dallas, TX
    Art Kimmel
    #1 akimmel, Jul 28, 2013
    Another dumb move on my part.
    I failed to measure the depth of the seat on the end of the crank for the pilot bearing. It's been years since I pulled all of this apart and I am wondering if it is proper for the bearing to not seat flush to the surface of the crank. It's about 0.140" out and I am reluctant to whale on it any harder than I already have. Pulling it probably means another new bearing so I thought I would ask if anyone in our forum knows.
    Thanks for any help! Picture attached.
    Art
  2. Steve Magnusson
    25,151
    See the cross-section drawing on page D6 in the 308GT4 WSM -- some protrusion is present to center the flywheel (and there's some nominal clearance on the far side to the shoulder on the splined shaft). The ID hole in your flywheel may show some witness/rust marking from the old bearing being there -- if you account for the radius on the bearing outer race corner, it might give you an idea of the prior ballpark protrusion.
  3. akimmel
    akimmel Karting
    Aug 13, 2009
    189
    Dallas, TX
    Art Kimmel
    The drawing makes me feel better about the protrusion. It's probably a good assumption that the drawing is somewhat to scale. The 0.14" that I measure is about 1/3 of the 0.4" measured flywheel thickness in that area. I'll leave the bearing for now and try to verify spline clearance when I attach the bell housing.
  4. smg2
    smg2 F1 World Champ
    Sponsor
    Apr 1, 2004
    15,523
    Dumpster Fire #31
    SMG
    Steve's right, the outer race is used as a concentric center for the flywheel. typical protrusion is ~0.150"
