Poor idle
Discussion in 'Mondial' started by decardona, Jun 13, 2017.
  1. ATTENTION: http/https Bug Fix! Most of us have been experiencing problems staying logged in as we navigate the site. That is simply the result of links varying between http and https, which each require different logons. To resolve we are going to force https starting sometime Wednesday. However, you may have problems accessing FerrariChat until after you log out, clear cookies/browser cache, and log back on. Keep in mind my email is admin@ferrarichat.com if you do have access problems after Wednesday. Thanks!
  1. decardona
    decardona Formula Junior
    Apr 23, 2005
    922
    PA
    Dennis Cardona
    I'm having a consistent problem. When I start up my car is fine. Idles well and consistent. Upon driving and getting to temperature the idle gets very low when coming to a stop. 500 or less. It feels as if it wants to stall. I throttle tap and it comes back, but if happens almost every time I come to a stop. The car is a 3.2. Any ideas? Thanks.
  2. Steve Magnusson
    Steve Magnusson F1 World Champ
    16,857
    Texas
    #2 Steve Magnusson, Jun 13, 2017
    Is this:
    A. A problem that appeared suddenly - i.e., everything was working fine for a while, and then this symptom started, or
    B. It's always been this way since the last time someone messed with all the adjustments?
    Edit: Bigger question - just noticed that you have an SA version, which (from the SPC) is no cat, no Lambda (no O2 sensor, no frequency valve, no K-Jet Lambda ECU), no air injection, but with vacuum limiting valve (so essentially a K-Jet without Lambda set-up). Is your SA version: 1) completely unmodified, 2) modified to be US legal, or 3) was modified to be US legal at one time, but has since been further molested in some unknown way ;)?
  3. Wade
    Wade F1 World Champ
    Rossa Subscribed Owner
    Mar 31, 2006
    19,657
    East Central, FL
    Wade O.
    #3 Wade, Jun 13, 2017
    Steve, as a refresher, here's the baseline from Jan 2015:
    http://www.ferrarichat.com/forum/technical-q/475731-mondial-3-2-k-jet-o2-sensor-control-system.html
    The "project" pretty much ended there when I discovered the root of the [vacuum] problem, a rusted vacuum reservoir.
  4. Steve Magnusson
    16,857
    Texas
    So does that mean you never got the frequency valve to work?
    Did you ever confirm/deny if the injection ECU was receiving +12V power from somewhere?
    The single green wire sure does look like it should go to the single signal wire of the O2 sensor -- does it?
    Are you saying you never had the symptom decardona is reporting (after fixing the vacuum leak)?
  5. Wade
    Wade F1 World Champ
    Mar 31, 2006
    19,657
    East Central, FL
    Wade O.
    Correct on all i.e. never got a chance to pursue any further other than some research. So, sorry that I can't help beyond that. The car was back to it's normal, excellent running self after I replaced the canister.
    http://www.ferrarichat.com/forum/mondial/476277-hvac-doors-flapping-about.html
    While I was tempted to restore the car back to OE (as it left the Factory and undoing the import conversion), I didn't have the time to do so. And then I bought a 348, and no longer needed a 2+2 Ferrari.
  6. spicedriver
    spicedriver Formula Junior
    Feb 1, 2011
    623
    Sounds like the linkage is getting hung up. Get the low idle symptom to show up, then pop the hood, and see where the throttle plate is exactly. Is it all the way closed ? Then do the throttle tap and recheck the throttle plate position again. I'll bet the tap causes the throttle plate to rest in a different position.
  7. Tired of seeing this ad? Upgrade now
  8. decardona
    Apr 23, 2005
    922
    PA
    Dennis Cardona
    Steve, the problem just popped up in the last couple of months. Prior to that it was smooth all the time. Wade made me aware of the things he did/changed on the car and I checked those items and they seem to be fine. The throttle plate position is something I will look at next. Hopefully it's something that's not going to be too problematic to fix.
  9. spirot
    spirot F1 Veteran
    7,772
    Atlanta
    Tom Spiro
    if this is just sudden, it sound more like an air leak in one of the vacuum hoses. Aux air valve, or something along those lines. also check the Frequency relay & fuse on the control panel - not sure where this is located in the Mondial, but in the 308's its under carpet on the passengers side of the trunk area. But my bet is going to be an air leak. next would be electrical. then mechanical... doubt its the throttle housing as if it were stuck open you would have a higher idle... if it was not returning or returning too closed you would have stalling.
  10. mike32
    mike32 Formula 3
    May 13, 2016
    1,296
    Uk
    First off checkt the throttle cable to the engine bay, you will see a spring loaded quadrant on top of the engine. These have a habit of getting a bit stuck, give it a shot of wd 40 and check it moves easy.
    Other thing is to put some injector cleaner in the fuel tank- if no change then try some of the other items previously mentioned. It might be just something simple
  11. decardona
    Apr 23, 2005
    922
    PA
    Dennis Cardona
    Thanks for all the input. Will be working on it this weekend. Will let you know what it turns out to be. Thanks again.
  12. ronfrohock
    ronfrohock Formula 3
    Aug 16, 2004
    2,023
    MA
    Ron Frohock
    Whenever I see Steve chime in, I pay attention. He has proven to be very knowledgeable and very generous with his time in the past. I can tell you that he has helped me more than a few times with odd problems that I have faced.
    I'll be following this closely.
  13. Steve Magnusson
    16,857
    Texas
    That's very kind of you to say Ron -- and this one won't be easy because it's been seriously modified (and that may not have been done correctly) and who knows what else now ;)
    IMO, the OP is going to have to decide whether to leave it operating as a K-Jet without Lambda (and it surprises me that was ever working OKish in that manner if it didn't have a VLV and had a K-Jet with Lambda WUR installed), or try to get working as a K-Jet with quasi-Lambda as it was once modified to be.
    OP:
    1. Can you post a (some) more complete picture(s) of the engine? (Wade's picture only showed the fuel distributor area -- would be interested to see if a VLV and/or a throttle microswitch is present or not.)
    2. Can you post the 10-digit Bosch PN shown on your WUR?
    3. If you do have a throttle microswitch present, try unplugging when you are at 1000 RPM warm idle (if it's working, I think something should happen ;)).
  14. Tired of seeing this ad? Upgrade now
  15. Wade
    Wade F1 World Champ
    Mar 31, 2006
    19,657
    East Central, FL
    Wade O.
    #13 Wade, Jun 14, 2017
  16. decardona
    Apr 23, 2005
    922
    PA
    Dennis Cardona
    Steve, thanks for all the ideas. But, I tried some of the simpler ideas and the combination seemed to solve the issue. I put some fuel injection cleaner in and ran the car for a bit after. Then the next day I sprayed the throttle linkage with some carb cleaner and after being on the road for about 20 minutes, the problem was no longer there. Smooth idle, warm or cold, and upon coming out of gear when stopping. If it reoccurs, obviously, I need to get into the more technical things you suggested. I appreciate you taking the time to offer up suggestions. You were a help several times when I needed answers on my 308 and now on the Mondial. You are a great asset to those of us who try to DIY.
    Wade, thanks for your input on where the car stood under your stewardship. Although I have all the records, I don't remember all that was done off the top of my head, as you do. You stepping in with info right away is appreciated. Thanks again.
  17. Wade
    Wade F1 World Champ
    Mar 31, 2006
    19,657
    East Central, FL
    Wade O.
    The traditional "Italian Tuneup", in regards to your car, means shifting at redline. :)
