News
Portofino: How much you can lower on stock suspension?
Discussion in 'California/Portofino/Roma' started by lamborarri, Dec 17, 2019.
  1. lamborarri
    lamborarri Formula Junior
    436
    Picking up my Portofino today, notice the wheel gaps are huge. I wonder how low I can go on stock suspension? Thank you!
    lfc-Q8 likes this.
  3. JBlack002
    JBlack002 Karting
    64
    Mooresville, NC
    Jim
    My dealer lowered each corner 1” on the stock coil overs. I have experienced no issues after 500 miles.
    lfc-Q8, Igor Ound, tomc and 4 others like this.
  4. lamborarri
    436
    That looks really good. Thank you! I will probably ask them to do the same.
    lfc-Q8, uhn2000 and JBlack002 like this.
  5. Redneck Slim
    Redneck Slim Formula Junior
    977
    Palo Alto,CA,USA
    Walt Kimball
    You can lower on the stock suspension only with Magneride. Not on the standard suspension.
    lfc-Q8 and lamborarri like this.
  6. lamborarri
    436
    Thank you for the note. Yes my car has the the option.
    lfc-Q8 likes this.
  8. carthusiast
    carthusiast Karting
    Sep 22, 2018
    143
    Did you pick up your Porto from an American dealer? Wondering if there are any restrictions in the US?
    lfc-Q8 likes this.
  9. lfc-Q8
    lfc-Q8 Rookie
    Oct 1, 2018
    40
    athbi
    i asked my dealer if he could lower my car, he said it will effect the warranty.
  10. lamborarri
    436
    Yes.
    My dealer has no problem with it. They would do it for me.
    lfc-Q8 likes this.
  11. Nick.C
    Nick.C Rookie
    Oct 14, 2019
    25
    nicholas chatburn
    I would be gobsmacked if it effected the warranty, considering it is “adjustable” from factory...
    Think your dealer is telling you porkypies
    djastral69, lfc-Q8 and Il Co-Pilota like this.
  13. dr_genious
    dr_genious Karting
    Dec 20, 2017
    81
    Lucerne Switzerland
    Sven
    I did the same. Approx 2.5mm / 1 inch is a perfect setting, both in looks and driving behavior. No warranty effected.
    lfc-Q8 likes this.
  14. uhn2000
    uhn2000 Formula 3
    1,989
    Toronto
    Joe
    Mine they did .8 inch and I love. Will post pics tomorrow with the winter rubber on as well :)
    Caeruleus11, lfc-Q8 and MRJW like this.
  15. uhn2000
    uhn2000 Formula 3
    1,989
    Toronto
    Joe
  16. uhn2000
    uhn2000 Formula 3
    1,989
    Toronto
    Joe
  17. Il Co-Pilota
    Il Co-Pilota F1 Rookie
    4,045
    Copenhagen
    A.B
    Lol. That's great. So the gearbox gives out or the roof fails, then what? He's going to say it was because yoh had the car lowered a bit? That's rich.
    lfc-Q8 likes this.
  18. Il Co-Pilota
    4,045
    Copenhagen
    A.B
    Asked the local Challenge tech about this. He said that if the car came with ACTUAL stock ride height from factory, then no more than 20mm. He added that doing a 15 mm rear and 20 mm front lowering would dial out some of the understeer and balance the car better.
    lfc-Q8 likes this.
  19. Il Co-Pilota
    4,045
    Copenhagen
    A.B
    Just to clarify. I say actual stock ride height, because these cars often come out of the factory slightly off in this regard. Some may sit 5 mm higher than stock, others a bit lower. So getting it properly measured at the dealer before adjusting it, is a good idea. If the car sits 5 mm higher than spec, a 25 mm drop is fine. But if your car sits 5 mm below, you may have issues.
    lfc-Q8 likes this.
  20. lfc-Q8
    lfc-Q8 Rookie
    Oct 1, 2018
    40
    athbi
    now i asked my dealer again and the master mechanic told me he can do it but he will charge me crazy money as he needs to redo the whole suspension.
    my question is: did you guys need to redo the alignment on the car after it being lowered?
    because i can do it outside the dealer for fraction of the cost.
    thanks
  21. Il Co-Pilota
    4,045
    Copenhagen
    A.B
    Yes you absolutely do need a realignment after a lowering. If you feel confident you can do the lowering yourself, you can do that and then get the car realigned. But don't listen to anyone who say you don't need the alignment, because they then clearly know nothing.
    lfc-Q8 likes this.
  22. lamborarri
    436
    you will need corner balance and alignment but you can do it at some race prep shop after AD lower it. race shop would do it better and set up better. But if you are not fighting for the last drop of performance, then you can just lower and alignment would be good enough.
    lfc-Q8 and SAFE4NOW like this.
  23. uhn2000
    uhn2000 Formula 3
    1,989
    Toronto
    Joe
    It cost me about 1500 usd to lower the car.
    lfc-Q8 likes this.
