News
portofino tyre pressure for the standard 20'' wheels
Discussion in 'California/Portofino/Roma' started by chrisf355spider, Aug 13, 2019.
  1. chrisf355spider
    Jun 24, 2014
    31
    buckinghamshire , uk
    chris coates
    Could anyone please confirm what this should be .. I'm away from the car currently. thanks in advance
  3. Continental AutoSports
    Sponsor
    Aug 22, 2006
    3,552
    Hinsdale, IL
    Jeremy Sus / Parts Department
    Vin number and possibly assembly number are the only factors in determining the correct TPMS.
    I can supply you with the correct Ferrari TPMS if you give me the last six of your vin.
  4. chrisf355spider
    Jun 24, 2014
    31
    chris coates
    it's the tyre pressure setting that I'm after? ie 2.1 bar?
    Il Co-Pilota likes this.
  5. Il Co-Pilota
    Il Co-Pilota F1 Rookie
    4,033
    Copenhagen
    A.B
    If you're in a pinch, simply use the pressure specified for the Cali/Cali T.
    2.4 front, 2.2 rear.
    Quite sure the Porto will need similar, if not same.
    Those are for Michelin tyres btw.
  6. SVCalifornia
    SVCalifornia Formula 3
    Mar 28, 2011
    2,076
    Silicon Valley
    Keith
    Aren’t the correct specs in the door jamb?
    SV
  8. GlowRed
    GlowRed Formula Junior
    Mar 2, 2012
    259
    West Midlands, UK
    Correct tyre pressures depend on the tyre supplied.
    There is a sticker on the drivers door in the door jam which gives the pressures for each tyre make.
    chrisf355spider likes this.
