Possibly the worst pilot decision I have ever seen | Page 2 | FerrariChat
Discussion in 'Aviation Chat' started by f4udriver, Apr 21, 2015.
  1. kevfla
    kevfla Formula 3
    Nov 20, 2003
    2,086
    gone 4 good
    Gives new meaning to the term "shaker-stick!"
  2. jcurry
    jcurry Two Time F1 World Champ Silver Subscribed
    Jan 16, 2012
    24,153
    In the past
    Jim
    The efficiency of a prop blade diminishes rapidly at the tip. Mostly the tip just generates noise, especially at high RPM. Hartzell has a Q-tip propeller where the blade tips are curled, although only about 2 inches versus 4-5 on this airplane. A Q-tip increases tip efficiency much the same way a winglet increase tip efficiency on a wing. So curling a blade back 4 inches would not be as dramatic as one might think.
    In-balance would be a product of un-even curling or loss of material. Hard to tell from the picture how much of either occurred.
    Note: In no way am I justifying the actions of the pilot, either aborting the landing or flying home.
  3. 2NA
    2NA F1 World Champ Consultant Owner Professional Ferrari Technician
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I bet he needed the time to prepare his story or decide whether to just ditch it in the drink.
  4. Rifledriver
    37,367
    There is also the idea of climbing from it in front of everyone who just saw you do it and the fact that once it stopped it ain't going nowhere until it is fixed.
    Dumb as it was at least now it is home.
    Putting it in the drink? Been done before but tough with all those witnesses and a custom paint job. Takes a little planning too if its going in deep water. Got done once to a Mosquito for insurance money.
  5. 2NA
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I'll bet he considered it.
  6. Steve355F1
    Steve355F1 F1 World Champ Owner
    Aug 26, 2011
    17,198
    Adelaide, South Aust
    Steve
    Holy crap!
    I've got a couple thousand hours in an Aerostar, and I think it's "reputation" is thoroughly undeserved. I'd rather be in an Aerostar than almost any other piston twin if you lose an engine, provided it is being flown properly. As always, speed is everything.
    That, however, has got to be one of the stupidest things I've ever seen done in any aircaft.
    Mind you I do remember seeing a C210R taxi in and park at our local airfield with a prop looking much the same for the same reason as this guy.
    Usual case of a private pilot with far more money than ability.
  7. cheesey
    cheesey Formula 3
    Jun 23, 2011
    1,921
    the A-star balances nicely on the mains with the nose (wheel) up, allowing to bleed off speed for a short roll or keep speed up on long runways
  8. kevfla
    kevfla Formula 3
    Nov 20, 2003
    2,086
    gone 4 good
    Maybe the pilot thought he was in a Lake Buccaneer!
    It is not unknown for a absent-minded Lake pilot to lower the landing gear for a water landing.
  9. jcurry
    Jan 16, 2012
    24,153
    In the past
    Jim
    Not unknown for any amphib pilot. Once had an immaculate 206 amphib that two wks after we sold it was upside down in a river in Alaska. Landing wheels down on water is much more dramatic than wheels up on land.
  10. NürScud
    NürScud F1 Veteran
    Nov 3, 2012
    7,317
    OMG.....
    Very lucky....
  11. alexm
    alexm F1 Veteran
    Sep 6, 2004
    5,223
    Coast up from Sydney
    Alex
  12. Bob Parks
    Bob Parks F1 Veteran Consultant
    Nov 29, 2003
    8,018
    Shoreline,Washington
    Robert Parks
  13. Tcar
    Tcar F1 Rookie
    Jan 2, 2010
    4,739
    Denver, Albuquerque
  14. alexm
    alexm F1 Veteran
    Sep 6, 2004
    5,223
    Alex
    oh!
    ok.. I looked it up. Story here describes issue as detected hydraulic leak 30 min after takeoff.. they proceed to Warsaw from Newark LOT Polish Airlines Flight 16 - Wikipedia, the free encyclopedia
    I see it is described as still under investigation, what was the incompetence at play here?
  15. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    The circuit breaker for the alternate landing extension system was popped and not checked. If it had been checked and reset, the gear would have extended. Theses days are different, I guess ,when it comes to mechanical skills. That LOT airplane could have been fixed. We replaced the entire belly from aft of the nose to the 46 section, landing gear, struts, engines, and lower wing skins on several 707-320's in the 60's and they were back in the air in 30 days. The AOG crew cut the entire bottom end off the airplanes and rebuilt them IN THE FIELD. It appears that those men and their skills are gone now. I'm glad that I was a part of it.
  16. alexm
    alexm F1 Veteran
    Sep 6, 2004
    5,223
    Alex
    Seems incredible thing to miss.. if not a "sensible" check.. then on a checklist.. if not then they would/should have been in touch engineering support all the time and THEY would have ideas/checks.. just wow then.
    I think a LOT (pun intended) of things are becoming more "throw away/buy new" mentality in general.. very sad on several levels.
  17. Gatorrari
    Gatorrari F1 World Champ Silver Subscribed
    Feb 27, 2004
    16,554
    Georgia
    Jim Pernikoff
    The question I have - was the Boeing AOG team even consulted? I think the aircraft could, and should, have been repaired, and it may be LOT's fault for not even trying.
  18. jcurry
    Jan 16, 2012
    24,153
    In the past
    Jim
    The airframe, or structure, is not the over riding consideration in maintenance and operation of a commercial airliner. You should see some of the 777's that are being scrapped.
  19. FERRARI-TECH
    FERRARI-TECH Formula 3
    Nov 9, 2006
    1,677
    Los Angeles
    Ferrari-tech
  20. LetsJet
    LetsJet F1 Veteran Owner
    May 24, 2004
    9,334
    DC/LA/Paris/Haleiwa
    Mr.
    Seems like a plausible explanation.... It could have had a much worse outcome...happy it didn't.
  21. garybobileff
    garybobileff Formula 3 Sponsor
    Feb 5, 2004
    1,183
    San Diego CA
    Gary
    I guess in his case, pulling the gear up after positive rate didn't apply to his way of thinking!
    Gary Bobileff
  22. kylec
    kylec F1 Rookie
    Jun 9, 2005
    3,671
    Orlando
    At 87, it may be time to give up flying at least without someone in the right seat.
  23. Bob Parks
    Nov 29, 2003
    8,018
    Robert Parks
    Even though I am 89, for all practical purposes, I can fly every bit as well as I could when I was 20...in my head. I can go through the commands to my feet hands, and eyes but, for some reason, the arrival of the signals are not getting there at precisely the same time and the the coordinated application of inputs does not happen. The commands get there but the resulting maneuver sometimes is late, jerky, and not pretty. To get back to acceptable performance would take a lot of practice in what used to be student level exercises and even then there would be instances where peripheral influences are missed and picked up later than they should have been. But other than that, I can fly just like I used to 70 years ago.
  24. Hannibal308
    Hannibal308 F1 Veteran
    Jan 3, 2012
    7,177
    Arizona / Hawai’i
    Hannibal
    Man, I feel sorry for that dude!
    I can't imagine the ignominy of being laid bare before the world at 87 like this guy has. For all we know he's had 5000 hours of accident-free flying since he was 15 years old and now none of that matters. Of course, I don't know, but still...I wouldn't want to be wearing his fuzzy slippers and terry cloth jump suit.
