Power for radar detector?
Discussion in 'Technical Q&A' started by Seve, Feb 12, 2004.
  1. Seve
    Seve Rookie
    Nov 6, 2003
    13
    My '88 Mondial Cab has a lighter that will not accomodate a plug for my V1. Do I need to direct wire it? If so, what is the best way to do it.
  3. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    8,433
    Find a wire in the dash that has 12V when the key is ON and 0V when the key is OFF. V1 comes with a clipon power connector--wrap connector arround wire, crimp on with a pair of pliers. The current load is small enough that you can simply use (about) any circuit matching this prescription.
  4. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,075
    Southeast USA
    Mike Charness
    On my '84 308QV, I have it wired into the domelight's hot wire.
  5. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    DITTO what mcharness did. Have it wired into the domelight's hot wire and ground. Shortened the power wire yet DID make sure the fuse section was still employed (VERY IMPORTANT).
    Enjoy the Drive,
    Steven R. Rochlin
  6. Seve
    Seve Rookie
    Nov 6, 2003
    13
    Thanks--that sounds like a good way to handle it.
  8. 4re gt4
    4re gt4 Formula 3
    Apr 23, 2002
    2,279
    Roseburg, OR
    Hans E. Hansen
    I found an unused spade connector on the fuse box. Just ran the cord up the inside of the "A" pillar and under some trim to the area of the mirror. As it was a bit tight in some areas, I used standard phone cord without the ends and then put on Radio Shack ends with their crimper.
