430 - Power steering pipe vibration on parking | FerrariChat
430 Power steering pipe vibration on parking
Discussion in '360/430' started by tony3156, Aug 10, 2021.
  1. tony3156
    tony3156 Rookie
    Jul 4, 2021
    4
    Tony Tseng
    My F430 scuderia
    Fast turning steer wheel on parking or Idle.
    Vibration occurs from the front of the car.
    I try remove the removable rear luggage compartment panel.
    I found that the return pipe vibrated after the hydraulic steering radiator.
    I tried drain the system and fill the power steering system,no change.
    Now,I want try bypass the hydraulic steering radiator.
    Maybe the return pipe is blocked?
    Thanks for the help.
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,920
    Isle of man- uk
    Is this only when the steering is full over ?
  3. tony3156
    tony3156 Rookie
    Jul 4, 2021
    4
    Tony Tseng
    NO,is on turning.
    I replaced steering box(brand new)
    the problem not solved....
    I think this is normal,because many 430 and 430scuderia stored this problem....
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,920
    Isle of man- uk
    Its certainly not an issue on mine, jack the front wheels of the floor and turn the steering lock to lock, that will bleed any air in the system. Then check the fluid level in case it goes down. Any play in the steering rack track rod ends
