Pre-empting Sticky Buttons | FerrariChat
Discussion in '612/599' started by LWR550, Nov 26, 2019.
  1. LWR550
    LWR550 Formula Junior
    Nov 8, 2003
    304
    East Sussex
    My 599 has a slight tackiness to some of the buttons, specifically the "AUTO", "LC" etc.
    They are a long way off needing a refurb, but was looking for advice on how I can prolong their non-sticky life?
    Any tips, or recommendations of something I should be applying to them?
    Thanks!
  2. Skidkid
    Skidkid F1 Veteran
    8,762
    Campbell, CA
    John Zornes
    I don't think there is anything that will do what you want. Once they get sticky the back stuff gets all over. I would just get them done. I had several things cleaned and redone on my car.
  3. scriber17
    scriber17 Karting
    Oct 30, 2008
    54
    Manhattan, NYC
    Tang
    What happens if you clean them with some alcohol?
  4. donv
    donv Two Time F1 World Champ
    24,103
    Portland, Oregon
    Don
    My opinion, which doesn't seem to be widely shared, is that heat is the enemy of that stuff, so I would keep it out of extreme heat as much as possible. Just my experience. Buy a sunshade for the windshield, keep it parked inside, etc.
    Skidkid likes this.
  5. 285ferrari
    285ferrari Two Time F1 World Champ
    Sponsor
    Sep 11, 2004
    20,847
    Southern Md
    Robbie
    You cannot stop it or prevent it. Once it starts, no stopping it
    Randy P. likes this.
  6. gsholz
    gsholz Formula Junior
    324
    Oregon
    Jerry
    I'm looking at a 599 at a local dealership. Overall well maintained, gone through Ferrari inspection and eligible for power warranty, but dealer/owner do not seem to be concerned about sticky button mess. It is a complete turn-off for me. Don't want to buy a $140k car with many buttons sticky and not legible. These buttons are not that expensive (between $50 and $300 at Scuderia parts). Why don't owners change them? Are the consoles that difficult to get off?
  7. docf
    docf Formula 3
    Sep 14, 2008
    1,358
    Florida
    Gary
    Ferrari now recommends Hydrocleaner by Lechler. Will it work ? . Can be purchased from Ferrari Parts Dept. Made in Italy. It is not cheap @ 100.00 for 1000ml. I bought some for my 15 458. Will it work living in Fl. I don't know.
  8. F3RN4ND0
    F3RN4ND0 Karting
    Nov 16, 2015
    195
    Madrid, Spain
    F3RN
    FW1 Cleaning Wax worked for me.
  9. George Vosburgh
    George Vosburgh F1 Rookie
    Sticky No More fixes the problem permanently. Replacing the buttons just starts the process all over again.
    lee-o, Potenza430 and 285ferrari like this.
  10. F3RN4ND0
    F3RN4ND0 Karting
    Nov 16, 2015
    195
    Madrid, Spain
    F3RN
    (for LC, Auto and R buttons only)
  11. 285ferrari
    Sponsor
    Sep 11, 2004
    20,847
    Southern Md
    Robbie
    We have replacement AUTO and R buttons in stock, the rubber versions cannot be cleaned, they must be replaced.
  12. 285ferrari
    Sponsor
    Sep 11, 2004
    20,847
    Southern Md
    Robbie
    Once you start adding up all the parts in that car that goes bad, it is VERY expensive. Thousands of dollars is normal, not a button here and there, much more than that.
  13. smggms
    smggms Formula Junior
    Apr 29, 2018
    252
    Matt Godwin
  14. Steinhart
    Steinhart Formula Junior
    May 21, 2019
    259
    Scottsdale, AZ, USA
  15. smggms
    Apr 29, 2018
    252
    Matt Godwin
    no rubbing , just spray let it dry .. do it again
    then feel it
  16. 285ferrari
    Sponsor
    Sep 11, 2004
    20,847
    Southern Md
    Robbie
    I have had many customers spray stuff, clear paint, other types of coatings to try and "harden" up the stickiness. The parts will still turn sticky underneath, the coating will start to come off like a black goo and takes two to three times longer to strip. Will cost you WAY more in the long run, just FYI. We normally have to charge extra hours to refinish because of the mess and time it takes.
  17. RossoC360
    RossoC360 Formula Junior
    Jun 20, 2008
    475
    Buffalo NY
    Jason
    The best solution is to remove the parts and send them out to a reputable company who is honest, and has a quality/permanent solution to the sticky soft touch coating failure. Do your homework. Having the parts properly refinished is also beneficial if you ever try to sell the car as it adds value and most people in the market or business look for the work to have been done.
  18. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,379
    Weston, MA
    Paul
    The little door to my USB port was sticky. I used Goo Gone over a year ago and it's still fine. I figure if it should get sticky again, I'll just use Goo Gone again.
  19. Speed and Angels
    57
    Dallas, TX
    Fix what is sticky and climate control your garage, it works pretty well.
