Project-Scuderia | Page 17 | FerrariChat
Project-Scuderia
Discussion in '360/430' started by RBM, Nov 7, 2011.
  1. freshmeat
    freshmeat F1 Veteran
    Aug 30, 2011
    7,289
    I'm disappointed to read you didn't choose to make lighter carbon reproductions of the skid plates ;)
    Seriously though, anyone putting around in their Scuderia / 16M without skid plates, lowered or not, is a buffoon. And anyone buying the cheaper eBay versions where the entire underside isn't covered is erm no better...
  2. freshmeat
    Aug 30, 2011
    7,289
    Premier Motorsport is where to get the good stuff btw, just in case folks aren't yet aware.
  3. martiy1971
    martiy1971 Formula Junior
    Jun 2, 2015
    651
    Alberta
    Robert Martineau
    As I mentioned earlier, I love the skid plates you have, but holy s**t they are expensive - $850 plus shipping??? I will try Premier like Mr. Meat suggested.
  4. freshmeat
    Aug 30, 2011
    7,289
    #404 freshmeat, May 4, 2016
    Here's the Premier one for comparison...same difference?
  5. martiy1971
    Jun 2, 2015
    651
    Alberta
    Robert Martineau
    Looks the same to me, and at half the price.
  6. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    Well, we are officially getting close to a new battery technology that is production-ready. BMW just announced a battery pack upgrade for the 2017 i3. 50% more energy (+ 11kW-hr) in the same size battery compartment. No cost or weight data yet, but the article suggested no significant increase in weight or cost, so BMW is making good on their word, and they are right on schedule as well.
  7. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    #407 RBM, May 9, 2016
    After this most recent round of upgrades to the car, I am setting it up for street/show, rather than pure track use. To deal with local TX roads and parking lots, as well as the reduced ground clearance of the front skid plates, I raised the ride height up to 136 mm front / 156 mm rear. I took the Scud into Soulspeed in South Austin, where Colin is quickly becoming the local go-to guy for alignments to spec. He set the car up to a street/stock alignment, which was tougher than expected for the minor increase in ride height. I then checked the corner balance and made some minor adjustments. The OEM sway bar drop links are back on the car, and they are not adjustable, so corner balancing was less effective. Nevertheless, the results were acceptable.
    Corner Balance Results
    198 lb driver
    Fuel – half tank (12.5 US gal)
    Sway Bars – OEM drop links (non-adjustable)
    LF – 734 lb RF – 699 lb
    LR – 917 lb RR – 916 lb
    Cross Weights – 1650 lb (50.52%) / 1616 lb (49.48%)
    Total Weight – 3266 lb
  8. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    Now that the Scud is re-assembled and has an all-new setup, it's time to set another baseline:
    Curb Weight Results
    - No driver
    - Fuel: full tank (25 US gal)
    LF – 670 lb RF – 665 lb
    LR – 889 lb RR – 923 lb
    Cross Weights – 1593 lb (50.57%) / 1554 lb (49.43%)
    Total Weight – 3147 lb
    Changes from Original Baseline
    - CF Rockers
    - CF Decklid
    - CF Under-Body Panel
    - CFRC Brake Rotors
    - Titanium Brake Rotor Hats
    - 16M Forged Wheels
    - Pirelli P-Zero Rossa Tires
  9. ShineKen
    ShineKen Two Time F1 World Champ
    20,036
    Southern California
    Nostradamus
    Interesting. That's still quite a bit away from Ferrari's "estimate" of 2975lbs. I know Euro cars should be lighter as they have less re-inforcements, but 175lbs difference is quite a bit.
  10. redcaruser
    redcaruser Formula 3
    Apr 8, 2012
    2,428
    switzerland
    daniel
    That's Ferrari. It's called compensatory justice: because they never deliver the promised engine performance they offer even more car weight.
  11. freshmeat
    Aug 30, 2011
    7,289
    Nor on the promised "limited quantities" ;)
    RBM's Scuderia still weighs significantly less than a Speciale "in the wet" which has been confirmed by a few owners on here to be in the excess of 3350lb mark!
  12. rmarchjr
    rmarchjr Formula Junior
    May 21, 2012
    586
    North east, USA
    +1 Shine,red,fresh
    True enough, but -117# (18gls @ 6.5#) = 3030# thats only 55# more then estimated. I don't think its really fair to fill the tanks to the brim. No other manufactures includes full tanks in their estimates either. I usually give it enough for 30 minutes on track just to be fair- 6 or 7 gallons.
    The OP doesn't but if someone really wanted to use the car on track, it didn't take much work to get my car to 2850, and that includes a CH rollbar hoop, harnesses and heavy stock wheels with cannon fodder steel brake discs and 7ish gallons of fuel. Mine still has AC & power windows.
    Interior panels, airbags, Ferrari CF seats and horrible stock exhaust is just about 150# not very expensive and all goes back in anytime...
    Nice work RBM, that is a wonderful show car! Beautiful, improved and as perfect as any car be. I hope you enjoy it.
  13. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    The difference is dry weight vs. curb weight, as discussed back on the first page of this thread (many months ago). If you pull out the 25 gallons of fuel (at 6.1 lb/gal = 152.5 lb) and 1.8 gallons of washer fluid (at 8.0 lb/gal = 14.3 lb), the 3147 lb curb weight is reduced to 2980 lb, which is very close to spec.
  14. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    Looking back at the original baseline in post #1:
    And considering the current changes to the car:
    CF Rockers -8 lb
    CF Decklid -7 lb
    CF Under-Body Panel -6 lb
    CFRC Brake Rotors +5 lb
    Titanium Brake Rotor Hats -2 lb
    16M Forged Wheels -2 lb
    Pirelli P-Zero Rossa Tires +14 lb
    Total Change -6 lb
    So, the curb weight of the car should be 3125 lb - 6 lb = 3119 lb.
    But, the curb weight was 3147 lb on the scales, which is a 28 lb error in the wrong direction. Upgrading from the OEM battery to the Optima Yellow Top when the original battery died may account for a few of those pounds, but the more likely culprit is an inaccurate fuel or other fluid fill.
  15. MaseratiCorse
    MaseratiCorse Formula Junior
    Nov 13, 2014
    472
    Melbourne, Australia
    Nicholas
    Any plans to modify the exhaust?
  16. freshmeat
    Aug 30, 2011
    7,289
    Woah, I missed this CF under-body panel...are you selling any? -6lb is a good reduction! Can you kindly PM me details please =)
  17. rmarchjr
    May 21, 2012
    586
    North east, USA
    Braille Battery B2015 - Braille Advanced AGM Lightweight Racing Batteries
    15# and you could remove all the stock brackets, steel floor mount etc. No one sees it and your close to 45# out of the car for $200 and an hour or two of work.
  18. ShineKen
    20,036
    Southern California
    Nostradamus
    #418 ShineKen, May 12, 2016
    I thought Ferrari claimed a curb weight of 2975lbs. Not dry weight
  19. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    Not sure of the source of the image that you pasted in, but it appears to be third party marketing data, which is different than engineering data. But this is an interesting discussion. See the following posts.
  20. Maks-F430
    Maks-F430 Rookie
    Jul 10, 2015
    5
    Ukraine, Kyiv
    Maks Pyzhyk
    3135lbs (1422kg) stock F430 coupe
    2975lbs (1350kg) stock F430 scuderia ;)
    True
  21. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    From Wikipedia, the free encyclopedia
    Curb weight (US English) or kerb weight (UK English) is the total weight of a vehicle with standard equipment, all necessary operating consumables such as motor oil, transmission oil, coolant, air conditioning refrigerant, and a full tank of fuel, while not loaded with either passengers or cargo.
    This definition may differ from definitions used by governmental regulatory agencies or other organizations. For example, many European Union manufacturers include the weight of a 75 kilogram driver to follow European Directive 95/48/EC.[1] Organizations may also define curb weight with fixed levels of fuel and other variables to equalize the value for the comparison of different vehicles.
    The United States Environmental Protection Agency regulations [2] define Curb Weight as follows: Curb weight means the actual or the manufacturer’s estimated weight of the vehicle in operational status with all standard equipment, and weight of fuel at nominal tank capacity [grey area], and the weight of optional equipment [another grey area] computed in accordance with §86.1832–01; incomplete light-duty trucks shall have the curb weight specified by the manufacturer [this is established by OEMs to serve more as a limitation than a specification].
    Unladen mass depends on the manufacturer and can be the same as curb weight, however it is often the total mass of the car without a driver, fluid or any additional equipment [this is where the marketing department comes in].
  22. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    Dry weight is the weight of a vehicle without any consumables, passengers, or cargo.
    It is one of the two common weight measurements included in road vehicle specifications, the other one being curb weight.
    By definition, dry weight does not include any of the following:
    Gasoline, diesel or any other fuel
    Engine oil
    Coolant
    Brake fluid
    Power steering fluid
    Transmission fluid
    Washer fluid
    The difference between dry weight and curb weight depends on many variables such as the capacity of the fuel tank.
  23. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    Over time, most domestic vehicle manufacturers have more commonly used the term 'shipping weight', which refers to the vehicle in as-built, no-option condition. This would include engine oil, coolant, brake fluid and at least some small quantity of fuel, as vehicles have traditionally been driven off the assembly line and these fluids were necessary to do so.
  24. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    I monitor this market periodically, but I have not seen a product that meets the project's constraints:
    - No loss of vehicle utility or street-ability
    - mandatory use of advanced technology and/or materials
    - Increased performance
    - Competitive cost/pricing relative to OEM
    The titanium exhausts I have seen so far are not technologically advanced enough yet. I'm waiting for something really aerospace-grade. Think inconel forgings, hydro-formed titanium tubing, and Bose dynamic sound-canceling.
    The same argument applies to my search for a battery solution.
  25. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    See posts #212 to #280 (June 2013 to February 2014) for our discussion of lightweight batteries for F430s.
