Project-Scuderia | Page 20 | FerrariChat
Project-Scuderia
Discussion in '360/430' started by RBM, Nov 7, 2011.
  1. RANDY6005
    RANDY6005 Formula 3
    2,270
    Jacksonville
    RANDY
    RBM have you ever weighed your Scud ?
  2. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    Yep, about a hundred times, starting with post #1.
  3. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    Battery charger/maintainer - here are some photos of the battery charger that comes with the Lithium battery. It's fully automatic, and has three banks of lights for three sets of functions.
    The bank on the left is for charger diagnostics. It let's you know that the charger is working properly, and is properly connected to the battery (polarity is not backwards).
  4. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    The bank on the right is for battery diagnostics. It checks the health of the battery. If the battery checks out good, the charger switches into one of its three charge modes.
  5. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    The bank at the bottom tells you what charge mode the charger is in, based on your battery's condition. If the battery is really low, it goes into save mode. Normal mode is charge mode (shown). When the battery is nearly charged, it switches to optimize mode to balance the cells and maintain the optimum charge.
  6. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    Here's a look at the inside of the stock US Scud rear bumper. Note the ribbed reinforcement structure. It's bonded to the rear bumper cover with epoxy. Both the cover and the reinforcement are made of fiberglass.
  7. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
  8. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,651
    England
    Mark
    I like where this is going.
  9. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    Here's the exterior of the stock US rear bumper. The US cars have side marker lights and rear reflectors, both red in the rear and both the same size (actually made from the same part, with the marker light having a light bulb installed).
  10. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    The side marker slot is open on the inside, while the rear reflector slot is closed because of the reinforcement structure inside the bumper cover. There are two small holes in the reinforcement panel, just big enough to get an extended socket through to tighten the fasteners on the back of the reflector. This is the best position for the bumper when you install the reflectors, so that if the nuts fall off the studs, they fall out of the bumper, rather than into the void between the bumper cover and the reinforcement.
  11. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
  12. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
  13. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,651
    England
    Mark
    For reference the Euro bumper is 9.1kg.
    RANDY6005 likes this.
  14. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    Here's the inside of a Euro Scud rear bumper. It uses the same fiberglass reinforcement bonded to the cover, but the lower corner section is trimmed away, revealing the inset for the rear reflector/marker light.
  15. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    The other big difference between the US and the Euro rear bumper is the deletion of the side marker light. You can see there is no oval inset in the upper corner of the cover, above the mounting bracket.
    Flea7 and RANDY6005 like this.
  16. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
  17. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    ShineKen and Flea7 like this.
  18. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    One more interesting difference between the US rear bumper and the Euro rear bumper is the license plate light placement. The two lights are placed a couple inches farther apart on the Euro bumper, in order to illuminate the larger Euro license plates. Not obvious unless you are literally beneath the car, looking up.
  19. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
  20. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    8.930 kg converts to 19.68 lbs, for a savings of 2.86 lbs over the 22.54 lbs of the US bumper, for a 12.7% weight reduction. It's notable that the reduction is all attributable to design and not to a change to a higher performance material.
  21. Scottslaw
    Scottslaw Formula Junior
    Freaking love this thread! I try to reduce the weight on every “fun” car I own. It’s fun, and if you are like me and value the “feel” of how a car drives, all these little improvements really do enhance the enjoyment and overall experience. Keep the updates coming and thanks for the inspiration!
  22. freshmeat
    freshmeat F1 Veteran
    Aug 30, 2011
    7,257
    Still tuning in for the low-down on the carbon center column...which sponsor do you speaketh?
  23. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    R-Tuned and Exotic Car Gear
    freshmeat likes this.
  24. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    The Euro rear bumper with the marker lights, upper valance/grill, and lower grill installed. Everything is intended to bolt up, although I encountered some bolt/stud holes on the bumper for the lower grill out of tolerance. Nothing new in this thread.
    kane00, Flea7, ShineKen and 2 others like this.
  25. freshmeat
    Aug 30, 2011
    7,257
    I wonder if there’s any weight to be saved from sealing/bondo’ing over those rear reflectors as well or would it net out to be the same as w reflectors+hardware+electrical.
    Will look super clean for sure. I might take up this mod if I find a deal on an oem euro bumpers...never liked the reflectors and side markers.
